Time for a necessary mod: brakes
I'm running EBC red with stock rotors right now and they recently started making a strange grinding noise.
My rotors are pretty chewed up from the pads (grooved) so I figure I'd get some slotted ones while I pick up some new pads.
After doing some research and speaking to some people, this is what I've come up with. I drive a 5AT BTW.
Rotors:
Rotora slotted ~$360
RB 1pc slotted ~$380
Pads:
Rotora H2 ~$135
RB ET500 ~$210
I'm leaning towards the full Rotora set up because I don't think I need the "best" set up. I wouldn't fully utilize an amazing set up anyway.
This is just a nice upgrade from OEM.
What do you guys think?
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
Rotors:
Pads:
Rotora H2 ~$135
RB ET500 ~$210
I have the rotora slotted with pads in front. They are great, no noise, low dust and of course much better stopping. If and when I need brakes I would certainly buy them again.
i bought fronts like 2 weeks ago, but with the ceramic pads, theres worth the money, im getting my rears done tommorrow so ill let you know how the whole setup performs and take some pics!!1
Cruising in my
Did you order with Heel Toe ?
I may have to do this next summer... 46,000 km's (just under 30,000 miles) on my stock brakes as of now with stock Brembo's
Oderint dum metuant.
Exactly what I'm looking at getting later this year, although I might cheap out and just get OEM/OEM replacements (the TL is as good as gone, just need some time to pass). Also, no need for the ET500's unless you track/autoX your car a lot...was going to mention that earlier.
There is a TL & GL in
how much did you pay for RB all around with et300 and ss lines? what brake fluid are yoou goin to be using?
i am eyeing the exact same setup and if marcus hooks it up id get it in a heartbeat!
why not cross drilled/slotted Brembos, and brembo stock pads....you will never get a better set up....
speaking of EBC... green stuff is the easiers on ur stock rotors, and red just completely destroys them....ur stock rotors are soft...which is why breaking is so great on the car with the brembo setup...both rotors and pads are soft and they bite instantly... EBC needs to heat up before it bites...always with a delay...and they're not the right pads for stock rotors......
i dont know about all these new names...rotoras and blah blah blah....one of those "back yard" manufacturers.....
either Brembo, or try Disk Italia <<$370 for front only...cross drilled and slotted.... incredibly amazing
not a fan of drilled/slotted? how so? u just dont like how they look? or u dont like what they offer? if u only like plain rotors....nothings gonna beat the stock brembo rotor. they wear out quick for a reason, and thats cause theyre soft, which makes them very biteable
Full of water...
Full of water...
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
