Rotora???
Rotora???
i'm thinking to change my stock rotors for drilled/slotted rotors, but couldn't find anyone is selling a really good brand like Brembo, i know many ppl here are using Rotora's, but is it really worth it? cuz i've heard its made in China... anyone got good/bad experience about Rotora? or any other good brand suggestion? thanks.
azine sponsoring vendor Excelerate carries brembo and Rotora
If you do basic driving, blank rotors are fine
If you do some repeated heavy use of the brakes like in the mountains, slotted are good because they give the expanding hot pad gasses an escape path.
If you autocross race, live in torrential downpour rain areas, then crossdrilled would be a bonus. They have advantage in those situations, otherwise they are just costly and look cool
Whats your budget?- really good front rotors and pads designed to work with those rotors are about $350
Basic stuff, you can find rotors for 50 bucks and pads for the same, but they wont last as long and may have a greater tendancy to warp under heat stress
Centric is another good brand mid priced brand- so is Stoptech, same company iirc
check the Off Topic link- Sponsored Sales threads for post by Excelerate and MrHeelToe for brake packages
many ziners are running rotora- I didnt realize you has a 6 speed car, that totally changes whats available down to - not very much
RacingBrake has the awesome 2 piece rotor- pay more now but when it eventually needs a new rotor ring- it unbolts from the hub and a new one bolts on- about 175 per ring iirc-- but they dont make a 1 piece normal style rotor
Their rotor ring should last 3 sets of pads before replacement based on their other rotors wear so far
Rotora makes a 1 piece, normal type- slotted, or solid/blank rotor, that is good quality and in use by many ziners- those are the 2 most popular for p[erformance oriented drivers.
You did not mention race type use, so ceramic pads will give the least dust but lesser braking abilty
or the semi met pads will give more bite with resultant dust
Wax the rims with synthetic car wax to cut down on that problem~
94 DC4 RS LSV/Turbo
so many choices but racingbrake are def the best out, there is also stoptech (identical to rotora)... brembo's website also has part #'s for their slotted or drilled replacement rotors
when you search, forget that you have a type s, search via a 04-06 6speed, otherwise you'll be wasting your time
Former Sponsor
It depends on what you're looking for. Upgraded rotors, a good set of pads like Hawk Ceramics or ROTORA ceramics, SS brake lines and some MOTUL DOT 5.1 will get you much improved braking. A ROTORA BBK will improve braking even further and also be much more resistant to brake fade and warping due to the larger diameter of the disc, curved vanes, 4 piston caliper, etc
In Search Of Sunrise....
^^ Excelerate, Just a heads up, I'm going to be hitting you up soon for a set of F/R drilled and slotted rotoras & pads.
71K on factory rotors/pads.. trying to hold out for as long as I possibly can!!!
Matter of fact I just made that same order pretty much.. combo Rotora rotors, rotora pads, SS brake lines, 5.1 brake fluid. Thanks again Excelerate! Cant wait to get my car out of its 15 month storage and get this stuff on!!
Former Sponsor
The Racingbrakes cost more because they are really good quality, harder material, and higher performance. They pay off in the long run. The rotoras may be better than stock, but not significantly as far as we have seen. We are not seeing major longevity or performance differences between any conventional 1-piece rotors.
Former Sponsor
Now I would have to agree a 2 pc disc will definitely be a better setup but what's the point of a 2 pc disc with inefficient 1 piston calipers on the base TL? You would want to upgrade that disc with something like the ROTORA mini 4 piston caliper setup that works with OE discs.
If you're not tracking this car and it's just a daily driver, generic rotors will be fine. I would never recommend spending the extra $$ on RB or Rotura in this case.
^^^Yes it is. You can buy generic rotors from one of many sources and they'll perform just fine for a daily driver. As an example, the bmw guys over at the M3 forum did a group buy from brakeplanet.com for generic oem replacement rotors and they are very pleased with the rotors.
Former Sponsor
However, my original response to your initial statement is still true:
You don't need a track car to get slotted rotors. There are many street cars/ daily driven cars that require an upgrade from stock b/c the stock blanks and stock pads just can't keep up the with the customer's need for better braking.
to clarify my statements and understandings-and often misunderstanding- I have not been keeping up with brake parts availabilty per model recently, and things have changed
RB rotors- no one here has enough miles on the rotors to know how long they will really last.
Marcus experience is 3 sets of hawk pads and still going strong on test vehicle on same RB 1 piece rotors- last I heard
I believe discussion of 2 piece rotors is limited to the 6 speed Brembo brake gen3 TL
-for this thread, Im with josh on this- better calipers before worry about anything big
on the rotors
if you are gen2 with single piston calipers- in which case get 1995 Legend LS-C dual (same side) pistons- beats stock for 75$ each, but its not 700 or 1200
After you have attended several days and have been moved up to the advanced group at High Performace school/race-track days- then you need to think about badazz braking upgrades
IMO:
1 piece rotors are fine for most drivers- slotted rotors offer many advatages to even the person who thinks they are not hard on brakes- but they really are--doing many sudden slow downs with ~efforted braking~ that quickly raises the pad temps- causing release of gasses in pad, which the pressure of the EXPANDING HOT GASSES,,, can physically overpower the pedal hydraulic pressure effort, and PUSH the pads AWAY from the rotor- while your foot is still on the brake pedal hard!
Not a very comforting feel at the bottem of a steep hill and sudden need for brakes...then a semi decides to back out of a driveway....and you need more brakes
A main purpose of side slots is to give the gasses an escape route as the rotor turns.
It also keeps the pads clean of minor debris that likes to stick to them when hot
Each maker has their own idea of which way the slots should run, but the intent is the same.
On the RB 2 piece I was going on what I heard a year ago-
If the new info is they can go 3 sets of pads then be resurfaced then keep going- I am truely impressed! and really happy with my purchase!!
My 1 piece are looking good after a year+, some good pad wear on ET300s, but the rotors look nearly new. Next time will try ET500s
Lets see if the rotors go 3 sets then resurface- that will rock!!
on the rotors
IMO:
Excelerate
Sponsored Sales & Group Buys
664
08-04-2011 09:22 AM
