RV6 V2 Precat Delete
Old Aug 10, 2009 | 03:27 AM
Richie v6's Avatar
Former Sponsor
You guys asked for them and here they are, RV6 V2 Precat deletes. The V2 Precat deletes are made with thicker 2.0mm pipping opposed to 1.2mm in the V1. They also come with angled O2 simulators which are more reliable.
Old Aug 10, 2009 | 03:30 AM
wrxyboy's Avatar
1st TL-S on air in
Wow this looks like real top quality. If i didnt already have your V1 i would defiantly buy this. Keep it up Richie.
Old Aug 10, 2009 | 10:33 AM
eh? spec's Avatar
Cruising in my
What does making the pre-cats out of thicker pipe change? (make them more durable or something?)
nice product!
Old Aug 10, 2009 | 11:54 AM
erickim730's Avatar
might be a stupid questions but what are the gains looking like for this?
Old Aug 10, 2009 | 02:44 PM
Inaccurate's Avatar
Richie,
On your website, the product description for these V2 Precat Deletes has the following text -
Originally Posted by www.r-.ecrater.com
Do not use with incomplete innovative mount kit will lead to failure.
What does this mean?
Old Aug 10, 2009 | 06:37 PM
04accordcpe's Avatar
347hp/300tq @ 4psi
Originally Posted by Inaccurate
Richie,
my guess is when people mix and match the innovative mounts with the stock units. example, front innovative mount with rear stock mount or visa/versa.
richie, glad your using thicker material now. i recently had to weld my rear V1 precat around the flange and hoping it holds up ok :/
Old Aug 10, 2009 | 09:32 PM
Inaccurate's Avatar
Richie and 04accordcpe,
Right. I quessed that much myself. But, I would still like to hear the whole story (and history) from Richie behind that statement. THANKS
Old Aug 11, 2009 | 03:57 AM
Richie v6's Avatar
Former Sponsor
nice product!
Yes they are more durable the thicker metal allows for deeper penetrating welds.
It all depends on your exhaust setup but the precat deletes should be used with a Jpipe. On my 3.0 V6 Accord MT gained 15HPW/7WTQ using precat deletes, V1 Jpipe, test pipe and Tanabe exhaust.
Richie,
There were a few people that installed 3 or the 4 innovated mounts. Skipping the rear mount since it was a difficult install. They snapped a couple of precat deletes before realizing the problem.
Let me know how it holds up I got some repaired used ones for exchange.
Old Aug 11, 2009 | 09:30 AM
Sonnick's Avatar
All motor
Richie nice improvement. id expect the gains to remain the same. richie that dyno isnt accurate since it was 2 diff cars n dynos. cubanob on v6 p got 25whp gain with just the PCs and 3" exhaust with oem jpipe which is more like it. The PCs themselves should be 10-12whp. I cant wait to get a set!
Old Aug 11, 2009 | 10:42 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
dyno smyno.. we already know these things make power... the debate should be on the amount of power... to this day no ones taken the time out to do a pre install dyno with a post install dyno same day
Old Aug 11, 2009 | 08:35 PM
greco9885's Avatar
+25whp gained from aem v2, underdrive pulley, rv6 pre cat deletes, j pipe, race pipe, evo2's
thats the real numbers. 1 day later, same conditions
Old Aug 12, 2009 | 12:07 AM
bballislife010's Avatar
BDN
richie. pm me a price shipped to 77418. thanks buddy!!!
Old Aug 12, 2009 | 01:01 AM
94 DC4 RS LSV/Turbo
go to rv6-p.com to order
Old Aug 12, 2009 | 07:00 AM
gerzand's Avatar
Did you have an aftermarket exhaust at the time?
Old Aug 12, 2009 | 08:32 AM
alexSU's Avatar
Under construction
evo2 is the greddy exhaust
Old Aug 12, 2009 | 09:37 AM
gerzand's Avatar
oops! haha ... blind!
