REAL 3.5L Superchared :)
#82
The acm is essentially a voltage clamp. If the PCM reads higher than atmospheric pressure it will code. Superchargers will create boost or in other words higher than atmospheric pressure. The ACM locks the max voltage to 2.92 which keeps the computer happy. On the older S/C kits I did I never got an upgraded fuel pump with the kit. Only that cheesy enrichment method of squishing the regulator. Have the added that to the newer kits?
#84
I have thought of that already. It wouldnt be that hard. Since our A/F sensors relay A/F data to the pcm in dc current modifying those signals would be a piece of cake. From a tuning standpoint secondary A/F sensors would be needed to see how the car is really running. I am not sold on devices that modify map sensor voltage IE Apexi NEO. I am not even sure if the PCM reads off the map under WOT. At any rate the PCM would be looking for atmospheric pressure anyway. Since our fuel trims are derived primarily from A/F readings (that I am sure of) any controlled adjustment of those signals will result in direct A/F changes. So good thinking CSMEANCE!
#86
I have car ADD
^ pretty much... i need to get a s/c kit on my type-s and make it work... lol
everybody says the ACM wont work... but.... if its just tapping into 4 wires.. .well, 2 technically , since +12v & ground dont count.... map in/map out.... i should be able to directly bolt the s/c kit onto my car then!!
#87
#88
Now that my car has been wrecked I'm thinking of a project. I've got too many stock turbos laying around here. Only difference is I wouldn't think of screwing with the Acura computer. Going to go with the old Motec I have or an old FAST system and eliminate the stock computer. Just got to find out exactly how much the stock computer is tied into the other systems which I have a bad feeling it's a lot.
#89
I have car ADD
so if i buy a comptech s/c.... and get the wiring pinouts for MAP, and hook up the ACM, it should work ??
from what i recall, comptech said everything hooked up right, but didnt show massive gains ? i am sure it was a stock type-s, so a fully bolted one, should show gains? i am looking to get about 40-50 whp from the kit... then ill be thrilled =)
#91
P.S. If you do end up with that thing on your car I WILL be going with at least 100 shot just in case!!!
#92
I have car ADD
^ 5AT for the lose
nokiaboy was selling a blower, but i slept on it.. now its gone.. i dont wanna buy a new one, just for fear it doesnt work well...
well, the newer 3.2L blowers (UA6) have more than just 4 wires from the ACM...it appears to control MAP, VTEC, and Fuel trim.... (as per Nate @ comptech)
I am currently looking over the installation instructions... and preparing for deployment!!
On a final note.. the main reason that comptech hadnt gone into serious production with this... again, as per Nate
1) RUMOR. they have never bolted one up to the type-s
2) They fear the M62 blower wont provide enough power for the 3.5L displacement. M90 seemed to be on their minds
3) The only mounting point for the blower, is the transmission mount... so, it should bolt right up to our cars and TB with absolutely NO PROBLEMS.
USSI, sorry to jump in your thread so much.. but everytime theres a 3.5L s/c thread, it gets polluted, or nobody with knowledge jumps in.. i like this thread
#94
Seriously, this sounds like it has potential, but as stated earlier the m62 is slightly small even for the 3.2L. Comptech won't necessarily tell you this but one of the main reasons with going with the m62 is just because there isn't that much room in the engine bay! LAME. Obviously other factors come into play as well, $cost$ for a bigger blower, max SAFE power levels, etc, but I mean just for efficiency it makes more sense for a bigger blower. So jumping to a 3.5L with a m62 you will pull less PSI with the same blower. So the % increase in power won't necessarily increase.
Not that this isn't a valid venture bc with some tuning it would be awesome to make more power. Essentially I have a similar motor to the Type-S guys and I'm sure i'll be putting down some solid power once I get my demons sorted out. But tuning wise our cars are extremellllly tricky, these ECU's are just ridiculous, you can't fool them. Even with my car weird things would happen during tuning - there would be ZERO pinging on the dyno, then on the fwy it would ping, so we'd keep pulling timing.
