Progress Sway Bar Installed
I got my bar in yesterday and threw it on this afternoon.
It was very easy to install, the only issue was the threads on the end link had some rust on it so I had to use a allen wrench in combo with a 14mm wrench (both sides) to remove and install the nuts.
Even with that, it only took 30 minutes to install.
The handling difference is very noticeable and most noticeable was the torque steer wander was reduced.
Floor jacks or lift?
I just got my Progress Sway Bar in today. Can I install by using floor jacks or will a lift be more suitable? I'm not sure of how much room I need uninstall the OEM sway bar and install this one.
OMGWTF4THGENTL
I wrestled mint in last night. It seemed harder this time (replaced the comptech RSB), perhaps the comptech exhaust is a bit more difficult to work around. It was a chinese F$ck puzzle getting it back in... Scratched the shit out of it, but it won't hurt anything, and it's gonna get beat up on the road. I figure everyone beats/scratches it up trying to get it installed over the exhaust.
In retrospect, I wish I had seperated the comptech exhaust...
Much stiffer... I might actually try the softer setting, in a hard turn you can feel the rear wanting to come out. Certainly a good investment...
A-spec steering wheel ftw
what did you use to prop up the car?
Installed mine early this morning on the soft setting. Took about 45 mins from start to finish being careful to correctly torque everything to specs. I have yet to take it on the road for a test drive. But I did test out my motorcycle instead!
are you guys all using regular floor jacks? i'm trying to figure out how i can do this install with the least amount of equipment available... being that i'm probably doing the install inside my university garage since i have no hook up to any shops in the area, and i'm not gonna drop 100+ for such an easy install.
so please, if you guys could just also post how you're installing, it'd be a great help to me.
sweet, looking foward to getting this done.
now as advice from people who've recently added this....what was the biggest reason for getting this change?
for example, if i am understanding things correctly, in a hypothetical scenario (of course ;P) - if i am coming out of a 90 degree arc, aka 1/4 of a circle ~ usually something like an onramp/offramp, - and i notice that my car shifts weight pretty sloppily hence i'd go in heavy on the left, but as i go thru the arc, the force is pushing outwards (Centrifugal force), and because of this force, i can feel that the car is potentially in a situation to lose it's arc-ing position, is this what i would add? so that i don't feel like the weight shift from inside to out is going to spin my car out? (i understand what i just described could also be understood as a drift of some sorts, but i'm just trying to figure out what exactly this will change in it's most basic scenario)....
i love the way the car drives, but my initial desire to get this mod is simply because i feel like the car is too "soft" at the moment, even with the A-spec suspension which apparently gave my salesperson an aching back....
so i mean my all means please provide examples and just basic info, i've read almost all the post regarding the RSB, and i mean yes, i understand the mechanics of it, but then i read about the real life stories of RSB conversions, and then it doesn't seem to have anything to do with what it was designed for - like what they are happy about has nothing to do with the RSB.
please, i'd like more info about this ^^
thanks in advance
thanks in advance
marcelft
07-10-2018 06:17 PM
MonkeyTrucker
09-21-2015 06:15 PM
k6biv
09-10-2015 06:37 PM
