Richie V-6 Products
Richie V-6 Products
hello all ![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
i'm sure there's a thread around already having reviewed richie's products, but in the end, i felt obligated to post separately; i ran into quite a few problems, and long story short, richie aided me in fixing/finishing all of them (plus Ale: ))!
a few months back, i purchased the j-pipe, race pipe, and pre-cat deletes (used) from stillhere153 - thanks ale! installed a few weeks later (richie sent me brand new pre-cats); i would have installed sooner if i had the confidence to do so. despite, the install took 2 nights, unfortunately because our "team" got stuck on a stupid bolt that just WOULD NOT come off on the rear cat. overall the install was fairly straight forward. initial start up was FRIGHTENING...the car sounded great though! as for the performance...let's just say the power's definitely there. i haven't been able to get any clips, but i'll try to do so SOON. as of recently, i've been pushing the car VERY hard...and the power pushes the car up to higher speeds quite unexpectedly
our spirited runs have been...interesting to say the least. i've had a few encounters with G's, Z's, and other odd ended Subi's and Hondas...i held my ground
unfortunately, lower end torque is lacking...hence my SHOCK at how quickly i went from 65 to...such higher speeds
. Anyways, the power package was worth every penny! Only complaint is the smell, but it's expected...and i seem to be finding more and more ways to work around it...it's all good.
ALSO, Richie's strut bar's some good stuff. I get over-steer! TeehhHhHeeEEeEe! Definitely holds the car down and body roll up front is most certainly decreased. I'm confident...trust me...I beat that shitz and it held on TIGHT! Thank you Richie!!!
![Drag](https://acurazine.com/forums/images/smilies/drag.gif)
I am starting to think the mod is just trading one end of the spectrum's power for the other. What do you guys think? I realize it may be tough to admit something unpleasant after making an investment.
runnin a little boost
It sounds like the mod you made just shifted your power band. I must ask if most of ones driving around is less than 65 MPH (per your comment) then does it make sense to do the mod and accept coming out of the hole slow?
I know the J-pipe, cat back and high flow cats made a huge improvement with the supercharger, but I installed the blower before the exhaust.
94 DC4 RS LSV/Turbo
glad I could help... yea I duno what happend to the precats I had, they were from the first batch, and NYC winter doesn't help much, so there was a hairline crack on the front from what I was told...
and yes I will agree there is a lack of low end... but that is pretty much useless on a car that lives at 6k rpms... I found that downshifting solved low end tq problems... afterall in 1st gear the low end tq being absent prior to 2k rpms kills the oversteer... course at soon as its in 2nd at vtec your chirping tires.... in an auto thats just sick
i'm still down to dyno... probably after i get everything installed. i ordered the P2R package from Excelerate over the weekend. it will be here this coming Friday and I will have it installed shortly.
uh...i'm not an expert, but i believe it's a combination of the pre-cats and the j-pipe. low end torque is created by back pressure...the back pressure is/was created by the bottle necking -> 2.25 to 2.5. someone correct me if i'm wrong, in which i probably am...despite, it's somewhere along those lines. the pre-cats, j-pipe and test pipe are all 2.5 in diameter...hence it's more free-flowing with no bottle necking
Former Sponsor
Former Sponsor
94 DC4 RS LSV/Turbo
dunno the low end balogny is just hearsay I quoted... all I know is when I had my tl-s it was 2.25 at the head, 2.5" to the tail... and um... yea there was that thing about the single exhaust... but when my tl-s was stock... sunny 201 (07 3.2liter) left my ass in dust and he had rv6 full package and an aem intake with greddy evo2 catback... I was pretty much stock (07 3.5 liter after being parted out) minus a lightweight crank pulley
All motor
Yes, but Richie..you're dyno wasn't "corrected." The stock dyno was from another 6MT on another dyno. Also, it dyno'd on the high end for stock @ 215whp. Someone on dyno'd a 10whp gain from just the Comptech exhaust. Every dyno is different, as long as you stay on the same dyno and quote each gain, it's whatever. 1/4 mile times are what counts in terms of power. A 225whp car can be faster than a 250whp car with the right driver
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
So with pre-cat deletes, jpipe and exhaust it only made 4whp until 5K then it made ~16whp? Thats not really impressive I know its on a 3.0 liter so it would yeild more on a 3.5 liter but not anywhere near double. ??
2008 tl-s sleeping in
^is that true, 4" diameter is CRAZY! that thing must be louder than anything ive ever heard and ive heard 3" piping on my prelude i got that changed like 2 days later i couldnt deal with it.
![what](https://acurazine.com/forums/images/smilies/what.gif)
I think the 4" dimension refers to the outside, overall diameter of the 20" long resonator, not the piping diameter. Since the system splits into two 1.75in pipes I would expect the pipe diameter at the resonator is probably between 2.25" and 2.5", but most likely 2.5". The final outlet tips are 4" though.
Unfortunately, Borla does not offer the cat back system for TL owners.
I am very satisfied with the fit and finish of the pipes. The T409 SS allows the pipes to reveal a mirror like finish after polishing them, where the competitor's are using inferior metal and are dull.
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
Too bad we cannot convince Borla to make a system for the TLs.
I wonder why our vendors don't match the Borla warranty of a million miles.
The 12 HP gain is pretty impressive for a mild sounding exhaust system.
I think if anyone commits to that type of warranty they must feel pretty strong about their product. Who else is willing to take on that type of risk?
borla? what are we driving SUVS? LOL....
anyway, i gotta be complete honest here, i lost low end torque with richies v1 j pipe, and i gained it back with the atlp. BUT while looking at richies v2 j pipe, it sure does look ALOT better than the v1. it definitely is going to flow alot better than the v1, but time will tell!
practicing nihilist
^i'm glad i will get that low end back with an exhaust, and i'm even more stoked that ATLP came out with a design I like.
so, do you think the V1 just has a top heavy torque curve, or, does it simply produce less than the others?
practicing nihilist
joflewbyu2
08-18-2019 10:38 PM
Pham Alvan
03-16-2016 09:17 AM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