But lets get it on as the first step! I dont remember what pins go in there bc I haven't run the ACM in almost a year. Then we can up the boost and try messing with tuning options..I can't wait to get my car back and running perfect its been soooooo longggg
#95
ECM B+= A4 YELLOW/BLACK IGB+= D6 BLACK/GREEN MAP IN= C5 GREEN/RED MAP REF OUT= C6 YEL/RED GROUND= A1 BLACK. I have it in front of me so if you want Ill scan the pinouts and emailt them to you but there a little tricky to understand.
#96
The AEM FIC does exactly that and works with our WBO2 sensors as well as gives injector control and single settting change for larger injectors to provide good idle, low rpm running, as well as timing retard, but the biggest thing is that it does add two channels of O2 modification.
#97
PS didnt forget about those files. Trying to locate a newer disc to get them from.
#98
I have one major question to ask, Power Rev racing has a J motor in their hatch thats turbo'ed, what tuning are they using????
Also quick edit:
Can't we hook up a j37 ECU to the TL-S's for the extra fuel? Also racinghart, does the SM have the max voltage for the MAP sensor under troubleshooting? If it does what is it? If it's different, nate at CT might be able to reprogram the ACM for the new voltage.
Also blackura_NY mentioned VTEC, Fuel trim and some other wires. Does anyone have install instructions they can send to me, I have a few guys that might be able to help us out...
Also quick edit:
#100
Rev High; Drive Happy
Wish I was in Montreal right now... with a stock type-s and c/t s/c.
We have a dedicated Honda Tuning shop... and they seem very reputable to honda/acura MTLers.
Also--if we were to disengage/remove VTEC completely.... what opportunities would rise up, if any?
#101
Also quick edit:
Also quick edit:
#102
Sounds like this is the way to go over the Emanage. Ill have to do some homework on the unit. Does the FIC have any (or multiple) rpm activated triggers? If it did then you can adjust the vtec engagement points as well. Also does it adjust duty cycle via the PCM or does it do it by connecting a secondary wire to each injector?
The FIC (no I am not a AEM salesman, nor distributer, nor sponsered by them) just like the EMB and EMU intercepts and stands between the ECU and injectors there by allowing full control of the fuel stratagey by being able to fully control injector duty cycle. This of course allows for pulling duty cycle under low demand cases when you change to higher flowing injectors.
#103
Yes it has multiple maps that you can setup so that you can even only trigger VTEC based on RPM X LOAD and not just a stright RPM switch, in other words, why would you really want vtec to always engague at lets say 4500 RPM if you only have the throttle 1/3-1/2 pressed, but at the same point, you might want to engauge VTEC at 3500-4000RPM if you have you foot in the throttle. Honda started implementing this type of startagey to thier stock maps around the 6th gen accord and 2nd gen TL/CL and the implementation has really become noticable in the 3rd gen TL and 7th gen AV6.
#104
One downside so far is that Boomslang does not make an FIC harness for our cars. I will call them to see about the option since they do make it for a bunch of other HONDA and Acuras.
#106
As per aem.
Fuel / Ignition Controller (F/IC)*
Fuel and Ignition Controller for 4-to-8 Cylinder Racecar Applications
The AEM F/IC is an economical solution for controlling fuel and ignition on vehicles that do not require stand-alone engine management, including variable cam timing engines like VTEC, VVTi and MiVEC.
*Legal in California only for racing vehicles which may never be used upon a highway.
OVERVIEW
The F/IC gives users with OBD-II race vehicles and non-factory forced induction systems the ability to retard ignition and deliver accurate amounts of fuel without the need for outdated FMUs or “boost hiding” controllers. This system works parallel to the factory ECU preventing tuning limitations due to complex factory timing patterns. 21x17 maps with configurable load and RPM breakpoints are easily accessed with the F/IC's Windows-based tuning software. The F/IC draws power from PC USB interface for quick and easy calibration changes.
PRECISE FUEL DELIVERY
The F/IC intercepts the signal to the stock injectors, allowing the user to modify pulse-width by +/-100%. The F/IC is the only piggy-back system that can decrease injector pulse-width, allowing the user to drive larger aftermarket injectors* while still maintaining proper air / fuel ratios. This powerful system can also tap into the factory injector signal and work independently to drive up to six (6) additional injectors.
