throttle body
throttle body
who know if the throttle body of the 3.0l accord is the same as the tl. Street & Performance Electronics do a throttle body spacer for 3.0l accord and it suposed to be 22hp and 25 ft lb torque gain. did anyone have evnen try it?
MPG increases are pretty much limited to exhaust, compression, and engine management changes, not intake changes pre-manifold.
94 DC4 RS LSV/Turbo
oh you are talking about the Street and Performance Electronics ![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
http://www.streetandperformanceelect...inst/91306.pdf
their spacer was out before the p2r, there was a member on here running it, last i checked he reported loosing power, no idea if they modified their design, would be good to run it using the p2r silicon thermal gaskets
http://cgi.ebay.com/ebaymotors/03-04...mZ260288943929
Not your moms TL.
as the owner of the 2007 Tl-S that S and P used, I can vouche that the statement abve is FALSE. True, the TBs are the same, even one set of years supposed to be a bigger bore. as far as the HP gains...If you honestly want to know i have the dyno runs showing a 4 WHP LOSS. Dean is supposed to be milling me ones w/ a smaller bore, and one with a bigger bore for further testing...curious, are you from LR?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
