Running lean
Old May 9, 2013 | 04:56 PM
Brennan8's Avatar
Running lean
Soon I will have the rest of my rv6 exaust and will have a system pcd jpipe and catback now thos who have all of that are any of you running lean if so what are you upgrading your fule system with ? Thanks
Old May 9, 2013 | 06:37 PM
DomGSR-T's Avatar
Don't worry about that, you will still be too rich even with the new parts
Old May 9, 2013 | 08:10 PM
anx1300c's Avatar
Huh?
Lots of people are running lean. OP, you can tune A/F ratio with Hondata if your car is an '07-08. You won't really know where you stand until you do what you want to do and then check your A/F with a wideband.
Old May 9, 2013 | 08:18 PM
EvilVirus's Avatar
^ plus one
Old May 9, 2013 | 08:40 PM
I hate cars's Avatar
Has anyone actually measured a change in AF before and after. Exhaust mods are increasing efficiency but there's very little change in actual intake volume from just exhaust and practically zero change at part throttle.
I'm not doubting that some people might be running lean but I'm wondering if the car is designed to run a little lean. Going from a bad memory I remember most dyno charts showing a pretty rich mixture in vtec.
The wideband 02 sensors should have no problem correcting for the tiny difference in airflow from exhaust.
Old May 9, 2013 | 09:01 PM
anx1300c's Avatar
I think with just full exhaust mods, most people are fine, but when doing the larger TB/porting or TB/SHAWD manifold, larger intakes is where they start to lean out a bit more. Not dangerously lean, but I think Sonnick pops CEL's that indicate a lean condition from time to time. Not sure if there are codes for individual cylinders or just banks. Could just be a coincidence; could be something else. I doubt anyone is going to damage their engine with bolt ons though. Leaner is meaner anyway.
Old May 9, 2013 | 09:05 PM
That's interesting. I know if the correction is too great it will throw a code but I'm wondering if the BLM is actually running out of range.
Old May 10, 2013 | 09:11 AM
Brennan8's Avatar
aem a/f ratio anyone have that in there tl
Old May 10, 2013 | 03:21 PM
AccordFlex's Avatar
I have full bolt ons with 3.7L mani, ZDX TB, and PnP runners and the car is running very rich. The car does do a pretty good job correcting these issues with bolt on but it still has its quirks. Im in the 12's for A/F but the Hondata I purchased should correct this issue.
Old May 10, 2013 | 03:43 PM
Sonnick's Avatar
All motor
Yea my CEL comes on intermittently, but my tail pipes are still black. There is soot on my bumper as well. Had the car washed for the track and the next day my bumper already had some buildup.
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
hrothgar02
Nov 2, 2015 01:29 PM
ExcelerateRep
Sponsored Sales & Group Buys
Sep 22, 2015 10:39 AM
