Question about installing the 2 studs on the P2R intake manifold spacer
Old 06-02-2019, 12:57 AM
Atlas_Gen's Avatar
I just installed the P2R intake manifold spacer but how do I remove the 2 shorter studs that are on the engine side?
Here's a picture of what I mean (The 2 red circles on the top picture) The second picture are the 2 extra bolts that I haven't installed yet since 9 came in the package. 7 bolts to install into the intake manifold to hold it down to the runners and there are the 2 studs that lead up from the runners and 2 nuts go on those from the top.
The stock studs are too short to even put the 2 nuts back on to hold it down (As seen on the last 2 pictures)
Old 06-02-2019, 06:54 AM
Received 16,260 Likes on 11,971 Posts
remove the spacer, then lefty loosey on the studs....then install spacer, using the new allen heads, going down....instead of the factory stud going up
The following 2 users liked this post by justnspace:
Acura TL Builder (06-03-2019), Atlas_Gen (06-02-2019)
Old 06-02-2019, 01:17 PM
Atlas_Gen's Avatar
Thank you justnspace!
justnspace (06-03-2019)
Old 06-03-2019, 08:53 AM
not a problem, I recently installed the spacer as well!!!!
Atlas_Gen (06-04-2019)
Old 06-03-2019, 11:17 AM
CAD Guy
05 Acura TL's Avatar
What Justin said, depending on how long they have been installed and if they have ever been removed. You may need to go the double nut method to back the studs out. When I installed my P2R spacer a year or so ago I had to use that method to remove them.
The following 2 users liked this post by 05 Acura TL:
Acura TL Builder (06-03-2019), Atlas_Gen (06-04-2019)
Old 06-03-2019, 11:28 PM
Acura TL Builder's Avatar
Ditto
Old 06-04-2019, 06:42 PM
Atlas_Gen's Avatar
Awesome, thanks for the good tip! I'm waiting for my new manifold and throttle body gasket to arrive so once I have those then I'll remove the old studs and give it a shot.
justnspace (06-04-2019)
Old 06-04-2019, 08:14 PM
I enjoy that tip too!
Old 06-07-2019, 03:11 AM
Resident Smart@ss
ProfessorFunk's Avatar
That's what she said?
justnspace (06-07-2019)
Old 06-09-2019, 01:20 AM
Atlas_Gen's Avatar
This worked perfectly! It backed out really easily too with the double nut method, thank you again guys!
16MattM16
04-13-2017 09:06 AM
mrkingstonvi
05-12-2015 04:16 PM
Nitin
07-28-2014 10:35 PM
kdawg8526
10-19-2011 09:59 AM
mglax13
04-22-2009 07:27 PM
Quick Reply: Question about installing the 2 studs on the P2R intake manifold spacer
