Ported/Polished Upper Intake Manifold and Runners!
#201
takin care of Business in
Received 4,732 Likes
nope....but i bet you will have dyno's of base TL's which have the same mods....the only difference will be my exhaust (not ready to disclose the design yet, its a custom true dual will be posting some vids later) and some other mods (bored TB etc)
#204
with ?
i got my manifold and runner pno-ed from Andy (Gerzand) on the forums....I am having 2 sets (Set 1: manifold+runners+mdx spacer+TB+TB spacer+Gaskets and Set 2: Manifold + runners) bored the fawk outta them from
will disclose when i see the results better than what I have currently....i will prolly put 1 set of manifold + runners on the BM.....
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
TrustinHFDJ (07-14-2012)
#206
#207
I thought it was explained by Richie that the crosses or whatever is actually BETTER then "true" duals? I also thought it was best for this J to actually have a little bit of back pressure. Is this not the case?
Sorry off topic. :/
Sorry off topic. :/
#208
LOL...in due time my friend....also will snap some pix and send them your way....perhaps some vids too ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
nah your cool...the only reason true duals wont work is coz of sound....3 cylinders coming out of 1 pipe wont sound as good and wont flow as good....its good to incorporate a H pipe (better than and X) as this equalizes the pressure and hence sounds /flows a lot better....
the reason richie went for X pipe is so that it will be a universal fit....imagine he had gone with the H pipe for the jpipe and true dual or the other way around, it wudnt have worked....the x pipe works perfect for him as he got to expand his horizons....people with ATLP exhaust can use richie jpipe and vise versa
#209
i am planning on a true dual too! iv got the plan ready but i am seriously considering trading for a MT TL....money is an issue there tho i would not want to lose alot to have an MT. plus my car at 110K runs soooo perfect. iv done so much to maintain it, seafoam, redline ATF, tranny filter change, spark plugs, just a bout everything xcwpt for the tranny pressure switches. its hard to let go! LOL ![Tomato](https://acurazine.com/forums/images/smilies/tomato.gif)
i have meticulously maintained my car as well...she is pristine.....i would go the true dual route....its ending up being expensive for me (1500 for parts + labor and 250 for the v2 pcd (already installed)) but the guy does an awesome fucking job....my budget was 1000-1200 but then after i saw his work, I was like i dont mind another 200-300 for this kind of craftsmanship....
it still ends up being cheaper than most systems out there:
riche: pcd + jpipe + exhaust = 2000-2200 + a wait of many months
atlp: richie pcd + atlp jpipe + exhaust = 1900-2000
I think the greddy+xlr8 systems come close in the cost....but then again the research + thought process makes you so much more connected with your car....
#210
ok lets stay on subject i am so tempted to talk about H vs. X pipes lol.....must ...resist......
#211
^^^ go for it....
and yes you do get what you pay for....my true dual is running me $1500 which is more expensive than richie's exhaust....but thats not the point...
i like going custom coz you see the exhaust being build infront of you....unlike just paying and waiting 4-5 months and then the UPS guy shows up and u put it up....it took me 2-3 months to find the right shop....someone who knows what he is doing....has worked with many other cars...then telling him what i am looking for and hearing his "how to go about it" and coming to a conclusion and getting the exhaust ready....
i have nothing against richie....i am rocking his pcd's and i think they were fucking great....very well made, very well constructed, materials, everything about them is awesome....
but i was looking for a different exhaust note....a different setup....hence custom....
#214
so this is the only thread that might have some discussions left on heat soacking in the engine bay.. has anyone painted their Manifold, Runners and possible Pre-Cats to reduce engine heat? found this link but not going to even bother finding out how much it costs but it maade me curious
http://www.zircotec.com/page/--motor...t-coatings/132
has anyone painted using a high heat paint.. and possibly something with ceramic or other heat reducing chemical..
Just curious since I might come into
a set of ported mainfold and runners
and before I put them in wanted to do what I can to reduce heat if possible.. also looking at pre-cat deletes or high flows but again want to do what I can before bolting on.. I truly hate bolting and un bolting.. its almost as bad a continously moving furniture around cause the wife doesnt like the location
and before everyone says anything.. I got all the cooling stuff and other mods bookmarked already.. no one.. and no one has spoken about a special paint to reduce heat
and technically I am not thread jacking since I am talking about painting a ported intake manifod and runners!!
![what](https://acurazine.com/forums/images/smilies/what.gif)
#215
nah dude you good...
i have my PCD's ceramic coated inside out....inside for better flow, outside for heat resistance and looks....
the heat travels from the runners to the manifold to the throttle body to the IACV where it affects performance....the best way to keep the heat down is:
1> UCM (Ultimate cooling mod): I have to say this does keep the heat wayyy low
2> Throttle body Coolant bypass
3> insulating your AEM/KNN/Whatever air intake (debatable)
4> Use of P2R spacers, throttle body spacer, etc....
