Thoughts on Cat delete??
Old Jan 22, 2018 | 11:05 AM
Muizz Saheed's Avatar
M m s
Hey guys I have a mid muffler and resonator delete on my TL, I was wondering if I should do a cat delete ? Any thoughts on that ... thanks
Old Jan 22, 2018 | 11:31 AM
the TL has 3 cats.
2 primary cats and a third cat underneath the car.
if you are talking about removing the third cat and straight piping it...it will only yield 2-3hp.
the better move would be to replace the Jpipe and third cat with an aftermarket Jpipe that has better bends which helps exhaust gas evacuate faster.
an aftermarket jpipe that removes the third cat cost about $350-500 and will yield 15hp.
Old Jan 22, 2018 | 11:33 AM
ExcelerateRep's Avatar
Former Sponsor
Deleting cats will have an effect on your exhaust system in a couple ways...
There is always emission testing to consider. If you live in an area that is strict about their testing then it is very possible you'll run into issues, and will need to revert back to your stock parts every couple of years. This is something that doesn't concern some people, but others like to avoid the potential for extra hassle.
Deleting the pre-cats with a system that is pretty close to a straight pipe will cause some rasp as well, so sound is going to be another thing to consider. From my experiences guys with a setup similar to yours usually end up looking for a way to quiet it back down a bit. Adding a resonator or switching to HFPCs are usually the best ways to fix this (if you find yourself getting to that point).
The last downfall of the PCDs is the exhaust smell they tend to make in the cabin when you're stopped. When there is air moving this shouldn't be noticeable, but some find it overwhelming sitting at a light or something like that.
If you haven't done the Jpipe already I would recommend starting there! It will allow you to pickup a couple extra HP by deleting the cat and merging the pipes together with a smoother bend. Plus emissions testing shouldn't be as big of a concern since that deletes an unmonitored cat, won't cause a CEL, and doesn't require a tune to run! The Jpipe will change the exhaust note as well, so you can get a little bit of everything like this!
If you already have the Jpipe then HFPC/PCDs are a great way to continue to pick up power! Feel free to send me a PM if you'd like help getting setup. I'll link you to our site below so you can see the pieces I mentioned:
RV6 PCD: RV6-PCD-TL-3G - RV6 Pre Cat Delete - Excelerate's Honda & Acura Store - Japanese Performance Specialist
RV6 HFPC: RV6-HFPC-TL-3G - RV6 High Flow Pre Cat - Excelerate's Honda & Acura Store - Japanese Performance Specialist
XLR8 Jpipe: JPIPE-V2-UA67 - XLR8 J-Pipe - Excelerate Performance - European, Exotic and Japanese Performance Specialists!!
Good luck and happy modding!
Old Jan 22, 2018 | 06:14 PM
M m s
the TL has 3 cats.
hmm thanks for the info 👍
Old Jan 22, 2018 | 06:15 PM
M m s
probably going to invest in a Jpipe in the near future. If you guys ship to Vancouver B.c I'll be definitely ordering when the time comes !!
Old Jan 23, 2018 | 09:22 AM
Former Sponsor
We certainly do! If you wanted to PM me a postal code I'd be happy to get you a shipping quote!
Old Jan 23, 2018 | 12:15 PM
M m s
the TL has 3 cats.
thanks for the info
Old Jan 23, 2018 | 12:22 PM
losiglow's Avatar
Like XLR8 said, J-pipe is the best way to start. The 3G has a pretty restrictive J-pipe/downpipe. I used the RV6 for my 3G and the XLR8 for my 4G. Very happy with both in terms of quality, sound and performance.
Old Jan 23, 2018 | 07:01 PM
DomGSR-T's Avatar
Come on guys Jpipe are useless, please advice this kid the right way!
