Throttle Body Spacer
Working On It
Let's start with the obvious question... do these even work? If so what would the power gain be realistically? I have seen two sides to these, some people buy them and swear up and down that it made a difference, and some people buy them and curse out the company cause they see no difference.
For those that have tried this what does the gain look/feel like? Any actual statistics? Or do you feel cheated like you wasted money.
Finally for those of you who feel a gain what brand did you buy?
not worth spending the money. adds weight and maybe .5 hp
P&P milled heads, or pauls intake manifold as well.
justnspace (02-28-2013)
... i got the zdx tb and p2r adapter... but i also picked up a ported intake manifold cheap.
For those looking... i got mine over on k20 from autofair. They got a package deal
I'd pass.
1QWKTLS
The "concept" behind this is a barrier to prevent engine heat sink into the throttle body, thus keeping incoming air cooler. The cooler the air, the more dense and so more power. The problem is that your engine is all contained UNDER your hood, which eventually builds up heat, so this defeats the entire purpose of the heat barrier! Your better off spending your money on a good CAI
What you are talking about are gaskets, which they do make however as you stated since everything is under the hood the only good the gasket does is slow a process down. Even if it kept everything 10-20 degrees cooler, you would see much increase in power.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
