TL cams
Mom why is there two?
TL cams
Hey I searched but to no avail. A friend of mine asked if there was cams available foe the TL besides having WEB CAM make some wasn't there a post on bisimoto or someone who came out with a couple of sets and retainers also I thought. Any help would be appreciated. Thanks
I wonder what process he uses. They definately have to be hardened after being ground. We lost about 100 GN engines during the "budget roller cam upgrade" due to hardening issues. I can't comment on this guy because I have no idea what process he uses but this can be a very real problem if not done or not done correctly.
I have regrinds in my car personally and have had no problems for a couple of years. Mild grind with stock springs and retainers. Also Pee or whatever your name is you will never see a dyno chart from me. I dont give two shits about dyno numbers.
Do you have these installed in the TL or something else? I'm curious what your impressions are in a TL?
IHC yes I have them in the TL. I was the guy who was talkin to you about the 275 on the stock wheel and the custom coilovers. I have had them going on the third season they are a very mild grind with a slightly aggresive v tec lobe. I am having a couple a new cams cut this winter these should be very bumpy.... we will see how the car acts with those. Still using stock tune with a fpr. So far she's a runner. We put down a 13.18 at 109 on the bfg forces. It is more of a track car, than straight line.
It's good to hear there are no issues with the cam reliability. I'm assuming they're on the big lobe most of the time lol.
No prob....... List begins with, I started with a port and polish of the manifold and lower tubes I put them on a bench to see what they were doing went through one manifold trying to figure out the right size. Lower tube took my time on and got those done I could prob go further but did'nt want to buy a set of those, cus I didn't want my number to go down on the bench. All the crank and valve cover stuff has been deleted and small filters put on those all the engines inhales is air. Fluid dampener crank pulley. Cams, Full custom 3 in intake. Your gonna hate me but a 1" TB spacer with a 1/4 in manispacer.... think tunnel ram and if you do the math which I have done they make a tiny amount of power. I have a program that helps me build sheet metal intakes, that is how I came up with the widths of the spacers. Ported throttle body. I think that is all for the motor. Exhaust is... precat deletes and a stock j pipe I had a xlr8 and lost 2 tenths at the track so I went back to stock and went back to where I was. Full 2.75 in stainless with mandrel bends through a pro flow race single chamber. Then to 3 in with 2.5 in inserts for backpressure slip tubes if you follow with a 3" tip. The suspension you know about from a previous thread. It is a 2004 base 6 spd. With minimal weight reduction minus the spare tire and jack and junk and back seat other than that it has full interior with nav. OOOPPPs I have taken all the plastic stuff underneath the car out and the dust shields for the brakes. Thats it guys besides a good grind on the cams. We all have to think,,,, this motor has the compression, It just needs a little head work and some good ole' roller cam thinkin small block style....LOL old schoolers will get that one.
No prob....... List begins with, I started with a port and polish of the manifold and lower tubes I put them on a bench to see what they were doing went through one manifold trying to figured the right size out. lower tube took my time on and got those done I could prob go further but did'nt want to buy a set of those cus my numbers went down on the bench. All the crank and valve cover stuff has been deleted and a filter put on those all the engines inhales is air. Fluid dampener crank pulley. Cams, Full custom 3 in intake. Your gonna hate me but a 1" TB spacer with a 1/4 in manispacer.... think tunnel ram and if you do the math which I have done they make a tiny amount of power. I have a program that helps me build sheet metal intakes, that is how I came up with the widths of the spacers. Ported throttle body. I think that is all for the motor. Exhaust is... precat deletes and a stock j pipe I had a xlr8 and lost 2 tenths at the track so I went back to stock and went back to where I was. Full 2.75 in stainless with mandrel bends through a pro flow race single chamber. the to 3 in with 2.5 in inserts for backpressure slip tubes if you follow with a 3" tip. The suspension you know about from a previous thread. It is a 2004 base 6 spd. with minimal weight reduction minus the spare tire and jack and junk and back seat other than that it has full interior with nav. OOOPPPs I have taken all the plastic stuff underneath the car out and the dust shields for the brakes. Thats it guys besides a good grind on the cams. We all have to think. this motoe has the compression, It just needs a little head work and some good ole' roller cam thinkin small block style....LOL old schoolers will get that one
So it sounds like basic intake, exhaust, and cams will take you very far. I guess adding a little more cam really lets the intake and exhaust breathe. I honestly had no idea if the J series would respond to a cam but apparently it does.
The reason I'm interested is I'm getting ready to do the timing belt and valve adjustment. In fact, I was going to do the valve adjustment tomorrow and timing belt 6 weeks from now but I may hold off until I decide to get the cams or not. The additional labor to do the cams does not look to be that much more.
One last thing... Have you noticed any loss in low end? It's the 5at's low stall speed tha I'm worried about. I'm hoping since it's a vtec motor, low end will be mostly unaffected.
