Obdii scanners advice
Old Jan 15, 2012 | 12:01 AM
DomGSR-T's Avatar
Question Obdii scanners advice
I would like to get inputs on scanners model/specs, I never used a scanner before and I need one that can record all O2 voltage values to tune my AEM FIC and also monitor knock/ignition retard if any occurs... If possible one that could connect to a laptop. Thanks for your help!
Old Jan 16, 2012 | 12:21 AM
Inaccurate's Avatar
Not possible to get the monitor knock/ignition retard monitoring. Please see link below for info.
Data Loggers (click here)
Old Jan 16, 2012 | 09:32 AM
KN_TL's Avatar
PM Libert69. He has the following:
http://www.autoenginuity.com/product...ware.html#EI08
It shows the ability to see all ECU parms including the knock adv/retard data.
http://www.autoenginuity.com/Honda-A...tems-List.html
I'm also not sure about the Honda HDS/HIM. I would think that would extract that data as well. bmeyer has this unit and may be able to help you. He also has a lot of knowledge about the o2 skew function of the F/IC that he could possibly assist with.
How the software interprets it and give it to you is unknown to me. I don't have either so I can only give info that I can read.
Old Jan 16, 2012 | 03:32 PM
Inaccurate's Avatar
Autoenginuity was never able to get this functionality to work for Bert.
Old Jan 16, 2012 | 08:18 PM
libert69's Avatar
18psi
^I guess my car never experienced any knock. Thats why it never showed up on the logs
Old Jan 16, 2012 | 09:12 PM
DomGSR-T's Avatar
Thanks for the link! Ok but if the actual knock retard is not available can we see the actual timing? If the timing goes down from time to time at x load/???? rpm i'll know that there's knock retard at that point. And from the link you gave me, does they are all plug and play for a 3G TL?
Old Jan 16, 2012 | 10:08 PM
DomGSR-T's Avatar
Hum looks like all the obdii connector the same I think this one looks like a nice tool!:
http://www.auterraweb.com/dyforwiusb.html
Old Jan 16, 2012 | 10:24 PM
Hi speed's Avatar
runnin a little boost
The dash dyno is very nice. If you want something to watch while driving it's about as good as it gets. If you just want to reset codes and look at data logging once in a while it can be had for much cheaper at obd2.com which uses your laptop to do the logging.
Old Jan 16, 2012 | 10:40 PM
Inaccurate's Avatar
This is the same company that makes the DashDyno. The link above is their interface that allows you to read from a laptop versus having the DashDyno.
Old Jan 16, 2012 | 10:58 PM
Inaccurate's Avatar
Yes, it does show real-time timing. But, it is impossible to detect retard by looking for a dip. The timing is always jumping around even under the most ideal conditions. The ecu is always tweaking and re-adjusting the timing based on many variables. So, the timing is never a smooth line where you would be able to see a dip from retard.
In the link for the scanners, I would *think* that all are plug and play for our car. Our car is a OBD-II (also called OBD2) interface. All scanners that I have seen are OBD2 compatible.
Old Jan 17, 2012 | 01:22 AM
swoosh's Avatar
takin care of Business in
https://acurazine.com/forums/showthread.php?p=13439136
Jamus22
Jun 11, 2023 10:08 AM
Jul 16, 2017 07:33 AM
soupi
14
Nov 15, 2015 11:15 AM
