Trailer Hitch on a 07 TL
Old Jun 20, 2009 | 11:15 AM
Country Al's Avatar
I notice Acura discourages all towing but I need to bring a boat, maximum load weight 1800 lbs., to my home 700 miles north of Tampa, Florida.
I wonder the consequences if I pull it.
Any experiences out there?
Old Jun 20, 2009 | 11:23 AM
Rick_TL-S's Avatar
You'll probably destroy the engine....
I'd say rent a truck to be safe.
Old Jun 20, 2009 | 11:59 AM
I hate cars's Avatar
It's not so much the engine but the trans and possibly rear suspension that I would worry about.
If it's an auto, when accelerating, do so easily. When cruising down the freeway on flat ground, keep it in 4th gear and when going uphill if in doubt, err on the lower gear side. High rpms in a lower gear will generate less heat in the trans than high load and low rpms. I would definately keep it at 55mph/4th gear. Give it 30mins to cool every hour to hour and a half.
Since you're going to be working it hard for an extended period, use a high quality 10w-30 oil. Mobil One 0w-40 would also be an excellent choice coming from Tampa.
A synthetic trans fluid will take the extra heat better.
Keep in mind that the TL has 65% of it's weight on the front tires, you don't want the boat spinning you out. I would be very careful the trailer is balanced well. The rear suspension doesn't have much spring stiffness so it doesn't take much to really compress the rear and cause excessive tire wear from the extra camber.
If done slow and sane, you can probably do it without hurting the car.
tj19855
Dec 5, 2016 09:16 PM
CL-S progression 01
Jan 26, 2016 04:15 PM
27trains
4G TL Problems & Fixes
Sep 30, 2015 09:44 AM
supadrai
Jul 31, 2002 08:14 PM
