NSX pistons
NSX pistons
i was looking at carillo pistons and for the nsx the piston diameter is 90mm i think i read somewhere that the j series except for 3.7 is 89mm maybe a possible swap? im sure theres other technical parts to it and im definitely sure someone is going to have the information but i am wondering if we could just hone or bore out a little bit more cylinder wall
inch mm ovrstd stroke
SC7073 3.504 89.00 +2.0mm 84 153 1.131 8.4 23 1.0 x 1.2 x 2.8mm4(f20cpistons)
SC7073 3.504 89.00 +2.0mm 90.7 149.7 1.131 9.0 23 1.0 x 1.2 x 2.8mm 4 (f22c)
SC7035 3.504 89.00 +2.0mm 90.7 143.15 1.220 9.0 22 1.0 x 1.2 x 2.8m4(h22sleeved)
SC70404 3.504 89.00 +3.0mm 86 139 1.181 9.0 22 1.0 x 1.2 x 2.8mm 4 (k20a1,2,3)
SC7080 3.543 90.00 STD 78 152 1.184 9.0 22 1.0 x 1.2 x 2.8mm 6 (nsxc30)
i know they arent related ive done research. but ive looked up pictures of both j series pistons and c series pistons and if the pistons are same bore and where it connects to the rods with the pins looks really similar i dont know why with a little modification it wouldnt be possible. its not like theyre electronic parts and incompatible because of different operating systems. if it fits i dont know why it wouldnt work
pictures mean squat when working with engine tolerances. wrist pin location, ring landing, and piston length all need to be correct. why not work with a j piston instead of all the headache of working with a foreign piston.
No j series pistons are forged. Idk hype about rl pistons but it's just a rumor that it's forged and higher compression. Rl heads or gasket are suppose to be difference in compression. But I know nothing technical about pistons this is all learning experience to me. I've seen only two posts about forged j series custom pistons and rods. Does anyone know the price on them?
Whats up with RDX owners?
You can bore out a J block to 90mm. However, thats the service limit, so no boost.
I think you need to do a bit more research on the subject, since its as simple as wrist pin location and bore diameter.
For the record, red text = sarcasm.
I don't see red text
civicdrivr (04-19-2012)
SidhuSaaB
05-30-2020 12:40 AM
acuratl26
04-23-2020 07:30 PM
09-17-2015 09:01 PM