TIMING RETARD CONTROL
The F/IC has the ability to retard timing by intercepting and delaying the outputs from the cam and crank position sensors to the engine- with no adverse affect on applications equipped with variable cam timing. The F/IC can retard timing from the factory system based on engine RPM and load inputs.
SENSOR CALIBRATION & CONTROL
The F/IC can also be used to recalibrate / clamp the MAF sensor, eliminating common problems with non-boosted factory MAFs. The on-board MAP sensor allows for proper fueling in boosted conditions.
CAN-BUS SYSTEMS NOT AFFECTED
Since the F/IC works in conjunction with the factory ECU, late model-vehicles equipped with a CAN-BUS system retain functionality of climate controls, dash and other components on the network.
PRODUCT COMPARISON : F/IC-6 AND F/IC-8
FEATURES F/IC-6 F/IC-8
Injector Channels 6 8
Advanced Injector Load Simulation & Filtering No Yes
Timing Channels (Cam + Crank) 3 5
High/Low Voltage Selectable MAG-Driver Outputs No Yes
TPS Input Yes Yes
MAP Sensor (Onboard) Yes Yes
MAP (0-5v Intercept) Yes Yes
MAF (0-5v Intercept) Yes Yes
Frequency Based Flow Meter Support No Yes*
Speedometer Recalibrator No Yes*
o2 Sensor Remapping Yes Yes
External AFR Input Yes Yes
Generic 0-5v Remappers 2 2
Boost Controller (Requires AEM 30-2400 Solenoid) No Yes
IAT Logging Input No Yes
PC Datalogging Yes Yes
Internal Logging Memory 64 Kb 2 Mb
Hey Blackura. May have the map voltage clamp too. Would eliminate the need for the ACM!
Only downside so far...Our cars nor the V6 Accord are listed in the known good test performed section.
OVERVIEW
TPS Input Yes Yes
#107
J37 ECU would be a no go, it has AWD controls and even if hooked up to a AT, it still would not be getting the AWD feedback it is looking for a probably throw codes, I tried doing something simular on a 3.5L 6th gen with a Pilot ECU and ended up in this position, so I changed out the ECU he got with one from a Oddy.
#108
This has been installed on a 7th gen and a couple 3rd gen TLs. If you search the forums you will find a couple of installs, also at least the AEM field engineer (yes I was actually able to get thru to a knowledgable person at AEM unlike Greedy) I talked to for a good 1/2 hour knew of several sucessful honda V6 installs.
#110
#111
The three things the FIC lacks compared to the EMU that I wish it had is....
1) Self tune mode, the EMU can take WBO2 reading and adjust a map according to the AFR set in the map, really nice for start-up.
2) Knock sensor input
3) Timing advance, alot of my franken-engine builds stay NA, it would be nice to be able to tune timing advance, although I am working on a solution for this
But at least the damn thing works with our ignition setup and you can actually talk to a knowledgeable person unlike the EMU. The EMU has great capabilities, but due to lack of support from Greedy for our crank trigger wheel setup it just does not work for our cars for ignition.
But there is one key thing the FIC does have that none of the others I have seen do, it will modify our O2 sensor siganls to keep our ECU from de-tuining or getting upset.
#112
#113
94 DC4 RS LSV/Turbo
hey allon, if you do buy the charger I suggest getting together with craig, muscle man knows his stuff
oh and it helps you can say your charger is dealer installed ROFL
#115
#119
He took the motor out of the cvcc and is trying to sell it. He was using the stinger. EMS has a new product that is designed specifically for a 6 cylinder. the 6860. It has the same features as the 8860. I've found the 6860 to be about 200.00 less than the 8860, about 1200.00. I'm going to use it on my project car. One obstacle you'd have to overcome are the cam gears, other than that, it'd be interesting to see someone adapt this to one of these TL's.
#120
Absolutely, if you could degree the cams with custom cam gears, i'd speculate you'd see maybe 15-25 hp increase.
