Precat install HELP Please!
Well I am in the process of installing Rv6 precat combo..
Jpipe & 3rd cat are off, now front precat is disconnected, how the hell do you get it out?? That thing is fat! Do you have to take the radiator out?
Also any tips for doing the rear one? Looks tight as hell and fucking impossible..
HELP PLEASE!! ASAP.. Doing install NOW.. and will be monitering this thread..
I have car ADD
rear cat?? woooo-hoooo. thats fan... remove the strut bar, and you may want to move the CC module out of the way
you'll need a good thick socket extension... remember to use the new gaskets and be careful.... those suckers can cut you NASTY.... i got the worse slit/papercut from the gasket.. i thought i was gonna need stitches
Chapter Leader (NY/NJ)
let us know how it goes and how much time it took. i just ordered my set and knowing me it wont sit in the house for long time so i need to make sure timing is correct. its f*king snowing in NYC !!!!!1
Former Sponsor
Ok will do, the battery has been disconnected all day..
But hey Richie, the origional precats had studs on the bottom of them, and yours dont.. Just wondering if I was supposed to receive 6 bolts for the precat to jpipe connection.. Its all good tho just wondering, gotta run to Pepboys and get some bolts right quick..
Former Sponsor
tehLEGOman
Received 1,982 Likes
Congratulations on a successful install.
How did you get the rear oem cat out?
sweet, so did you pull the rear cat out from the top or the bottom?????. it almost seems like the rear one is the biggest prob. the front one dosent seem that bad as long as the fan/shroud is outta the way. oh and did you have any problems with the o2 sensors being really stuck in the cats???
thanks!
thanks!
94 DC4 RS LSV/Turbo
Glad to see a few guys going at this the diy way, hope my thread helped
This is one mod that needs to be done by someone with some-sort of basic automotive skills... Don't do it if you've never held a ratchet in your hands
Haha this is true.. Not brain surgery but not easy or fun by any means..
One question for anyone who has precats/jpipe/testpipe and stock exhaust w/ stage 3 with deleted mid muff & dynamax res..
Do you have any rasp? My car has a slight rasp at about 2-3k now and its kinda annoying...
BTW car def sounds alot more aggressive.. Not for the feint of heart
94 DC4 RS LSV/Turbo
its the dynomax res... its there to amplify the stock exhaust note... via the stage 3...
if you want the rasp to go... the dynomax has to go.... replace it with a real resonator
I favor the aero resonator but any "real" resonator will eliminate the rasp
yeah im running the same set up as you rite now.. i think when the car is cold it may sound like alittle bit of rasp but it goes away when the car warms up ...atleast for me it does ...
I have car ADD
i get the metal shaking sound from 2k-4k rpm ONLY when the car is cold... its the heatshield on the drive shaft... some people chose to remove theres
i have NO rasp what so ever on my car, just that damn vibration.. once i give the car a full throttle once, the sound is gone until the car is cold again... summer or winter, doesnt matter
94 DC4 RS LSV/Turbo
you can remove it by getting skillfull with a 12mm rachet... I would remove it simply to avoid the vibration
its there to protect the halfshaft from the stock cats which light up and get extremely hot...
with the precat deletes it seas nowhere near the hgih temperatures
wait sooooo what goes on wiht the O2 sensors once the precats are in only 2 of the 4 get used or none get used? i just got them off the blackmarket from one of the members and he said all the stuff richie put in the box is there and is pretty much self explanatory but i still dont get the O2 thing. I got a P0420 code in the car the other day and i looked it up in the service manual and they say to replace the cat. obviously Im not but maybe an O2 is bad as well???
No, the o2 sensor does not sit inside the pipe like in normal cats. They are not exposed to any fumes. If you look at the precat delete, there is only a very small hole for the o2 sensor to "sniff" the fumes. It is so small that it barely sniffs anything, and anything it does sniff is considered normal.
Correct me if I am wrong please
94 DC4 RS LSV/Turbo
^ yup richie includes double stacked defoulers on the lower 2 o2 sensors...
for those of you get o2 catalytic codes you can get smaller one's from richie but you should really return the one's he sent you originally so he can make those smaller and replace for other people
still whatta u mean?? smaller larger whats the diff?
the reading comes out different depending on the size of the defouler?? <~ that i understand but y change what he put there?
practicing nihilist
So, I was showing off my RV6 kit (still in the box till next week) to a buddy and just noticed something that I didn't before. Is there supposed to be a slight crimp near the bottom flange of one of the Pre-cat's? It looks purposeful like for clearance around something but, still has me sweating a little. Never saw that in the pictures.
