Nitrous Help!!
Old Nov 28, 2010 | 07:42 PM
josiel's Avatar
Nitrous Help!!
hey everyone whats up im thinking about doing a nos install on my 06 tl can anyone give me any tips or ideas on this and also whats a safe shot to run
Old Nov 28, 2010 | 10:27 PM
phee's Avatar
I got the Shifts
a safe shot is nothing if you dont tune it.
1. buy an a/F guage
2. buy an FIC
3. buy a knock box
4. buy a nitrous kit (wet)
5. start with a 75 and work slowly up
Old Nov 28, 2010 | 10:39 PM
I hate cars's Avatar
Search for "Inaccurate". He has done a ton of research on nitrous and has one of the most elaborate nitrous/methanol setups I've seen.
Old Nov 29, 2010 | 12:51 AM
Inaccurate's Avatar
I have not posted much info regarding my Nitrous Methanol Injection. However, you might benefit from the few things that I have posted. Please do a search on "nitrous methanol" by Inaccurate. Select "posts", not "thread" for the result output.
Plus, do some searches on Acurazine (not just the Third Generation subforum). Plenty good info to give you an idea of how much boost to aim toward.
My project is still under construction. Please feel free to ask if you have any specific questions. My project requires a large methanol tank to be installed.
Old Nov 29, 2010 | 02:02 PM
josiel's Avatar
Nice pics inaccurate thanks guys for you help
Old Nov 29, 2010 | 02:06 PM
josiel's Avatar
What do u guys mean by tuning what exactly do I have to tune
Old Nov 29, 2010 | 03:56 PM
Inaccurate's Avatar
Please read this thread to see if you really want nitrous (click here)
For tuning, the primary concern is preventing detonation. Other tuning is your air/fuel mixture while spraying the nitrous. Also, you will need to monitor the pressure in the nitrous bottle too because the pressure heavily influence the air/fuel mixture while spraying, in addition to influencing the overall level of nitrous boost being injected.
Your biggest concern will be how to prevent detonation. You have two options. Use an engine management device, such as the FIC or J&S SafeGuard (click here). Or to use methanol as the supplementary fuel for the wet nitrous system. This is the route that I am taking to control the detonation.
Here are my onboard gauges that I will use to tune my system.
Old Nov 29, 2010 | 04:51 PM
ethenol's Avatar
Mom why is there two?
Inacc.. why nitrous express? I have always used zex. personal preference or is there a big reason for this. Are you also going to use a progressive controller? I have used them in the past. Just wondering what numbers you are going for. Jet size numbers not hp. I am a huge fan of nitrous.
Old Nov 29, 2010 | 05:00 PM
ethenol's Avatar
Question again are you running it off of the Throttle body WOT wire? Or a separate micro switch. If its on the TB what wire is that one? Or just PM me with a pic. I had a nitrous powered cl we had set up that way dont know if the TL's can be done the same way
Old Nov 30, 2010 | 01:20 AM
Inaccurate's Avatar
No. I hate the concept of progressive controllers. Below is a quote from someone that summarizes my feelings about progressive controllers.
If you progressively spray your nitrous with a controller (or eventually with Petrik's flash software) the nitrous solenoid is pulsing about 5 times per second, but the intake valve is opening and closing almost 100 times per second. The fuel injector is also opening and closing 100 times per second. What does that mean... well for a dry system the result is that the flow of nitrous can pulse or vary by quite a bit depending on how far the solenoid is from the nozzle exit, but the motor doesn't know this. Some engine cycles it opens the valve and gets more nitrous. Some cycles it gets less. On average, your O2 sensor might think its dead on, but in actuallity, the motor is going lean / rich / lean / rich 5 times a second but averagin out in the tail pipe. This causes the occasional detonation and big crank vibration problem due to the enourmous difference in cylinder pressure from cycle to cycle across the 4 cylinder. I ran a single cyclinder (low RPM)development dyno lab at WPI in the Eighties and had an opportunity to measure and photograph this phenomina. Kind of scary. This is one of the reasons why nitrous can be hard on motors EVEN IF you think you have the perfect tune.
My Nitrous Methanol Injection System is not a "store bought" kit. This is a custom system that I designed myself from concept to implementation to tuning. Each component of the system is hand picked (aka, cherry picked). I favor no company in particular. Just who ever makes the best individual component.
For a nitrous tank, I feel that NX produces the best tank because NX uses a valve specifically designed for nitrous system which minimizes internal diameter variations.
I will be using a TPS which taps into the TB wire that actually senses the throttle position, not the pedal position.
The Throttle Position Switch will read the actual closing of the throttle butterfly between shifts. Thus, the nitrous will be turned off while the trans is shifting. This will allow the clutch pack to couple (lock up) without being under the strain of the boosted torque.
The correct wire is the signal wire at terminal 1 of the 6P connector on the TB. This is the topmost wire, which is Red/Black wire. However, I will be tapping this wire from within the car, not under the hood. The wire runs to the Throttle Actuator Control Module under the dash. I will tap into the wire from under the dash.
Old Nov 30, 2010 | 03:00 AM
libert69's Avatar
18psi
So no juice between shifts huh. NICE. Hopefully you wont have the 2nd gear issues I was having.
PLEASE GOTO THE STRIP WHEN THIS IS COMPLETED.
High 11's
Old Nov 30, 2010 | 03:19 AM
Inaccurate's Avatar
Without regards to traction limitations, I estimate that I am low 13 now with n/a. With nitrous, I estimate low 12, but no where near 11's.
Good enough to beat 99.9% of the stuff on the roads during daily commutes.
I probably will never take it to the track. Too many rules that my car would not be able to pass. But, I will have a lot of MPH vs Time data logging.
Old Nov 30, 2010 | 05:35 AM
ethenol's Avatar
Makes sence.
gavriil
Nov 1, 2005 03:17 PM
stangg172004
May 30, 2005 05:50 PM
haiduc
Mar 3, 2004 10:07 AM
htownaccord
Feb 23, 2004 10:34 PM
civic4982
Dec 4, 2002 12:07 AM
