Rear mount turbo - Type S
Old 12-01-2014, 07:43 PM
  #41
thisaznboi88's Avatar
godspeed turbo from ebay YO!
Old 12-01-2014, 08:02 PM
  #42
KN_TL's Avatar
Originally Posted by maddogtheta
The TL is my daily driver. I'm shooting for the 400-450whp mark. I believe I remember reading in a previous turbo thread that the stock torque converter had problems with getting any power beyond 450 to the wheels.
I did research an aftermarket torque converter through level 10, but if I'm going to upgrade the torque converter for more hp, I think I have to upgrade the transmission and engine internals.
That'll have to be a project for another time (or when my engine blows up...) but it would be fun to go for some big turbo numbers at some point.
Libert69 had an upgraded converter but the clutches internally were the issue with holding power. Not sure if there were aftermarket packs or if they tried increasing pressures, but he ended up swapping to 6MT.
Old 12-01-2014, 08:58 PM
  #43
maddogtheta's Avatar
That's what it was, I didn't remember if he had upgraded his torque converter. I thought I remembered seeing another member here with a Type S that had the same issues after around 450 whp. Level 10 offers an upgraded transmission as well. I wonder if that would help with getting over 450 whp to the wheels.
Old 12-02-2014, 02:41 AM
  #44
SilverSurfer101's Avatar
Looking forward to seeing it finished! Good luck with the install!
Old 12-02-2014, 06:48 AM
  #45
6spd-GERCO's Avatar
KN_TL correct me if I'm wrong, but I thought Libert69 was a 04 auto trans then swapped to a 6MT. I would think with the revisions of the auto trans in 07-08 models (OP is a Type-S) would be more robust relative to the 04-06 auto trans.
Old 12-02-2014, 07:41 AM
  #46
UTAH TSX's Avatar
Lets all join hands and say a prayer for our automatic transmissions LOL , Ive been putting over 450 whp to my automatic for over a year and all it has is a big ass cooler been holding up so far, the type-s transmission is like the odyssey transmission and they are pretty tough Iv'e only seen a few go bad at very high mileage with no service history and black fluid, so I'm confident that these will hold some power
maddogtheta (12-02-2014)
Old 12-02-2014, 09:14 AM
  #47
UTAH Type-S's Avatar
Your transmission has held up but didnt you have to replace an axle
Old 12-02-2014, 10:23 AM
  #48
UTAH TSX's Avatar
that's a different story, wheel spin at 65 MPH and hook up kills those quickly
Old 12-02-2014, 11:14 AM
  #49
good to hear about the transmissions being reliable, I've switched to redline sythetic ATF fluid. Do you think I need a bigger transmission cooler or is the stock one sufficient?
Old 12-02-2014, 12:44 PM
  #50
6spd-GERCO's Avatar
Lol your auto transmissions are in my prayers!
Old 12-02-2014, 01:32 PM
  #51
UTAH TSX's Avatar
Go bigger for sure like rv size
Old 12-02-2014, 02:17 PM
  #52
I figured as much, I'll make sure to get a bigger one. Any recommendations?
Old 12-02-2014, 05:34 PM
  #53
UTAH TSX's Avatar
My kid has the part number for the one we used he will post it up it fit perfect and it is big
Old 12-02-2014, 06:39 PM
  #54
Tru Cool Max 30 000 GVW LPD 49211 Transmission Fluid Oil Cooler RV Towing 4921 1 | eBay
this oily s the one. It fis perfectly. maddogtheta see if you cant get this instslled before they put the intercooler.
Old 12-02-2014, 06:52 PM
  #55
KN_TL's Avatar
You are correct. The 5AT on the later models are definitely different so it is possible that it could hold more power....There are two projects that may test that limit.
Old 12-02-2014, 08:52 PM
  #56
Thanks for the product info. I don't have enough time to order and get it delivered before my install next week, but I'm sure the shop has transmission coolers and now I have a size to ask for.
Old 12-02-2014, 09:25 PM
  #57
take pix pix
Old 12-05-2014, 10:34 AM
  #58
J-series addict
yungone501's Avatar
I run a 2007 TL 5AT on mine and it handles the power fine. I also run Amsoil ATF and a front mounted ATF cooler. The good thing about the ecm on newer models is that it will momentarily close the throttle body during a shift to remove torque during shifts which protects the clutches from damage...especially during those WOT full boost shifts.
