Race Pip from ATLP same as Test Pipe?
I see everyone has the Test Pipe done on their cars but it is not on ATLP's website, is this the Race Pipe?
Overall, I'm thinking about doing the Pre-cat Deletes from RV-6 and the J-pipe and Race Pipe from ATLP. Any other suggestions? I have the Type S so Im thinking about keeping the rest of the Exhaust stock? Recommend changing?
While they are not the exact samething, they both replace the same part. The Test Pipe, I believe is actually a little resonated, while the Race Pipe is a just a straight pipe. Either one of these (or a Hi-Flow Cat) will replace your 3rd cat.
Thanks that what I thought it was, was just a hi flow cat. I see you did the J-pipe and the Race Pipe. Did you notice a pretty good gain? change of sound? are you still using the stock mufflers? Do you think the Pre-cat deletes would be well worth it?
94 DC4 RS LSV/Turbo
richie v6 and atlp both offer RACEPIPES
richie v6 offers a testpipe (which is a racepipe with a resonated wall)
prices vary...
richie's is like $50 give or take $10
atlp is $125 I believe
prices vary...
I would also say Pre-Cat Deletes are definitely worth it. Everyone here that has gotten them as noticed the difference. Their only true downside is probably inspections.
Car pulls slightly harder, but I have not done a dyno since the intake. The car is running stock mufflers until I get the ATLP Quad in. Afterwards, I'll have a dyno done shortly to see the gains.
Is there a big difference in hp gains with the 3 replacement options for the 3rd cat? Or, is it primarily sound and emissions compliance (with high-flow cat)?
zaino'd
1. Search! Sooo many threads talking about the "best" set up.
2. To answer your question, its really all preference. Aftermarket j-pipe is a must (RV6, ATLP, XLR8). 3rd cat should be replaced with a resonated test pipe (RV6), a non-resonated race pipe (RV6, ATLP) or a high-flow cat (RV6, ATLP). As for your primary cats, you can install RV6 precat deletes, E-shift procats or OEM type-S precats.
I caught the mod flu
I'll be picking up the J-pipe V2+ Race/test pipe. I'm not sure which pipe I'll choose.
Anyone have sound clips of this set up on a stock exhuast with a CAI? What about HP #'s on the Race/Test pipe?
Full of water...
The guy might have to look a little hard though. The Pre-Cats aren't exactly in plain sight, and 1's pretty much hidden.
What do we attribute the price difference to? Construction, materials, profit?
Mainly anything in the exhaust that is higher or faster flowing, will cause some sort of loss in low-end torque, but till what 2-3k rpm. Right after that you will be going faster then before, but other then that your gaining more torque over-all.
zaino'd
Material-wise, RV6 uses a superior type of stainless steel (304 vs 439).
Construction-wise, both use solid flanges and I think they are both TIG welded.
Cost of production. RV6 products are made overseas while ATLP products are made in the US (I think)... damn US hourly rates!
I tried your approach on my Accord. I was extremely disappointed and pulled off alll the aftermarket pipes and put the stock exhaust back on because the engine bogged so much on the low end it negated the gains on the high end of the RPM spectrum. Besides I am not going to drive mostly above 5000 RPMs. Hence, that mod was not for me or my vehicle. Keep in mind, that was a 4cy Accord which obviously needs the back pressure for low end. Lesson learned. Lets see the effects on a 6cy TL.
Thanks.
94 DC4 RS LSV/Turbo
Yeah the k24 is different than the j32/j35... My friends base 07 halls ass all over low end mid range top end you name it
His setup is rv6 precat deletes/jpipe/resonated test pipe/greddy evo2
so if i got the race pipe from acuratlparts.com, that would take out my precats and put that in its place? Does that pass emissions and is it legal and what not? No problems will result from doing this?
Also do i need the o2 sensors and anyhing like that or do i just get the race pipe and take out precats and put race pipe in?
Help
Help
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
They are 2 different mods.
Pre-Cats will replaces your first 2 "cats" that come straight down from the heads if I recall. These lead down to your J-Pipe. Afterwards, comes your 3rd cat., which is what the race pipe replaces.
joflewbyu2
08-18-2019 10:38 PM
ExcelerateRep
10-14-2015 08:20 AM
lanechanger
10-13-2015 10:56 AM
johnpancakes014
09-27-2015 12:58 PM