Old Aug 12, 2009 | 10:19 AM
alexSU's Avatar
Under construction
^ its all good lol
wow, looks like all your missing are the pre-cats. from what i've read they will give you a good bump in power so go for it
Old Aug 12, 2009 | 10:26 AM
gerzand's Avatar
^ its all good lol
Oh believe me, ive been waiting what seems like a lifetime to get my hands on a set. I had an older set which were faulted. Cant wait to get the v2's on! Richie should be shipping pretty soon haha
Old Aug 12, 2009 | 01:31 PM
alexSU's Avatar
Under construction
post up your results and feedback. ill definitely be getting these along with the j-pipe
Old Aug 12, 2009 | 06:43 PM
Richie v6's Avatar
Former Sponsor
Quick question are you running the precat deletes with the V2 ATLP jpipe? I have a customer that says it shifts the whole jpipe over.
Old Aug 20, 2009 | 04:53 PM
craigtl35's Avatar
the motor mount question is the only thing holding me back from purchase i had my ccard ready to go b4 that comment, i have stock motor mounts currently and would like to keep them bc i cannot afford to have my motor lifted to put the rear mount in at this moment is this going to be a problem for me? or is it just if u have 3/4 of the mounts? i know you have semi answered this question i just want to b one hundred percent sure, i hope i am being clear
Old Aug 21, 2009 | 02:38 AM
Richie v6's Avatar
Former Sponsor
Stock mounts are fine and the innovative mounts and fine as well. Just dont combine the 2.
Old Aug 21, 2009 | 03:45 AM
347hp/300tq @ 4psi
yes it does ever so slightly. i simply grinded down the damper underneath the k frame a bit and it fit right in with plenty of clearance
glad you chose to make these things stronger richie, cause these PCD's are probably the BEST "bang for the buck" exhaust mod you can do for these cars. BTW, did you say you have some repaired V1 deletes that you can trade for a defective one? cause my rear one cracked and i patched it with a small weld for now to get me by.
Old Aug 24, 2009 | 11:42 PM
BLACKURA_NY's Avatar
I have car ADD
Hey i did a pre-post dyno... just not on the "same day"
I gained like 20whp, and like 15wtq from just installing those on my Type-S (on top of all my other mods)
Old Aug 25, 2009 | 10:55 AM
rodneyc77's Avatar
Retired!!! ON TOP!!!
I was going to wait to go Turbo... but i think I might get a set of these and Official start my Engine MOD journey... I'm still thinking about doing engine mod though.... let's see what I do...
Old Aug 25, 2009 | 12:20 PM
CJ0920's Avatar
Is is raspy with the evo's? I've been debating FOREVER, just scared of that raspyness sound that will possibly come out. I'm running k&n, pulley, xlr8 jpipe, rv6 res cat, and evo2's. Did it make more or less drone inside?
Old Aug 25, 2009 | 02:25 PM
Rick_TL-S's Avatar
Inspection time's getting very close, so I may have to wait & pick these up as a Christmas present.
Old Aug 25, 2009 | 07:53 PM
Escobar7's Avatar
i had a set up of RV6 pre cats, ATLP jpipe, ATLP race pipe n greddy catback= RASPY+DRONE!!!! i didnt like it one bit, dont get me wrong perfomance was very nice it would make my wheels spin at times very nice its all up to what u want and like it was just too loud for me so i sold the greddy and put the stock exhaust back on, planning on getting a Tanabe. my
Old Aug 25, 2009 | 10:34 PM
Inaccurate's Avatar
Escobar7,
When you say that you "put the stock exhaust back on", do you mean
Precat Deletes --> ATLP Jpipe --> Race pipe --> OEM cataback
If so, did the oem catback (with oem resonator) eliminate the rasp?
