p2r DIY help!!!!!!!
Old Apr 7, 2012 | 02:18 PM
dragonsking91's Avatar
Go Pats!
p2r DIY help!!!!!!!
ok i following this DIY from a member on our on here but I'm at the point where i need to get the two long bolts that connect to the intake manifold.
https://acurazine.com/forums/3g-tl-2004-2008-93/diy-video-throttle-body-spacer-install-3g-garage-b-002-a-629143/
I'm the 2:55 right now but i can't get the bolts to come out even using the above method which is putting the two nuts back to back. When i turn the nuts, it starts to come out but not the bolts. Please help...thank you!
Old Apr 7, 2012 | 02:33 PM
Go Pats!
please help, my car is jacked up with the driver side tire removed so i can move my CAI and the battery is removed for more space. This is do or die mission. Help please ty
Old Apr 7, 2012 | 02:54 PM
Hacura's Avatar
dragon try tightening the bolts together a little more at the end of the thread. I've never done this on this particular area but it should work. I guess you can try to spray a little PB blaster in there. If you have a friend, get him to grab the non-threaded portion with a set of good pliers and help you turn at the same time. GL
Old Apr 7, 2012 | 02:59 PM
Go Pats!
ok i got the one of the bolts to come out but now the two nuts is stuck in there i can't get it out
Old Apr 7, 2012 | 03:35 PM
rooster415's Avatar
it would be better if you get some vise grips and turn the bolts.
Old Apr 7, 2012 | 04:07 PM
thisaznboi88's Avatar
you need someone help you. First u take off the outer nut and then the inner nut. You have to really go at it.
Old Apr 7, 2012 | 05:35 PM
Go Pats!
i just finish the installation. Thank you everyone for their inputs
Mike734
Dec 10, 2021 01:25 PM
tsx_boy
Dec 13, 2019 08:33 PM
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
