Ported/Polished Upper Intake Manifold and Runners!
Old 03-27-2012, 07:04 PM
  #961
Mom why is there two?
ethenol's Avatar
Phenolic................... Look it up guys!!!! I already commented on your post about that type of plastic. Once on, it is done non reusable! It is cheap to produce ans machine that is why a lot of people use it.......
Old 03-27-2012, 08:21 PM
  #962
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
mother$%#$%^
talk to p2r and ask for a refund thats 40 bucks a pop !!!
Old 03-27-2012, 09:02 PM
  #963
thisaznboi88's Avatar
can't talk to p2r. I bought it new but from a member on here... So I am just going to eat it.
Old 03-28-2012, 03:46 AM
  #964
Hacura's Avatar
Originally Posted by thisaznboi88
didn't you see my thread? this was after 1 month
I didn't do the ultimate cooling mod. Going to run water/meth. I don't like cutting up stuff that I can see.
No, I haven't read your thread man...that's uffing scary.
So what do you recommend Keith? Do we just install both P2R IM gaskets and leave it on or should we use a different gasket underneath where it gets hotter. This will leave the P2R in between the IM and spacer which I think it where it's mostly needed and should withstand the heat.
Any comments on your IM spacer and turbulence? It looks like a damn fine product.
Originally Posted by swoosh
mother$%#$%^
Yeah I wish I knew this before ordering both IM gaskets.
Old 03-28-2012, 04:19 AM
  #965
ethenol's Avatar
They work. Just dont take your manifold back off. If you do you will prob need another set. Or you just run 2 steel stock gaskets and you can take it off and put it on as much as you want. You will be fine. They are non reusable remember that.
Atlas.46 (03-28-2012)
Old 03-28-2012, 12:38 PM
  #966
Hacura's Avatar
OK, that makes sense. If the gaskets melt, will the bolts need to be tightened again after a certain setting time?
Old 03-28-2012, 05:18 PM
  #967
ethenol's Avatar
^^^ No
Old 03-30-2012, 07:47 PM
  #968
Hacura's Avatar
I'm opening up my parts just now and noticed a few things:
1. One of the runner openings is not completely round, it has a slight notch in it:
2. The IM spacer isn't port matched to the IM. Isn't it supposed to be? Here's a picture of the spacer sitting on top on the IM. The IM spacer has a wider opening.
3. All of the parts where air will flow don't appear to be completely clean and free of fine metallic residue. Should I just clean with isopropyl alcohol and proceed?
Old 03-30-2012, 08:02 PM
  #969
where did you buy the runenrs from? Here is what mine looks like. Very little of the seam is left. Get a dremel and sand it down some what
as for the spacers. Look at the bolt holes... They aren't even lined up. Line them up correct and they should be mostly match I think.
Clean the parts with brake fluid cleaner. You don't want any those of residue inside of your engine.
Old 03-30-2012, 08:08 PM
  #970
swoosh's Avatar
^^^ i agree with that azn boi
this is bound to happen when you get parts from 2 different area....am guessing the IM spacer is from KPP which has a 46.xxmm opening and the runners are from Andy which have a 44.xx opening....
Old 03-30-2012, 08:23 PM
  #971
Hacura's Avatar
The runners are from my car; I sent them to be worked on. Everything else is fine except for one runner opening in the pic. The seam only shows in this one opening.
Even after lining up the IM spacer holes, there is still a difference.
Everything is from MPP.
Old 03-30-2012, 08:34 PM
  #972
who is MPP?
Old 03-30-2012, 08:37 PM
  #973
swoosh's Avatar
^^^ Moores Performance Parts....Owned by Keith (ethanol)....
The following 2 users liked this post by swoosh:
Atlas.46 (03-31-2012), thisaznboi88 (03-30-2012)
Old 03-30-2012, 08:42 PM
  #974
@ Swoosh Thanks man
@ Hacura its probably a casting issue with the OEM runners since because usually the welds stick outwards. your is sunk in, and I think Ethanol didn't want to overbore it. It happened to a set that I was finishing up a few mins ago. I just couldn't get it flushed cuz there were really bad casting imprefection which also caused it to sink inwards. But its not as bad as yours.
Old 03-30-2012, 09:21 PM
  #975
Hacura's Avatar
@ Swoosh Thanks man
Ahh, that makes perfect sense. I'll clean up the little notch and clean everything with brake cleaner before installing.
Thanks for the help bud.
Old 03-31-2012, 07:42 AM
  #976
ethenol's Avatar
Yes that tube casting was pretty bad. Your runners had a lot of casting issues. The spacer is overbored for a reason. It will always have clearance for all size tubes. Your casting lines were very deep on that set. It does happen I am not going to oval out holes just to remove a slight casting imperfection. There is no horsepower loss because of that. How does the TB spacer look after the long trip?
Old 03-31-2012, 08:07 AM
  #977
Atlas.46's Avatar
sent you a couple questions in a message.
Old 03-31-2012, 10:09 AM
  #978
Hacura's Avatar
Keith, I appreciate the quick follow up bud. I don't care how it looks, I was only worried about the function and since there's no HP loss, it's a non-event. Both spacers freaking look awesome man. Everything else looks great and I'll be taking pictures for this thread during the install.
It feels like a slurricane outside right now so I'm contemplating doing the work today.
Old 04-04-2012, 08:48 PM
  #979
^ sooo hows it going?
Old 04-04-2012, 10:43 PM
  #980
swoosh's Avatar
Old 04-05-2012, 05:37 PM
  #981
Hacura's Avatar
Actually the re-install was going great until I broke one of the 5mm bolts that secures the injector housing to the runners . Called Acura and Honda dealers and it had to be ordered out LA so it's taking a week to arrive. Should be here tomorrow.
