Replacing J-Pipe with Test Pipe
Old Feb 15, 2011 | 12:13 PM
vtec22's Avatar
Hello guy's, my stock J-Pipe is bent and it is not in a good shape I need to replace it very soon. I was thinking of getting XLR8 J-Pipe with the XLR8 Test Pipe. I know that it'll give me power but I am willing to know how much and will the car sound louder?
One More question, will I pass the Emission Test?
04 Auto/with Navi, Blacked Out SMarker's (White)
Old Feb 15, 2011 | 12:25 PM
Bearcat94's Avatar
AZ Community Team
Depends on the "emissions" test. You won't get any codes/CEL. And a "sniffer" shouldn't notice any difference. BUT a visual inspection might catch you out; it's happened to other members.
Maybe a tad louder. My J-Pipe (ATLP) alone actually reduced a little drone; added the test pipe (ATLP) and got the little bit of drone back; I've got the hacked stock exhaust, no mid-muffler, after market resonator.
I did think the tone was a little lower, a little more growl with the J-Pipe.
I've had no issues passing inspection (visual) twice. BUT I did put the stock heat sheilds back on over top of the test pipe.
Old Feb 15, 2011 | 01:54 PM
vtec22's Avatar
That is the sound that I am looking for.
So what your saying is if the Mechanic pick's up the car and sees that there is no 3rd Cat, he will tell me I cannot pass the inspection? If that's the case, my mechanic does not do that as long the Machine read's it normally and no Codes are shown it will pass right?!
I am assuming that I will get 10WHP to the wheels with the J-Pipe and the Test Pipe?
Old Feb 15, 2011 | 01:57 PM
SharksBreath's Avatar
BANNED
it is highly unlikely that the emissions tech will look under your car.
i just got mine done and it took all of 25 seconds, literally.
you're fine man, enjoy the extra power!
Old Feb 15, 2011 | 02:09 PM
vtec22's Avatar
Thank You guy's very much!
Future Mods: Roof Spoiler (Satin Silver)
!8" x 8.5 ADR Rims
Falken Azenis ST-115
Modded Heads & Tails
Koni Shocks (Yellow)
H&R Springs
A-Spec Body Kit
Old Feb 15, 2011 | 02:14 PM
BANNED
sounds like a solid plan!
Old Feb 15, 2011 | 02:28 PM
Bearcat94's Avatar
AZ Community Team
Depends on the state and place you get the inspection. NC says the tech is supposed to visually inspect that the emissions equipment hasn't been tampered with or removed.
If the car doesn't throw a code, will the tech still have a look? Who knows?
Other states may just have a ODBII port scan and/or an exhaust sniff and if there's no issues, it passes.
Here's one local that got caught out: https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/remove-third-cat-%3D-failed-inspection-758857/
Not to scare the OP off the mod. 95% of the time, you probabely won't have any trouble.
Old Feb 15, 2011 | 02:33 PM
BANNED
^that is a good point. it is state dependent.
OP, where do you reside?
Old Feb 15, 2011 | 02:49 PM
Excelerate's Avatar
Former Sponsor
The j-pipe doesn't alter emissions. The test pipe does delete a cat, the third cat, but it is not a monitored cat. So in most areas, it shouldn't create an issue. Even if it did, keep the original cat and reinstall for emissions purposes. It will only take 30 minutes or so and it will bolt up to our XLR8 J-pipe.
Old Feb 15, 2011 | 03:04 PM
vtec22's Avatar
If you are asking me, I am from Brooklyn NY :wink:.
My mechanic never looks under the car! He just connects the computer to my car and that's it.
Will the Excelerate J-Pipe and the TP fit and connect without any issues to my stock exhaust and everything? The only slight little problem that I have is that it is pretty rusted there, hopefully there won't be any issue. I will let my Mechanic bolt them on.
Old Feb 15, 2011 | 03:24 PM
vtec22's Avatar
Hey guy's I got 1 question about Rims. I need to buy 3 new Rims because my other one's are beat up (potholes). My front tires are 235/40/18 and my rear are 255/35/18. What size of the Rims I need to get, 18 x 8, 18 x 8.5, 18 x 9.0 or 18 x 9.5? For the Front and Rear. I would appreciate for a reply to this because I am not really sure.
Thank You!
Old Feb 16, 2011 | 02:15 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
I'd rather go to a wheels shop to get them fixed instead of replacing them.
Depends on the make and model of your car and what kind of wheel.
Old Feb 16, 2011 | 01:07 PM
vtec22's Avatar
ADR M SPORT (black). 18"
There is no way of fixing them 1 is chipped around (when I bought the car ) the other front right I hit a big pothole, and the last one is scratched.
Old Feb 16, 2011 | 01:18 PM
BANNED
sure there is. google wheel repair in your area.
can be fixed.
can be fixed. (pending actual damage)
can be fixed.
see bold.
Old Feb 16, 2011 | 01:30 PM
vtec22's Avatar
I'm afraid that the shop will charge me more than $200 and there won't be any point of fixing them if I can buy 3 Rims for 400 brand new.
I mean another 2 bills and get them N
EW why not?
Old Feb 16, 2011 | 01:36 PM
BANNED
sorry, wasn't aware that you could get the 3 wheels for $400 new.
compare prices at wheel repair shop VS new wheels. the one in my area does them for $75 a wheel.
Old Feb 16, 2011 | 04:20 PM
vtec22's Avatar
That's not bad as long it looks good as new!
Yes, I will price everything up but I think Ill get the new one's :-P
Old Feb 16, 2011 | 08:08 PM
Excelerate's Avatar
Former Sponsor
Yes it is a direct bolt on.
Old Feb 19, 2011 | 04:33 PM
vtec22's Avatar
I was thinking of getting AEM V2 CAI, XLR-8 J-Pipe, RV-6 PCD. Am I going to get like 20 to the wheels?
One of my buddies said I won't beat him with his G37 Auto... Any suggetions?
Old Feb 19, 2011 | 05:43 PM
thisaznboi88's Avatar
in CA they put the car on a lift and check the CATs. But it should not throw a CEL like everyone said.
Old Feb 19, 2011 | 05:50 PM
Bearcat94's Avatar
AZ Community Team
20 sounds ballpark. Your exhaust will play a role in whether you get max gains or not.
Old Feb 21, 2011 | 03:19 PM
illmatic tl's Avatar
6th Gear
sounds good keep us updated
mada51589
Jan 9, 2025 04:40 PM
acurajj
Feb 14, 2016 02:28 PM
ibGTV
Sep 28, 2015 03:40 AM
Phambam12
Sep 6, 2015 06:57 PM
Mikehxbx
Aug 31, 2015 10:17 PM