Thanks for all of the great info. It's very nice to talk to someone who has done this work. 109mph is absolutely awesome. That's around 350 crank hp at 3,400lbs. You picked up basically 100 crank hp from intake, exhaust, cams, and a little porting of the intake tract. I would be happy if the 5at would trap 105mph with the same mods. this would allow me to play with IS350s and such.
Sometimes I almost wish something would happen to force me to tear into this thing. I always think about it and then feel guilty.
The low end seems fine no loss. I felt considerably more torque especially in the 1to 2nd. Yes if you are going to be in there doing all that you might as well be throwin those in there as well...lol No the car is on straight pump for now. My old cl is the one that ran on the stuff. I will convert this one over as well
Hi ethenol...I recently finished instaling my pre-cat deletes on a 08MT Type S putting down 290whp/262tq (I have never been to the track yet)....I have been doing lots of research regarding cams with Bisimoto...also I was considering the upgrade of the intake runners whoever I do not know if they do it fo the Type S i've seen it for the regular TL and 08 Accord...You are not using any ecu for fine tunning? Those are awesome numbers dude. Anyways just wanted to see what are your recommendations since I am heading this route. If i get to do the cam and runners, I think I would do a complete head work...Let me know what do you think
All motor
109?!!! Holy sh!t. Do you know the specs of the stock cam? Also, would you be willing to share at least some specs of your custom cam?
And you said no tuning just a FPR? Wow....I am extremely impressed. More info, more info!!! I may switch to the stock Jpipe!
Have alot of stuff goin on tonight and a huge write up for you guys It will have to wait till tomorrow. Pulled some stuff off of mitchell
well, I wouldn't give the credit to the stock jpipe.
It is the whole package that must work together in harmony with all of the other parts.
The stock jpipe is working better for ethenol because the stock jpipe is covering-up something out-of-harmony elsewhere in the overall package. My guess in that his overall package is looking for backpressure since he has a huge 2-3/4" exhaust.
Turd Polisher
Very interesting!
I would LOVE to do this for my Accord ... much better than going FI on a daily driver.
All motor
Hmm...maybe. My exhaust is bigger
I figured I may as well try it, should only take like 45 minutes to take off.
Ethenol, let us know tomorrow!!! Oh, do you have stock tires on it as well? Or did you run that time at the track with different size tires? I know smaller overall diameter wheel/tire combo makes a difference in gearing and acts like changing the FD.
Stock cams specs. this is the cam lobe height.
Intake primary, 35.041mm-1.4348in.
Intake. Mid, 36.445mm-1.4348 in.
Intake, secondary, 35.284mm-1.3891in.
Exhaust, 36.326mm-1.4302in.
These are the stock specks and I unfortunatly am not going to give up the secrets yet until I have the new set and see how those do. You never know I may be going back to that setup. I am just trying to push the stock ecu and stock setup, to see how far it will really go before tuning is needed. Tire size is a 275 40 17. Bfg G-Force and a luk clutch. I have all the mitchell specs for the TL I just cant figure out how to get it over to azine in one peice. Computers are not my specialty.
The plan for this winter and next year are serious weight reduction and some fine tuning of the suspension and the new cam setup. I might be having some head work dome no milling just taking the seat lip out and see if we can get better numbers on the bench.
I also will be going to to try the bigger TB on a trial basis. Also the A/C will be coming out I think that will be a great weight saving along with a better throttle responce not needing to spin that thing around for no reason. I have never used the damn thing anyways so what the hell I figure.
The main emphasis will be pushing the stock fuel and ecu to its limit to see where it is and taking the car itself to the limit with no major surgery being done the the body and suspension itself.
I am currently working on a sheet metal manifold but that is a year or so out still working on flow numbers and over all making it a easy bolt on thing for everybody . Wish me luck
The track is Michigan international speedway. aka Martin raceway. Martin Michigan. It was in the low 2's if I remember. It was in 09 when I ran the car. It was early spring. track was a little loose. It would prob hook better in warmer temp and I bet the trap would be a couple mph lower.
Sorry man wasnt tryin to be a dick but anytime anybody does anything around here.... Its dyno numbers or its bullshit. Not all of us can afford a dyno session. I have dance lessons that come before a dyno.... lol aka kids, take all your cash until they are 20 and out of your house.
2004 NBP TL 6MT
Bisimoto in general has camshafts made to their specifications by Web Camshafts. I have been to their facility, met their crew and have extensive experience with their products on another Honda application. They have quality products. They are one of the few companies that truly tailor the camshaft to the vehicle application. Take their descriptions literally, when they say "race" they mean it.
I would simply determine whether I needed stronger valve springs and retainers or not. Also, if tuning equipment is needed to support, which seems to be a limited market for TL's. Even though we have factory programmable ECU's and wideband oxygen sensors, the tuning hardware is there. Just a matter of time before someone figures out how to access it and allow tuners to use it.
All motor
