RL cams, who's running them?
#162
Found Bisi Camshaft duration and lift again. Max lift is 0.415″ on the intake and 0.423″exh. Still not too bad. 300 CFM intake and 200CFM exhaust.
see below
Level 1 All Motor: Offers a 10% improvement in power over factory, emissions friendly, stock-like idle, with emphasis on the 1500 to 5800 rpm range. Takes 7-10 business days to manufacture, after stock cam cores are received. 0.394″ valve lift on the intake and 0.395″exh; 246 and 234 deg duration on intake and exhaust at 0.050″, respectively.
Level 2 All Motor: Offers a 15% improvement in power over factory, slightly lopey idle, with emphasis on the 2000 to 6200 rpm range. Takes 7-10 business days to manufacture, after stock cam cores are received. 0.415″ valve lift on the intake and 0.423″exh; 255 and 236 deg duration on intake and exhaust at 0.050″, respectively.
see below
FamilyGuy (05-03-2015)
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
