Slight Problem with intake install....
Old 07-09-2007 | 09:34 PM
alpswd's Avatar
I just finished installing my aem intake. When I first started the car, it was idling very roughly and nearly stalling. So, I opened the hood and took a look and saw that I had forgot to reconnect the sensor near the the throttle body (O2 sensor?). I reconnected it and everything seems finenow, but my check engine light remains lit. Is it safe to assume everything is OK? If so, how do I clear the light?
Old 07-09-2007 | 10:03 PM
TLFourplay's Avatar
Disconnect the battery for at least 10 seconds and reconnect. You should do this anyways so that the computer will re-learn the intake ratio adn stuff with the intake installed for the best performance gains. Will also clear the code.
cycdaniel
12-17-2019 10:58 AM
marcelft
07-10-2018 06:17 PM
nanos
11-12-2015 08:41 PM
Abe_Froman
09-16-2015 01:27 PM
Mike Bertram
09-10-2015 09:27 AM
Quick Reply: Slight Problem with intake install....
