Throttle Body Spacer HELP!
I just got finished putting on the P2R spacer only to realize that I left the $%!*ing old gasket on there. Is this going to be a problem? Can I leave it on or should I take it off?
THANKS
THANKS
see makers or sellers threads for that info- spacers reduce heat transfer at critical point in air to engine
any old gasket material is asking for a leak-
vac leaks are really bad as they can burn valves and other parts,,general bad running
take it apart and do it right this time= never have to worry
I like a product called gasket cinch for installing stuff- gets tacky but never dries so easy to remove parts later--extra sealing power for when in doubt.
can be used as bolt thread goop to help hold them without going to threadlock
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
