Question about muffler/exhaust system replacement??
Old May 9, 2016 | 04:01 PM
Zach St. Denis's Avatar
I have a 2004 3rd Gen TL and it currently has a dual exhaust system with SG-573 Sankei mufflers that are the stock models. I am wondering if there is a DIY way to bolt on an upgraded performance muffler (possibly a hotdog) in the TL that doesn't require welding and can give me a louder exhaust sound... anything??
Old May 15, 2016 | 07:43 AM
Scottwax's Avatar
Mr. Detail
Leave the rear mufflers alone and start with removing the mid-muffler and replacing it with a straight pipe and the factory resonator with a Magnaflow or Dynomax resonator. It will be a lot cheaper, will make your car noticeably louder without it being obnoxious ricer loud and you won't have any drone or rasp.
Old May 15, 2016 | 08:30 AM
VisualEchos's Avatar
Andrew
I don't recommend that you remove the resonator, as stated above, as the resonator's sole purpose is to quiet the noise INSIDE the car, and removing it won't do your exhaust sound any favors either.
If you're just looking for more volume, then the mufflers are where you should start. Contact XLR8 for this.
Old Jun 2, 2016 | 10:29 AM
GroundedCustom's Avatar
GroundeDCustoM
Loose your mid muffler. Straight pipe it.
Replace factory resanator with a dynomax. Will give that import soft growl. Magnaflo has that buzz tone to it more so
everyone hypes the magnaflow mufflers but to my ears they humm.
Old Jul 16, 2016 | 06:57 PM
TLTypeSlow's Avatar
Everything is going to require welding.
Like everyone stated, try experimenting with remove/replacing the mid-muffler and resonator. Here's a great link that lists and describes some options that you have. Of course, you'll have to go to a muffler shop in order to get everything welded properly, along with ordering a resonator if you choose to.
https://acurazine.com/forums/3g-tl-p...1811-a-589747/
Old Jul 19, 2016 | 11:14 AM
Eastt__Eastt's Avatar
Muffler Deletes
I Am Going For The Sound Of This TL Here:
Anyone Can Help Me With Finding A Helmholtz Resonator To Do The Rear Muff Delete.
gavriil
Apr 1, 2026 12:45 PM
TSX69
3G RLX (2013+)
1409
Aug 17, 2020 12:49 PM
00TL-P3.2
Feb 11, 2019 11:23 AM
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
Sep 17, 2018 07:45 PM
D.j. BeatBreaker
1/2G MDX (2001-2013)
Dec 14, 2016 12:01 PM