On another noob note, I dropped a bolt right next to the timing belt harness and heard it hit a few things and land on metal. I spent 2 hours fishing for that shit with a magnet and still can't find it. Would suck if it's stuck in a pulley.
Old 04-05-2012, 06:15 PM
  #982
swoosh's Avatar
Old 04-05-2012, 07:03 PM
  #983
should have let me know yesterday. I have extra of those 2 5mm bolt that hold the rail. Now they are in the trash.
Old 04-06-2012, 10:37 AM
  #984
All motor
Sonnick's Avatar
Does anyone know if the 09 TL manifold has the same size "ports" as the 3G? Basically my question is, if I were to *hypothetically* get my stock runners ported and *hypothetically* purchase the 09 manifold, would they line up as if I had our stock manifold? (Accord V6 and 3G TL manifolds are identical).
Old 04-06-2012, 10:50 AM
  #985
^ yes they will light up. are you talking about the TL-AWD 3.7L IM right?
Sonnick (04-06-2012)
Old 04-06-2012, 01:02 PM
  #986
All motor
Sonnick's Avatar
I hope they don't light up.....
Yea I meant the 3.7 TL SHAWD manifold. Thanks man.
Old 04-06-2012, 06:34 PM
  #987
swoosh's Avatar
^^^ you will loose power !!!
will post the link of a thread where someone did the same and posted his review !!!
Old 04-06-2012, 08:42 PM
  #988
^ Jiggga on V.6.P did the swap and gain power, but he also did cams.
Old 04-07-2012, 12:09 AM
  #989
swoosh's Avatar
^^^ guess i will hold off the setup until i get some cams....haha
Old 04-07-2012, 12:27 PM
  #990
All motor
Sonnick's Avatar
^ Wait, what? Lost power with the 3.7 manifold?
Old 04-07-2012, 06:07 PM
  #991
swoosh's Avatar
can you post the link to this thread bro ?
here you go Sonnick
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/4th-gen-sh-awd-intake-manifold-throttle-body-3rd-gen-728797/
Old 04-07-2012, 06:14 PM
  #992
http://vx6xperformance.net x/forums/7g-performance-discussion/211988-redrum-dyno.html
Old 04-07-2012, 06:28 PM
  #993
swoosh's Avatar
^^^ so he gained only 21WHP and 11WTQ with the following mods:
PCD V3
2011 Acura TL-S SH 3.7 TB (max Bored)
2011 Acura TL-S SH 3.7 IM
P2R Acura Tl-S SH Thermal Gasket
Outlaw Engineering IM Spacer
07-08 TL-S Cams
WOW !!! thats ahem sucks !!!.....you should I remember the test car with Rodney went from 224 to 249 (25WHP) with PCD's and Jpipe.....
also we cant really point out what he is gaining from what mod.....if you ask me, he lost some power there.....PCD's + Type S Cams + Bored TB should gain you ~30WHP....
Old 04-07-2012, 07:05 PM
  #994
He also had a CEL with the intake leak. So I am guessing his losing a lot of timing. He has new dynos and the numbers still don't add up compared to Cubano accord.
He needs to fix the CEL and get the car tuned.
Old 04-07-2012, 07:11 PM
  #995
swoosh's Avatar
^^^ dude i dont know the circles you run in.....who is cubano
Old 04-07-2012, 08:28 PM
  #996
Aghh.... Go join v6 p bro.
Inaccurate (04-07-2012)
Old 04-07-2012, 11:46 PM
  #997
Inaccurate's Avatar
who is cubano
He is the person (his post) that convinced me to take the risk on the single 3" exhaust. I was scared as heck of losing massive low and mid range power with the zero back pressure. But, he said in one on his post "trust me, the single 3 inch will gain a lot with no loss in the low range." And, I did trust him and he was right.
In my books, Cubanob247 is the man
I agree
Old 04-08-2012, 12:39 AM
  #998
All motor
Sonnick's Avatar
Cubano is awesome.
Thanks swoosh/ken for the links. And yes, Jiga has a leak in his injector O-ring, hence the CEL. Once this is fixed I think he will be in the upper 260s SAE untuned.
I refuse to believe the 3.7 manifold lost power. He is the only person said to have felt a decrease. Civicdrivr dynod 6whp/tq more throughout the powerband untuned on a ported 71mm TB, and a vacuum leak on his 3.2 CL-s before he went 3.6. He had I/H/P at the time I believe also. With a tune I think this manifold will make 10+whp over stock. Add the TL big bore throttle body and I'd guess an additional 3-4hp on top or the manifold. Plus the heat soak will dramatically decrease due to the Magnesium shell. Magnesium ftw. 09 TL manifold ftmfw.
Old 04-08-2012, 12:41 AM
  #999
I agree
yeah at first I was like nah man not enough backpressure. He shut me up pretty quickly after he did it and dyno the car. lol
Old 04-08-2012, 12:12 PM
  #1000
swoosh's Avatar
hahaha i am on there but dont visit there as often....maybe i should start
I agree
damn didnt know that....
Cubano is awesome.
why do you say the 09 TL ? isnt there a difference between the 09TL and the 11 TL SHAWD manifold and TB ??? (assuming you mentioned the SHAWD as well)....
i am thinking about it, but it will be an expensive deal....400 for manifold + cover....another 500 for TB then another couple hundred to just get em polished....
i might look into this after i get my cams/head work done....
Quick Reply: Ported/Polished Upper Intake Manifold and Runners!