UTAH TSX (12-05-2014)
Old 12-05-2014, 11:16 AM
  #59
I had read about the ecm closing the throttle body during shifts, but I could only ever find the press release where it mentioned that it might not close it the whole way, only partially?
How long have you been running the 5AT on boost?
Old 12-06-2014, 12:38 AM
  #60
J-series addict
yungone501's Avatar
'DBW/5AT Co-op' is not something that Honda reports as being done specifically for clutch protection. However, it is reported that this is done to aid in shifting smoothness and speed. Improvements are made in these two areas because when the drivetrain isn't under torque during a gear shift (up or down), the shock is less likely to transfer out and away from the transmission itself. This effectively (and significantly) decreases stress to the transmission internals (specifically the clutches, gears, and main shaft) which is why a DBW system improves its service life as well as vehicle drivability and comfort.
The throttle body doesn't close all the way during co-op. You will normally see between a 50-70% change in TPS graphing during a shift and this goes for the 'throttle blip' feature as well. The variation in percentage all depends on the model and it's programmed gain between the APP and throttle body which is determined by mapping in the ECM. The idea here is to not close the throttle body (as this would create momentary engine braking) but to close the throttle just enough where the motor is between the two points of engine braking and producing torque....a happy place for gear shifts.
I've been running the updated transmission case (2007 and up) now for maybe 2 years now. Mind you, the car is NOT babied and its regularly sees 12-15lbs of boost daily when driven. Honda says the transmission is more compact and much stronger than previous design. It's definitely hard to argue here against that point. My only complaint about the damn thing is trying to hook up during WOT when the wastegates are set to 15lbs of boost. I'm running 10.5" wide street tires and felt I've hit the limits of the car as its sits currently. So, I'm going to stay at a safely tuned 12lbs and enjoy her.
The following 2 users liked this post by yungone501:
maddogtheta (12-06-2014), UTAH TSX (12-06-2014)
Old 12-06-2014, 08:57 PM
  #61
^Thanks for the explanation, I'm even more excited to get boosted! It's going to be tough waiting for the install to get finished.
Old 12-08-2014, 12:14 PM
  #62
Just dropped the TL off! Now the waiting begins. The guys over at the shop were excited to get started on the project and I was promised lots of pictures and updates. They're also running a baseline dyno today. I'll post that info when I get it.
The following 2 users liked this post by maddogtheta:
EvilVirus (12-09-2014), TheBlueBomber (12-08-2014)
Old 12-08-2014, 12:43 PM
  #63
UTAH TSX's Avatar
Ooooooohhhhhhh yeh here we go
Old 12-08-2014, 01:52 PM
  #64
TheBlueBomber's Avatar
Old 12-08-2014, 09:12 PM
  #65
base dyno
Here's the first base dyno. For some reason they couldn't get the torque to read. They are going to figure it out tomorrow. They didn't get to do a run until late because I left my studded winter tires on and I had to run my summer set over.
Old 12-08-2014, 09:21 PM
  #66
6spd-GERCO's Avatar
Whoot! Base lineeee! You have studded winter tires! I am a little jealous!
Would have expected a little more HP for a TL-S auto, but pretty soon you will be well beyond 223 whp .
Old 12-08-2014, 09:27 PM
  #67
Yeah, I was hoping it would be closer to 236, especially since I have pcd's. The TL has 98k miles though and I think engines lose some hp as they age. You're right about being well beyond 223whp and I can't wait!
Old 12-08-2014, 10:31 PM
  #68
Finally a build with a base line!!!
Hope you get 100+ hp. That would put a smile on your face for sure
Old 12-09-2014, 07:25 AM
  #69
6spd-GERCO's Avatar
I made 230 whp with about 120K miles on the clock and now at 133k with the numbers in my signature. These engines age well, maybe it has something to do with the dyno since you only got the HP # on the dynojet?
Old 12-09-2014, 08:36 AM
  #70
screaminz28's Avatar
Unless they did a 'baseline' with the timing maps updated and the knock control tables zeroed out, I'd say go easy +/- 10 - 15 whp depending on how the car acts. I doubt they did that since it was just a pre-mod dyno, so I'd be happy with those numbers for an auto.
