Swap Success j32a3 into j304a
My 05 Accord EX-L threw a rod, so I figured I should upgrade. Runs great!! Put in engine from an 06 TL w\ 157k mi. Everything lined up perfect. Drop and bolt. Engine was around 700.
The following 2 users liked this post by Mnemonia:
Acura TL Builder (05-08-2022),
Scottwax (02-09-2021)
Mnemonia (09-10-2022)
Oil leak is one way; however, this $25 seal replacement is one of those things you consider 'while there' when doing a swap, especially if the new used motor has over 100K.
Good Luck!
Try driveaccord.net Accord forums. There is a guy over there with a 06 6-speed with over 730k miles , so I find it hard to believe that you throw a rod with just 157k miles on the original engine. Sounds like neglect to me.
Edit: keep in mind I'm a newbie. However none of my peers who know about cars have ever heard of this happening before. My car "fuellocked" for lack of a better term. I am privileged to drive two j32's now
a pesky fuel injector malfunctioned, got caught with the nozzle in the on position and started flooding cylinder 2 with fuel.i came out and started it and knew I was fucked Instantly. There were pieces of my engine on the driveway. I took the plenum off and in was filled to the brim with fuel. The bad fuel injector FUCKING locked a cylinder. I came to find to chunks blown threw both sides of the engine
Mnemonia (05-08-2022)
UPDATE: Losing compression and knocking but still runs alright.
P.S. I do not fault the OEM injectors for failing, I had been taking them out and putting them in a bunch and mixing them up with old injectors maybe.
Yes. It always ticked and had poor compression(new engine) but is getting worse now. I wonder if I just got a bad used engine, or an oversight.
Still Running. No engine work done since swap
Biggie_B
01-18-2021 09:53 PM
