Project TL: Engine swap has begun!
#82
I am not. I bought a whole new shortblock and transfering everything over.
However, the bearings in the 3.2L and 3.5L are identical. I don't see why you can't reuse them if they are in good conditions.
#83
i'd replace the bearings anyway for security if it was me. also new connecting rod bolts. this is if you are getting used parts obviously. i know you got brand new shortblock.
#84
Honda/Acura uses a very simple way to identify what bearings you need for proper clearances. The block is stamped with five letter codes and the crank is also. With both letters you can determine the right bearing color (hondas way of "size") for the right journals. Just because they are the new ones from the short block doesnt make them right for that appication. The rod bearings will be correct since the short block came from the factory assembled and you are using the crank and rods from that block. Do yourself a favor and install the right bearings. I bought some King bearings for a F22 race build up and it they mic'ed up good but i still ended up spinning a bearing. Never had any problem with the correct oem bearings even on some 600 fwhp turbo'd hondas.
#85
#87
I am not using my orginal block. Well I am using the TL block but a brand new one. All crankshaft bearings and rod bearings between the TL and MDX and RL block have identical part numbers, so I would assume they are all made the same and would all fit perfectly especially when all the parts are brand new.
#89
As of right now we are waiting for the new block to arrive. Hopfully if it arrives tomorrow then it will be off to the machine shop next week. Then we will be able to start putting everything back together and hopfully fire it up at the end of next week or the early week after.
#90
one questionm, i dont think anybody has asked this but if they have im sorry for the redundancy. all this work and money going into the car is great in my opinion (i love what your doing to ur tl), but it seems like your replacing all of your parts with tl-s or tl-s like parts. y not just get a tl-s?
#91
If you are transferring the internals from one block to another block, your mechanic must order the bearings from a stamped code on the block you are going to use. If you don't do this, and the two blocks have different codes, your going to be taking that motor out again and doing it over.
It's the machining process when doing the line bore. Anyway, here are a few pics of what i'm talking about.
In the top right hand part of the pic are 4 letters, CCCC, This is the main bearing that is associated with this block. Not every block will have the same code. The bearings can be bought at acura and you must tell them the letter series on your block.
This is what's stamped on the crank, there are 6 bearing codes stamped on every crank. They are not all the same from crank to crank. Machining processes get it in the ballpark, then they fit it to the nearest color associated with the clearance of that particular journal.
If anyone is looking to follow in his steps, I do have a brandnew rl crank that has been coated. pm me.
#92
Oh now I get it! Thanks for the heads up! Learn something new everyday! Hopfully my machine shop will take care of that for me.
How much are you looking to sell your RL crank? Do you have rods or piston to sell as well?
#95
Anyway, I do have a fully prepared, with matching rod bearings, RL Crank. The crank has been coated to allow the oil to slip right off it. The rod bearings have also been coated by Calico Coatings, google them. If the block your going to use has the same code, then I also have the main bearings for that as well. The issue at hand is if you want this crank, i can take a loss on it as it's not going to work in my particular block. the rods pistons i will not take a loss as it's going to go into that block. It's just that i'm still some time away from completing this and can always reorder and wait for the rest.
Rods: I do have the rods, Pauter, but hadn't contemplated selling them. If you do want them, I won't take a loss on those because I have the time to re order another set and wait a few weeks for them. If you want them, You'll have to pay what I paid, and they very well may have gone up in price a little, If you need them i'm only asking for what i paid. receipt available. They are brand new and have been matched to the bearings for a very presise fitment which is matched to this rl crank.
CP Pistons: Same with the pistons, I hadn't thought about selling those as well. They are expensive and the wait for them is excruciating. I kid you not, I waited for 6 months for those f#$&%$g things. It's not easy getting something like that made. Think of the measurements needed to get the desired compression ratio. There were many measurements made, to much science to detail. The end result is a fine forged piston, with lateral gas ports and comes in at about 9.4:1. The valve releifs are more than adaquate for your choice of cam. I also sent the pistons to Calico to have them coated on the sides with a friction reducing coating and the tops coated with a ceramic to fight off heat. With you being SC, I'm not sure that's the compression ratio your looking for, but IMO it's a good place for a SC motor, low enough to allow more boost and high enough so bottom end torque is compromised. I won't take a loss on these but can take some loss on the coatings. The pistons come with rings, tool steel pins, locks. They are of stock bore, 89mm.
Seems time is a factor for you, but welcome to the mix and match world of honda motors. Those parts were ready to go into my block, but the difference between the cranks threw me under the bus. The crank pictured above is a stock 01-02 mdx/oddesy steel crank. It needs the attention that was given to the RL crank. let me know if you want pictures.
if anyone is needing rl cams, they will fit the tl motor as the length is the same from the tl to the rl, fire me a pm.
Cheers.
#97
So the new engine block arrived last week and has been sent to the machine shop for crankshaft and piston assembly. Hopfully if everything goes right, we will be able to fire up the TL on saturday if not early next week.