5> I have the MDX spacer which also helps since the TB is that much away from the runners...(after my setup is complete I will be dyno-ing with and without the MDX spacer to see if the spacer hurts anything)
6> Butterfly delete in the manifold (gives you a little low end)
7> Am working on something (not yet tested and hence am not posting it up)....i ran with that in 110F heat and the throttle response was awesome....
i dont think any kind of paint is going to keep the heat out...as in this case heat is caused due to conduction and not radiation....
my manifold was powder coated black and that was just for the looks
#216
for additional readings on ceramic coating inside out:
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/ceramic-coated-precat-delete-j-pipe-test-pipe-710198/
#218
Here is it when it was on the car:
![](http://i1202.photobucket.com/albums/bb362/sezniko/Kansas%20City%202011/DSCN0481.jpg)
someone took it at the KC meet not too long ago....
will snap some close up pix of it....its sitting in my garage, ready for sale LOL...
#219
So i thought when you use the P2R spacer, throttle body, & or MDX spacer it robs from either low end or high end... I know its out there but need to read through all my bookmarks to find it.. wait gerzand said it in page one of this thread.. he said "you will lose massive top end HP while only gaining a small amount of low end TQ from the MDX/Ridgeline spacer"
has anyone experienced that or just going by word of mouth?
#220
04Tl
my manifold was powder coated black and that was just for the looks![Too Cool](https://acurazine.com/forums/images/smilies/toocool.gif)
I've tested and from my experience the butterfly delete made my car a lot slower so i put it back in. u feel a gain in low end? and how is ur top end?
#221
butterfly + mdx spacer
butterfly only no mdx spacer (like stock)
mdx spacer only no butterfly (completely opposite)
no butterfly and no mdx spacer
i hate to go by experience and word of mouth since you dont know the ECU/driving conditions/so many variables....i love numbers....if a mod gives me tons of low end and mid range but sacrifices a little top end, i dont mind....since we drive mostly in the 2-4K range 80% of the time....i dont hit vtec everytime i drive....u know what i mean ?
#222
Just btw i think you guys have it mixed up as to what a true dual exhaust is...the only reason Richeys exhaust is not a true dual is because the merge at the j is not a true X or H merge...most good true duals have an XorH pipe
#223
I am going custom....its going to be a true dual....thought of using an Hpipe but went with something different...will post when i see the gains....
#224
on a V8/V12 you could try without a merge...but not on a V6....
they will sound like shit and have bad exhaust pulses/pressure....i was going to use a H pipe but ended up going a different route....
anyway back to pnp manifold and runners
#226
04Tl
my low end is fine, since i have lots intake side mods and only PCD's exhaust side....so its a crazy fawking bottleneck...am going to get my exhaust fabbed next week and will try to take 4 dynos....
i hate to go by experience and word of mouth since you dont know the ECU/driving conditions/so many variables....i love numbers....if a mod gives me tons of low end and mid range but sacrifices a little top end, i dont mind....since we drive mostly in the 2-4K range 80% of the time....i dont hit vtec everytime i drive....u know what i mean ?[/quote]
Ya i hear u, im more concerned with up top power and am always in vtec so ya i see where ur comin from and i didnt know u didnt have a full exhaust. i have a complete exhuast and intake mods.
#227
Yup i will post all the 4 dyno's up so you can decide which way you wanna go....
#229
its ight dude....
yes am running them....here is the order of air flow:
AEM Air intake with over-sized filter
Throttle body (getting this bored out in couple weeks)
P2R throttle body spacer sandwiched between P2R Thermal Gaskets (this will get bored out with the throttle body)
Ported and Polished Intake Runners
MDX Spacer sandwiched between P2R Intake Thermal Gaskets
Ported and Polished Runners
Hope that helps....
Hope that helps....
#230
just a quick question for you dude....when you had the butterfly delete was there a little noise coming from the manifold....it doesnt bother me, but wanted to make sure its coz of the butterfly delete...
#231
thanks, able to see it in me mind now
its ight dude....
Hope that helps....
Hope that helps....
#232
#233
runnin a little boost
Does the timing belt need to be messed with to remove the runners? I am trying to figure out if its worth my while to polish just the IM and if the runners are going to be a pain to remove. I bought a IM to polish the outside and started thinking maybe Pnping it would be a good idea. My concern is with the turbo the Pnped IM won't make much difference.
#234
nope ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
you will remove the manifold + fuel rail and injectors and you have like 6 screw that hold the runners....
as simple as that....time consuming but yeah simple....
NOTE: while putting the injectors back in apply some engine oil on them so they slide in...else they can be a biyatch !!!
#236
hey Feji.....I have gotten the exhaust....here is the thread....
am waiting to get my Throttle body bored out and will put her on the dyno and the track for 1/4 mile times....
#238
^^^ yeah i did....it seems like that noise is from the tensioner or some like that....when i took it to my exhaust guy he said its from the butterfly so I thought I ask you....
#240
Insulated CAI....keeps the things cooler ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
one of the most biggest problems with the TL is low end goes away with higher temps....I have done 3-4 mods to keep the underhood temperatures low and hence my low end high LOL
