quick clutch question...
Old Feb 13, 2010 | 05:46 PM
tl2slow's Avatar
Bored at work
ok ...i put back my stock cmc with all the stock lines...when i bleed the clutch i get no air bubbles at all...the clutch seems to engage fine at first but when i drive around it loses pressure ...i have to pump the clutch at every light just to get it in first.. everything is brand new...what can it be???????
Old Feb 13, 2010 | 06:23 PM
Xiomaro's Avatar
1st 3g Turbo TL-S
loss in line pressure??? what happened to your rsx cmc?
Old Feb 13, 2010 | 06:34 PM
tl2slow's Avatar
Bored at work
it worked great but i just want the car stock again....
Old Feb 14, 2010 | 02:26 AM
NAiL05's Avatar
Bleed it a lil more and it might take care of it. If it doesnt go away your CMC might have crapped out on you. My buddies and my personal old car have done it before. You will be able to engage gear then lose pressure...if it gets bad enough it will have pressure then it will completely depressurize.
Old Feb 14, 2010 | 08:59 AM
tl2slow's Avatar
Bored at work
the cmc is brand new......
Old Feb 14, 2010 | 10:11 AM
KN_TL's Avatar
Bleeding the clutch was the strange for me. If you used the pump method, did you limit the travel of the slave?
I used a vacuum bleeder and found it took several passes to get it to function correctly. I ended up going through at least a full tank of fluid.
SidhuSaaB
May 30, 2020 12:40 AM
knight rider
Mar 4, 2016 08:59 AM
KBTypeS
25
Oct 1, 2015 04:49 PM
mshipon
2G CL Problems & Fixes
Sep 28, 2015 12:14 PM
MilanoRedDashR
Sep 24, 2015 11:04 PM