I saw you were planning on running 10-12psi of boost, and shooting for 400 - 450 whp. What size is the turbo? I know it's the STS 'china' turbo, but I'd be more concerned about the size than where it is made. If the shop installs it correctly, I think it will last. Looking at the pics though (granted totally subjective since pics don't show much) it 'appears' to be a bit small. I'm sure STS knows how to size turbos better than I do though, especially considering how they have a longer exhaust gas path which cools it somewhat, it's probably intentional.
Good luck with it - I'm excited to see the install and results.
What size injectors did you get? I didn't see that in your thread either.
Old 12-09-2014, 10:21 AM
  #71
Thanks for the info about the dyno. Like you said I don't think they did a lot of zeroing and setting up for a pre-mod dyno. I think they are going to do another pre-mod run to get the torque figured out. I mainly wanted the baseline to see how much whp was gained. Even if the dyno is off some hp, it should be consistent to show the gain in hp.
The turbo is an STS branded GT-35 750hp turbo with a .58 A/R turbine housing. I don't know anything about how to properly size a turbo so I'm relying on the experience of STS to properly size the turbo. The shop I'm having it installed at did not seem concerned that the turbo was too small to reach my goal of around 400 - 450 whp. I hope the combined turboing experience of STS and Speedfactory is enough to know if the turbo is big enough
I went with some bosch motorsport 970cc injectors. They are the same ones that UTAH Type S is using in his turbo build.
Old 12-09-2014, 11:06 AM
  #72
Turbo should be large enough - I wonder if they use that small of an A/R due to distance from engine and cooler air though.
To get a torque reading, they have to be able to pull the tach signal. Sounds like they may be used to doing old school stuff, or maybe just LSx stuff that has plug wires. They should be able to grab an rpm signal off of one of the coil wires.
Its fun watching the local domestic shop here try and dyno Rotarys lol.
Old 12-09-2014, 12:20 PM
  #73
^I was assuming the need for the smaller A/R was because of the distance and cooler air charge. It'll be interesting to see how early the turbo spools up with the small A/R and hopefully it won't hit a wall before redline.
I'm assuming they'll be able to figure it out, they do a lot of honda and acura tuning so I would be surprised if they couldn't get it working. I'm hoping they'll get it working today and get a baseline for torque and then get the turbo installed ASAP
Old 12-09-2014, 12:31 PM
  #74
6spd-GERCO's Avatar
Maddogtheta so happy that you are having speedfactory set this up for you! They seem like a well-established shop with some very good racing experience.
Speedfactory should be used to import stuff search the interwebz
I think your right about the turbine A/R being smaller since this is a remote mount turbo,this will also help with the transient response of the turbo.Very interested to see how this set-up reacts and drives, especially with keeping temps down under the hood which is already an issue for the TL.
maddogtheta (12-09-2014)
Old 12-11-2014, 12:12 AM
  #75
J-series addict
yungone501's Avatar
Wow that's low power for a j35a8, I expected another 15-20hp more AT LEAST from it. Did you dyno with your setup installed and wastegates unsprung?
Old 12-11-2014, 08:20 AM
  #76
It was stock except for the PCD's I have on there.
I got an update yesterday, the turbo is on. Ricky at speedfactory recommended going with a water to air intercooler to keep from having to hack up the front, he was also concerned about the amount of air flow as well. The core for that is supposed to get delivered today.
I'm waiting on some pics from him, but I think I might just go by the shop today and see the progress.
NvrDwn (12-11-2014), thisaznboi88 (12-11-2014)
Old 12-11-2014, 12:35 PM
  #77
J-series addict
yungone501's Avatar
Sorry, for some reason I thought your post was the OPs.
Old 12-11-2014, 12:39 PM
  #78
I am the OP...
Old 12-11-2014, 12:46 PM
  #79
UTAH TSX's Avatar
Dam you will be done before us, this work stuff really messes up my play schedule
Old 12-11-2014, 01:13 PM
  #80
^ That's one plus to paying for the installation, it's their job to get it installed quickly. I'm hoping that it'll be done this week. But I'm betting it will be next week.
Quick Reply: Rear mount turbo - Type S
