Now I Did It - Help Please
Old Sep 1, 2007 | 08:04 PM
07V6SE's Avatar
Installing my CAI. Have everything torn out, now I can't seem to get the rubber boot on either the CAI of the throttle body. Any soultion to this/lube etc. Can't drive anywhere now
Old Sep 1, 2007 | 08:12 PM
Xx06SickspdTlxX's Avatar
06 TL 6spd. Navi/A-spec
I like to use silicone lube just try not to get any inside the intake tube and you should be fine!
Old Sep 1, 2007 | 08:14 PM
07V6SE's Avatar
anything household....uh oh
Old Sep 1, 2007 | 08:21 PM
Inaccurate's Avatar
Windex. It is soapy and slippery. However, it will dry to leave a grippy fit. Do not use lube that will remain slippery - Hint = slip on, slip off. If you have no windex, make a mild solution of dish soap.
Old Sep 1, 2007 | 08:24 PM
07V6SE's Avatar
Thankis Inaccurate...I'll try that. I think I have some. If I don't, will soapy water hurt anything. Greenhorn here.
Old Sep 1, 2007 | 08:26 PM
07V6SE's Avatar
Will any glass cleaner work? I have some generic, but it says it has ammonia in it.
Old Sep 1, 2007 | 08:31 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
I put the rubber piece on the ram than forced it onto the throttle body... the bottom part was giving me hell to slip over so I used my fingers to slip it over (throttle body was still hot which sucked_ but it it worked)
best of luck
Old Sep 1, 2007 | 11:55 PM
07V6SE's Avatar
Finally installed. I was prepared to hear the whistle which is common, but unsure of a noise when blipping the thottle. Sounds like something tapping a tin can.
Also, my radio clock is blinking and can't reset after taking out the battery.
Is this a possible error?
Old Sep 2, 2007 | 12:30 AM
94 DC4 RS LSV/Turbo
Tin can?
Clock blinking?
Unplug battery again
I installed a fujita... it sounds like a wolf screaming from getting f*cked in the a$$
Ps. My clock's time didn't change my install took an hour and it isn't an hour slow... just punched in navi code then punched in radio code... 1 thing I forgot was to plug the fog light back in (I unplugged by mistake) took me 5 minutes to figure out where the little harness gets plugged into... and by that time I had break dust all over my hands
Old Sep 2, 2007 | 12:48 AM
07V6SE's Avatar
yes a tin can....thats the bset way to describe it. I blip the throttle, tin can sound. I turn the car off, it does it once also.
Not a constant tapping...just sounds like the valve in the throttle body or something.
Old Sep 2, 2007 | 01:06 AM
enigmaos's Avatar
Too Fast TOO FURIOUS
I have heard of that "tin can" sound before on a different car with SRI when shutting off. I think it is the metal valve/flap in the TB. I am not sure though.
Old Sep 2, 2007 | 01:31 AM
94 DC4 RS LSV/Turbo
It might be ur filters touching some portion of either the battery braket or the side of the bumper
Old Sep 2, 2007 | 02:07 AM
Inaccurate's Avatar
When blipping the throttle, the engine will slightly twist on the motor mounts. This will be enough to cause the CAI tube to be pushed close to the car body to lightly hit against the body. WITH THE ENGINE *OFF*, examine the CAI tube as it snakes thru the body. Look closely at the area behind and under the battery. This is the tightest fitting area for the pipe. This opening will be a square shaped hole. If the tube has less than approx 1/4 inch clearance anywhere along it's length, this might be your problem.
To fix it, loosen one of the clamps on the pipe/throttle body to allow the pipe to be rotated. While looking at the tight opening behind the battery, twist the pipe until it is centered in the opening. Now, tighten the clamp. Verify again that the pipe is still centered.
Old Sep 2, 2007 | 02:28 AM
07V6SE's Avatar
For fear of water intrusion, I only installed the CIA as an SRI. The more I hear the sound when turning off, the more it sounds like air rushing out creating a pressurized sound maybe. I'll go back in tomorrow and check everything again.
Is the SRI suppose to butt up agains the throttle body when clamped together? The rubber tube supplied by K&N seems awful short, so I'm guessing that maybe with your suggestion of motor twist, the throttle body is actually hitting the end of the SRI....or is that they it is meant to me.
I apologize for all of the questions as this is all new to me.
I do appreciate the feedback.
