Replacing air filter.
Hi all, I'm trying to replace my OEM air filter with a K and N 33-2299 filter for my 04 TL. Problem is I can't unscrew the filter housing with a regular screwdriver and that's all I have. The dealership was supposed to replace the filter at 30,000 miles, but by the looks of the way these 4 screws are stuck in there I don't think this thing has ever been touched. I don't want to start stripping the threading for the srewdriver. Is there anything I can do to make these things come off easier? Anyone else have this problem? Thanks in advance.
P.S. Sorry if this has already been adressed but I couldn't find any DIY's on changing the air filter.
Use a socket - one of the smaller sizes (I forget which size) attached to a screwdriver's replaceable tip. That's what I used. Get a longer screwdriver specially when the engine is hot because you can burn your fingers in there if you're not careful.
Just my $0.02
Just my $0.02
Got a a rachet that would fit it with an extension thanks! Howcome there is no DIY on the forums for the engine air filter? I did the cabin and it was much easier than this. Or is this supposed to be even more basic? If there is one and someone has a link please share it as I'll bookmark that for life.
Originally Posted by xkegsx
Got a a rachet that would fit it with an extension thanks! Howcome there is no DIY on the forums for the engine air filter? I did the cabin and it was much easier than this. Or is this supposed to be even more basic? If there is one and someone has a link please share it as I'll bookmark that for life. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
F-129: DIY: Replacing Engine Air Filter
https://acurazine.com/forums/showthread.php?p=1159175
I'm looking to replace the OEM filter also, but will the k&n filter better? i know it gives more hp but does it waste more gas? where a good place to order the k&n and the cabin air filter?
thanks
thanks
cycdaniel
12-17-2019 10:58 AM
