New S/c, Dyno Tune??
Old Mar 7, 2007 | 01:00 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
as some of you know, i just supercharged the 06 6MT with the last comptech supercharger ever produced.
about a week later, check engine light comes on, as expected i suppose.
but i am concerned i need to dyno tune it, maybe it is not running like it should
i know there is no HONDATA but i believe there is a VAFC? s/c guys, help me out
still dont have freakin exhaust on it either. thanks comptech
Old Mar 7, 2007 | 01:12 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
Oh Yeah And It Surges A Lot
Old Mar 7, 2007 | 02:55 PM
dan.....k's Avatar
Mine doesn't surge a lot. I haven't had a CEL yet either. Maybe a FPR problem? What code did it throw?
Old Mar 7, 2007 | 03:09 PM
StYLeZz101's Avatar
when u say surge what do u mean?
Old Mar 7, 2007 | 03:18 PM
encrypted03's Avatar
Pull the CEL code first, then you'll know where to begin
Old Mar 7, 2007 | 08:49 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
yeah i know, at qtr throttle or even 1/8 it bucks like a mother fer
i probably should pull the code, just need to get a scanner
Old Mar 7, 2007 | 11:00 PM
k6biv's Avatar
302.7 WHP 251.3 Torque
Hello:
I get mine installed on Monday. Please let me know what you find out.
Thanks,
Tim
Old Mar 7, 2007 | 11:02 PM
k6biv's Avatar
Hello:
Did they do the fuel pump mod?
Tim
Old Mar 8, 2007 | 12:28 AM
mmcv6's Avatar
313.4WHP& 284.6TQ
Mine used to surge alot, but not anymore. Pull the code need to figure out the problem. If its knock 1 sensor 1 just reconnect the knock/map wire back to stock.
Tim, so is c&c auto doing your install on monday or a different shop local to you? If you do let c&c auto do your install in southern california let me know so I can help you with the surging issue.
pm me or call me if you let c&c auto do it.
Also Tim, no fuel pump mod its the fpr mod.
cool
Old Mar 8, 2007 | 08:36 AM
k6biv's Avatar
Hello:
I have found a local shop, who has done 3 installs of Comptech SC. I'm looking to them to do the install this Monday. UPS has the SC that was shipped from Escondido Acura. I will pick the boxes up this morning.
I will place a call today to the Hondata place to see what they might recommend.
There has been many SC installed and if done correctly, from the reports I have heard, work very well without any additional tuning.
Why have some folks had problems?
Tim
Old Mar 8, 2007 | 08:57 AM
bklynpanman's Avatar
321 whp SAE
if installed correctly, won't throw a CEL
Old Mar 8, 2007 | 09:00 AM
03TL_S's Avatar
2006 TL-S.C. 6mt
so what im gauging after all these comments is that the fuel mod may have no been done correctly. i guessing when he put the fpr in the "crush box" he may have not hit it properly.
soon i will know the CEL and go from there/
Old Mar 8, 2007 | 09:30 AM
321 whp SAE
when i had my fpr problem, i never threw a code.. curious to see what your code is
Old Mar 8, 2007 | 10:05 AM
03TL_S's Avatar
2006 TL-S.C. 6mt
yeah its bucking/surging pretty bad if i dont throttle it just right
do you have an engine management system? like for the fuel? a VAFC i think it is
Old Mar 8, 2007 | 10:42 AM
03TL_S's Avatar
2006 TL-S.C. 6mt
i mean is it hard to f up the crushing step?
Old Mar 8, 2007 | 12:24 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
did they crush it with the old or new tool for the fpr?... If you throw a code most likely its not the fpr. It could be, but most likely not.
Tim, its good you found a local shop so you dont have to drive down. Good luck.
Old Mar 8, 2007 | 12:32 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
i'll probably be calling the so cal shops as soon as i get the code, he used something that looked like a metal test tube, but shorter, and fat, with a cap to it? (best explanation i can do)
Old Mar 8, 2007 | 01:59 PM
03TL_S's Avatar
2006 TL-S.C. 6mt
P0325
Knock Sensor 1
Circuit Malfunction
Bank 1 or 1 Sensor
wtf does this mean
Old Mar 8, 2007 | 02:41 PM
mmcv6's Avatar
313.4WHP& 284.6TQ
just reconnect the map/knock wire back to stock.
MrHeeltoe
20
Feb 23, 2023 01:54 PM
Jul 16, 2017 07:33 AM
ExcelerateRep
Oct 14, 2015 08:20 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