Old Aug 25, 2009 | 11:21 PM
94 DC4 RS LSV/Turbo
stock exhaust with these you dont hear anything... its literally nothing not even 1peep.... literally sounds stock
Old Aug 26, 2009 | 11:51 AM
AcPimpin's Avatar
Leather so soft.
i dunno al.....i just got these on with everything else stock...jpipe 3rd cat reso...ohh yea i did take off mid muff...maybe that cud be the sound..
but it sounds like air going thru a wide hallway if that makes anysense.... this happens at high rpm.
Old Aug 29, 2009 | 11:25 PM
NBPacuraTL's Avatar
Herro
Are 1 of the deletes suppose to have a bend in them? Guessing for clearance issues?
Old Aug 29, 2009 | 11:35 PM
94 DC4 RS LSV/Turbo
^ yea if you look at the rear cat... it has the bend also... its more like an angle than a bend... its to clear the rear frame... its normal and is supposed to be like that...
Old Aug 29, 2009 | 11:39 PM
NBPacuraTL's Avatar
Herro
Umph! Thanks. and I just read the papers that went with it and it also says that haha. Thanks Richie for the parts! Can't wait to install it.
Old Aug 30, 2009 | 02:14 AM
Inaccurate's Avatar
I got my deletes installed this weekend. One word... WOW !
The craftsmanship and fit.... WOW!
The sound at idle... WOW!
The sound at wot.... WOW!
The power.... WOW!
Thank you Richie for bringing these to the market!
I was scared to start the car for the first time. I was just gritting my teeth for what I might hear (too loud). I turned the key..... Growl, burble, burble, burble. I got a huge ass grin. "Damn, that sounds identical to a G35 coupe!". Not too loud, just perfect.
Goose the throttle..... again "Damn, that sounds identical to a G35 coupe!". Not too loud, just perfect.
Wot thru 1st gear = Someone else (I forgot who) phrased it well. If I was the other driver trying to race me and I heard that TL, I would roll-up my windows and shift into high gear quick. :surrender ...LOL !!
For reference, my setup is =
Precat Deletes --> XLR8 Jpipe --> RV6 Race pipe --> OEM catback(with midmuffler delete)
I AM EXTREMELY HAPPY WITH THESE DELETES !!!
"What's that smell?.... Smells like Victory !
The smell is beautiful. This is *not* a raw unburnt fuel smell. This is*not* a rotten egg smell. This is the smell of a healthy engine. It smells like my motorcycle smelled.. a big ass 1100cc Superbike. "I love the smell of exhaust in the morning".
BTW, many folks that install the deletes think that they have an exhaust leak. That is *no* leak. That is how tube headers sound. I have had real tube headers on my small block chevy motor. And the precat deletes sound just the way that I would expect. Guys, that is no leak. It is the way it is suppose to sound.
Did I mention that I AM EXTREMELY HAPPY WITH THESE DELETES !!!
Old Aug 30, 2009 | 02:54 AM
JwongTLS's Avatar
Can't wait to get mine..
Old Aug 30, 2009 | 03:31 AM
greco9885's Avatar
inaccurate. IMO precats delete are a must for any person with performance in their mind.
and another plus is u saved a few lbs i assume right? maybe 2-3?
Old Aug 30, 2009 | 09:01 PM
Inaccurate's Avatar
Cats Vs. deletes = 12 Lbs reduction
Deletes, race pipe, misc brackets and heat shields deleted = 14 Lbs reduction
Old Aug 30, 2009 | 09:54 PM
ABP_04TL's Avatar
6-SPEED LOVER
hmmmmm
<------- PreCats? wat ya think? would this b a good mod for my car? i have RV6 Jpipe,Test Pipe, XLR8 Res Exhaust, MDX IM Spacer.... need help dont kno wat 2 do
Old Aug 30, 2009 | 10:46 PM
Inaccurate's Avatar
Do two searches within the Performance subforum for the word "delete" and "deletes". Many good threads that will guide your decision. This is how I research the deletes before purchasing mine.