Will update as soon as possible! Stay tuned! I haven't been able to sleep for so long. Finally it's coming along...lol
Recap of what we are adding this time:
3.5L crankshaft + connecting rods
CL TypeS piston with 10.5:1 compression (bigger valve relieve ports for the bigger intake valves in cylinder head)
07 TL TypeS cylinder head (bigger intake valves, hollow camshaft)
Total Seal Piston rings
Dr.Evil custom torque converter
Snow performance variable controller
Split Second ESC1 (possible fix to the supercharger surging issue)
We are going to use the stock 4.5lb pulley for the supercharger and get the TL up and running first. Then we will hook up the E-manage Ultimate and get it tuned. The last step would be to use the 8lb high boost pulley if everything goes right.
#98
^^^^ I am not understanding how the weight of the pulley relates to the boost capabilities, I am assuming that a higher boost pulley would be of a smaller diameter and would actually be lighter if made of the same materials. I am not all that familiar with the intricacies of this technology, so am I missing something here?
#99
Bro he is talking about the boost capabilities of the pulleys not their weight, they are small so the weight wouldn't really matter anyway. The stock Comptech supercharger pulley provides around 4.5 lbs of boost. Comptech also has a high boost pulley which will give you about 8 lbs of boost this pulley is smaller in diameter and provides more power so you were right about that. Lookinco has both but he wants to be safe so he is going with his stock Comptech pulley to test out the new motor first, plus he needs to tinker with computer/fuel management first.
By the way lookinco great going, good luck and keep us posted, great thread!
#101
#103
DOH! do i feel like an idiot! I have always been thinking in psi, not lbs I thought the high boost pulley was like 10 psi, its only 8? Wow, so for the standard setup that is like 1k$ per # of boost ? I guess I like the 75$ per 1 horsepower figure, somehow it sounds better!
As far as force induction being expensive I agree it's a costly option always has, is and will be but there are more expensive kits out there with similar results plus when you exhausted all other means of obtaining power short of increase in displacement from a moderately powerful NA engine, FI is the only way to go if you crave more power. It's not the worst thing to spend your money on, you could do much worse. FI is intoxicating!
#105
I like to whistle in my
3 new pages and great info. This is the kinda of stuff you copy,paste and print out to read over and over again. i was never good with internals but this is definitely a good start as far as learning about the TL capabilities. I know this car isn't going anywhere and time soon so I need to learn all i can like i did with my previous hondas
#106
Good luck
BTW, I was talking to 02AV6 (the one who runs 12.8 @109mph in his hybrid 3.2L Accord V6 with blower ) and I'm thinking to do the following for my 5AT:
1. Get '04 MDX 3.5L cyl. block and swap it's pistons with '03 CL Type S to lower compression a bit.
2. 2 new head gaskets.
3. RL cams or TL-S cams (whichever less). Not much difference in lift vs. regular TL but I just want it and getting a good deal on it.
4. Get the blower kit with regular pulley in the future.
Thanks 02AV6 for advice
#108
Just so you know, the MDX block will NOT work.
TL heads should fit right in as well
#110
There are some things about the 3rd gen tl that i don't know much about, but sounds like lookinco ran into some of the same problems i did when working on this swap. I have the cl. It sounds like you guys use almost the same block as ours, as the tranny bolt pattern is different, to help out, here are a couple pics to show the difference.
this is the back of an 03 and up mdx block.
This is the back of an 01-03 CL block and shares the same part number as the 01-02 mdx block, notice the difference in the bolt pattern and casting. Everything else in the 03 and up block will work in the 3rd gen tl motor but won't work in the cl motor, shorter cams, crank, and other things.
#111
Been thinking about it...and one other thing for lookinco, the 3rd gen tl and 03 and up mdx have a kidney shaped oil return cast into the deck of the block, I'm not sure, but if you ended up getting a block to fit your tranny, i don't think that block will have that kidney shaped oil return I'm speaking of and therefore don't know it the heads your wanting to use will line up properly. I'll try to find a pic of what I'm talking about for later, just a thought.
#113
Right now I am using a 06 TL block but with the 3.5L internals. The 07 TL-S head bolted right up without any problem and also bolt right up to the AT transmission.
#115
The engine is finally back in the TL!! Unfortunately I am going away for 2 weeks for christmas and new years so I would not be able to give an update until I am back. I can't wait till I am back to start breaking in the engine. Everything fit back into the TL perfectly, so hopfully it will run nice and smooth.
#117
#118
Yep, everything will fit inside the MDX block. The head will bolt right up. The problem is, your AT will NOT bolt up to the MDX block.
#119
You need to do some better research. There are 3 people including me who have TRIED IT and the reuslt is that the MDX block WOULD NOT WORK. However if you want you can go ahead and try. If you are interested, I have a brand new MDX bare block lying around that I could sell to you for $200.
BTW, the MDX and 04-06 TL DO NOT have a similar 5AT design and the bolt pattern is NOT the same. I don't see how you guys would think the AT would bolt up to the MDX block while the MT won't. The 04-06TL uses the same block for both AT and MT. If the MT would bolt up to the block, than the AT would also bolt up to the block because it's the SAME BLOCK. So if the MT won't bolt up, than the AT would NOT bolt up as well.