Old Jan 24, 2018 | 03:24 PM
1black_seven's Avatar
Slot Machine Lubricator
PRE-CAT DELETES + V3 JPIPE + RESONATOR - MID MUFFLER = horseshit rice cooker
Keep the mid-muffler, or get high flow cats, or invest in a high quality cat back exhaust. But running no cats with a j-pipe sounds like an EP3 with an eBay exhaust.
Old Jan 29, 2018 | 03:21 PM
Acura TL Builder's Avatar
ATLP exhausts have a heavenly note without all the rasp and drone.
Old Jan 31, 2018 | 09:11 PM
twokexlv6coupe's Avatar
I agree, the ATLP sounds absolutely orgasmic.
If I wanted to build my own custom ATLP (purely for the sound, not for the performance) would it essentially be;
Keep the stock PreCat's and J-pipe, then straight pipe (delete 3rd cat, resonator, and mid-muffler) back, and keeping the rear mufflers?
Old Jan 31, 2018 | 09:55 PM
M m s
hmm that seems like it would be nice.. I wonder how it sounds..
Old Jan 31, 2018 | 09:57 PM
M m s
Thanks for all the input guys, I appreciate it !😁
Old Jan 31, 2018 | 10:44 PM
My 3rd cat is an ATLP high flow, and I have the resonator on aswell. Stock HFPC.
I'll make a video of the ATLP J-pipe, ATLP high flow 3rd cat and ATLP cat back w/ resonator so you can see what it sounds like.
Going to install RV6 high flow precats this weekend!
Old Feb 26, 2018 | 12:37 AM
M m s
Old Feb 26, 2018 | 10:08 PM
greenpearl6speed's Avatar
Public Figure
Do it. Also delete the back two mufflers as well. Let all the rice out it will sound great
Old Feb 26, 2018 | 10:38 PM
M m s
lmao I'm good 😂
Old Apr 4, 2018 | 12:11 AM
Hector Irizarry's Avatar
3rd Gear
i currently have all stock exhaust except the rear muffler delete and it sounds amazing. With no rasp. But now my question is will installing high flow primary cats cause a check engine light.?
Old May 21, 2018 | 03:33 AM
friltz's Avatar
Hey guys so I bought an 05 tl a couple months ago. I haven’t had the time to look at it completely yet but from what the previous owner said I’m pretty sure it’s completely straight piped. No cats, aftermarket j-pipe and all mufflers deleted. Not sure about resonator. It does cause a CEL every once in awhile but goes away in a day or so and will stay off for weeks. But it is WAY TOO LOUD!! Super raspy, gets louder and shitter when you let off the throttle and after 3000rpm sounds like a weed whacker. Can’t stand it anymore. Any suggestions on what to do? I’m considering buying a stock exhaust and starting over. Also worried about passing inspection with the cat deletes.
Old Jul 16, 2018 | 12:22 PM
Glassman's Avatar
9th Gear
Is there any place that sellscthe pre cat delete pipes or do you have to make your own?
Old Jul 16, 2018 | 01:25 PM
losiglow's Avatar
RV6 manufactures them:
https://www.rv6-p.com/v3pcd-223.html
They come highly recommended around here. I've purchased jpipes and their high-flow cats for both my 3G and 4G TL and have been very happy with their products.
Edit: it looks like they're on backorder however. States a lead time of 4-6 weeks. Their products are often in high demand so they're occasionally on backorder. They do most of their fabrication in house. My HFPC's were on backorder when I purchased them for my 4G. It took about 3 weeks before I got them.
Old Jul 16, 2018 | 02:19 PM
Glassman's Avatar
9th Gear
Thanks for the info but i need them like now for my dirt track car. Only 6 weeks left in season. My cat is bad and melting coil packs.
vletnguyen
Aug 10, 2021 10:09 AM
nvidiaclocker
Feb 2, 2017 10:10 AM
6SpeedTL
Jul 17, 2015 11:24 AM
Damian0216
Mar 13, 2012 01:46 PM
Caiman
Feb 26, 2011 12:29 AM
