Nitrous Question!!!!
Old Mar 14, 2008 | 01:39 PM
CoiledOutTL's Avatar
6th Gear
(First of all Im new to the TL forum, So HI to all.)
Q: Would a 75 shot be SAFE for my 05 TL
Any help would be appreciated....
Thanks, Cody
Old Mar 14, 2008 | 01:44 PM
TylerT's Avatar
Turd Polisher
I've heard 75 shots are pretty safe for the TL (according to DIRTYJOHN), anything higher is kind of risky.
Old Mar 14, 2008 | 01:45 PM
RYAN97812's Avatar
8 second & 150 mph member
Cody, without a doubt as long as its a WET kit, try NOS for their drive by wire wet kit, it suits the TL perfect. You will have to tap into the stock fuel line for the fuel supply. I did a TL with the comptech s/c AND a 50 hp wet kit. Car ran 13.1 @ 108 on street tires with an auto.
Old Mar 14, 2008 | 03:09 PM
6th Gear
YEAH MY BUDDY HAS A DRY KIT FOR A GOOD DEAL, BUT I HAVE HEARD GOOD AND BAD ABOUT WET AND DRY KITS?
IF YOU TAP INTO THE FUEL RAIL, THAN YOU GO TO USE THE NITROUS IT SUCKS ALL THE FUEL TO THE INTAKE AND OUT OF THE RAIL AND LESS FUEL FOR THE INJECTORS AND COULD POSSIBLY LEAN OUT???
BUT A DRY KIT WOULD LET THE SAME AMOUNT OF FUEL TO THE INJECTORS???
Thats just what i heard but please let me know if i am incorrect...
Thanks,
Old Mar 14, 2008 | 03:43 PM
TLdriver022's Avatar
50 shot is better. I would say anything over 75 is very dangerous on stock internals.
Old Mar 14, 2008 | 03:44 PM
RYAN97812's Avatar
Dry kits work fine for mass air flow systems NOT speed density systems. The returnless fuel system in the tl is more then adaquate for 75 hp. I wouldnt spray more then that on pump gas as you are only relying on the knock sensor to retard timing and after the sensor picks up detination times almost up for your motor. I would suggest a 50-50 mix of 100 octane and 93 octane to be on the safe side. Your not talking about alot of power here (as compared to my race car that i spray 300hp on a single stage and 400hp on a dual stage this year) but i like to tune and run on the conservative side. You can always play another day if your safe or go balls out for a day and and find out the wrong way what goes wrong. The s/c tl that i did with nitrous DID blow up. The car had a bad knock sensor circuit in the acm and i told him not to beat on it till i we replaced the acm, we'll he didnt heed my warning and SPARAYED it racing an evo till he gernaded the motor. I put a motor in the following day, $2000, hard lesson learned.
Old Mar 14, 2008 | 05:28 PM
6th Gear
Thanks For The Info Everyone... I Appreciate it!
Old Mar 15, 2008 | 05:55 AM
722ish's Avatar
71Q
Ryan, i hear that...
Sometimes i wonder if it isnt the other way around. Sometimes the people arent safe with spray, rather than the motor, let alone any modifications.
this isnt directed at you coiledoutTL, just a general statement about people
Good luck with your car!
Old Mar 15, 2008 | 07:50 AM
MWalsh9152's Avatar
all work and no play
Not that I have any intention of spraying my TL but I had a dry kit on my fox body mustang for years it was speed density, and I never had a problem. I was running way more than the kit was rated for too I think 150hp? 12.0 @112 on a stock motor is the mass air recomendation something more related to newer cars? Im just curious
Old Mar 15, 2008 | 03:19 PM
bent09's Avatar
horny =
Knows his stuff!
I ran a 75 shot NX Wet Kit with no problems. The problem I had was all the extra can get it upthere!
NX Wet Kit- $800
Bottle Warmer kit- $200
Bottle Opener- $ 200
Autometer gauges- $150
I have ran nitrous on:
97 Accord- SE - 4 banger
97 Accord EX- v6
01- CLS
03- CLS
I could probably count on two hands the number of times I sprayed. It is all in how you use it.
Old Mar 15, 2008 | 08:00 PM
RYAN97812's Avatar
the mustsng dry kit uses fuel enrichment by appling regulated nitrous pressure to the fuel pressure regulator to add more fuel pressure thus adding more fuel through the fuel injectors. You cannot run a dry kit with no fuel enrichment, well you can for sometime LOL you get the point.
I ran a basically stock 305 in my camaro for two with a 150 hp shot 11.43 @118 with over 200!!! passes on nitrous. Sold the motor with less then 9% leak down in all cylinders. Stock rods with arp bolts, stock crank, kb hyperutectic pistons, small cam 262 .472 stock heads, 650 demon carb, rpm air gap intake. New motor 9.10 @ 153 on a 200 hp shot. 434 sbc. I can keep goin but no need to.
The topic is what is SAFE for the TL. I would without a doubt run a 100 hp WET shot on my TL with 100 octane race gas. The motor and fuel system WILL handle it. I would rather be able to retard my timing instead of reling on my knock sensor to do the job but i am confident that the octane in the gas will prevent the detination. I would definetely run two heat ranges colder on the spark plugs with 75 or 100 hp worth and one heat range colder with 35 or 50. I would run a heater and a purge along with the kit.
Old Mar 16, 2008 | 01:50 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
off topic: ^ DUDE your lady's got the new ninja 250... I just got on one last week... black... it looks like a baby zx6 doesn't it...
on topic: I was just watching some youtube drag strip vids with guys running nos on stock motors... some blow some dont... it is a gamble... the saying goes you gotta pay to play
Old Mar 16, 2008 | 11:21 AM
MWalsh9152's Avatar
ok so its a fuel related issue, I was just curious what the difference was in the TL. My only other experience was tuning a fogger kit on my friends Musi built 406 sbc...sounds like a similar setup to yours 8.90 152
Old Mar 16, 2008 | 06:48 PM
RYAN97812's Avatar
Bike is on order, ordered it about a month ago. Its not a gamble, its about doing it right and deciding whats right for your combo. People throw everything they can at a stock motor THEN add nitrous for as cheap as they can and never bother with upgading the fuel system and so forth.
AH musi yes a good nitrous guru. I have had the pleasure of dealing with a few of his motors. I have a Scott Shafiroff 434 sbc that makes 675 hp and 630 ft lbs on 100 octane gas set up for the street Never dynoed it on nitrous but have run 200 hp worth so far down the track, that was 9.10 @ 153 ran out of gear and was spinning the motor too high (7400 rpm) motor makes max power at 6800 so im screaming her down the track on spray but perfect on motor 9.89 @ 137 mph.
Old Mar 16, 2008 | 10:57 PM
MWalsh9152's Avatar
the musi motor actually started its life coming from Shafroff, started its life in a footbrake bracket car, then was sent to Musi while the 10.5 car was being built it made 600 and change all motor running 9.80-90s the 10.5 car ran bracket consistant, but needed a dominator and a tighter converter, it made just around 900 hp with a pretty conservative tuneup. I wish we got to play with that car more, he ended up tearing it apart and refuses to put it back together with anything less than a 7 second motor.....so it looks like I'll have to wait a lil while longer
ttimberlak443
21
Oct 22, 2016 10:23 PM
navtool.com
3G MDX (2014-2020)
32
Jan 20, 2016 11:43 AM
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