Old Sep 2, 2007 | 02:34 AM
94 DC4 RS LSV/Turbo
From my experiences installing past intake cold/short I've never put them that close together so they touch... try and see if that is the culprit, put them as close as you can without actual touching...
Old Sep 2, 2007 | 05:34 AM
ayethetiense's Avatar
.:KCCO:.
hahahaha
Old Sep 2, 2007 | 01:14 PM
07V6SE's Avatar
Ok, to make sure I did everything right and peace of mind, I took it to 2 different places this morning where several of the techs have experience doing the SRI install. They looked over everything and said what I was hearing is perfectly normal. Said it was a good install. When blipping the throttle, the sound I am hearing is the butterfly in the throttle body.
The noise I was hearing at shut off was just the pressurized air releasing itself.
Just want to thank everyone for all of their help and advice.
After installing the Stage 2 setup and the SRI, I'm done modding for awhile
Now I have a mean sounding 4 door grocery getter with 2 kid seats in the back
Old Sep 2, 2007 | 01:26 PM
94 DC4 RS LSV/Turbo
holy moly
Old Sep 2, 2007 | 01:34 PM
07V6SE's Avatar
Holy Moly as in good or bad? haha
Old Sep 2, 2007 | 02:27 PM
94 DC4 RS LSV/Turbo
good man awesome actually
Old Sep 2, 2007 | 02:33 PM
07V6SE's Avatar
thanks lol
ill post a few pics....even if it is an Accord. Everyone on here has been more than helpful. Moreso than any of the other boards.
Old Sep 2, 2007 | 03:04 PM
ballinfizzle89's Avatar
FizzyStatus!
Haha that's what we're here for..even though I couldnt help you with the CAI haha.
How do you like the SRI? thinking of doing this real soon
Old Sep 2, 2007 | 03:21 PM
07V6SE's Avatar
Love it so far. Getting a good feel where the sweet spot is for the automatic. I love it at stop lights. People just see a tinted up Accord, until I hit it. Sounds mean. Here's a few pics.
What do you think?
http://i220.photobucket.com/albums/d...driverside.jpg
http://i220.photobucket.com/albums/d...wResonator.jpg
http://i220.photobucket.com/albums/d...raightPipe.jpg
http://i220.photobucket.com/albums/d...ax96/KNSRI.jpg
Old Sep 2, 2007 | 08:41 PM
.:KCCO:.
thanks lol
what? its not a TL? if i knew i wouldnt have said anything. hahahahaha j/k
you'll find that most of the people on here are helpful compared to other forum members.
Old Sep 2, 2007 | 09:14 PM
FizzyStatus!
Hahah...yeah dude I was looking at G35Driver the other day just to check out some different exhausts and it's like everyone was hating on something/someone. haha kinda annoying..
07V6SE..the Accord looks real clean though..i like the white Definitely looking into the SRI
Old Sep 4, 2007 | 12:24 AM
07V6SE's Avatar
Heres 2 sound clips while driving and windows up.
Quality is poor, only becuase I used my Blackjack. Not bad for a little phone though.
http://s220.photobucket.com/albums/d...t=MOV-0002.flv
http://s220.photobucket.com/albums/d...t=MOV-0004.flv
Old Sep 4, 2007 | 01:56 AM
94 DC4 RS LSV/Turbo
I wonder how hard it would be to do a TL conversion to the front end of an av6 (hint hint)
Old Sep 4, 2007 | 03:52 PM
07V6SE's Avatar
could rebadge it.
Old Sep 4, 2007 | 04:02 PM
FizzyStatus!
Sounds real good..haha show that to those guys that said it would sound like ass
Stillhere-haha itd be hard enough..speakiing of that though, I saw this Civic with a WRX converted rear..looked oddly cool
Old Sep 4, 2007 | 04:45 PM
94 DC4 RS LSV/Turbo
nah man I've had my fixes of TSX with Euro R and RSX with Honda Integra converts... lets just go DEBAGED on your AV6 and call it a day...
Old Sep 4, 2007 | 04:55 PM
07V6SE's Avatar
I'll probably leave it badged, but getting the urge to do something else, so I went ahead and ordered the dynomax...going to try stage 3.
If I don't like it, I'll convert back to stage 2.
Either way, I'll sell which ever one I dont keep.
Old Sep 4, 2007 | 05:10 PM
FizzyStatus!
stage 3 FTW for the win
Old Sep 4, 2007 | 06:37 PM
07V6SE's Avatar
Here it is at idle...stage 2
http://s220.photobucket.com/albums/d...t=MOV01206.flv
