New pickup!!
Old Oct 10, 2013 | 11:17 AM
SirSwag24's Avatar
New pickup!!
Got a good deal on this. Coupling with a dynomax resonator and a 3rd muffler delete. Can't wait to see what this sounds like
Old Oct 10, 2013 | 11:36 AM
Joneill44's Avatar
Cant see sh!t
Old Oct 10, 2013 | 01:54 PM
EvilVirus's Avatar
ok
Old Oct 10, 2013 | 03:45 PM
SirSwag24's Avatar
Finally got a hand of this and how it works! sorry about that. this is why my car sounded like a dying cat:
Old Oct 10, 2013 | 05:48 PM
vietxquangstah's Avatar
Why did you buy a magnaflow high flow 3rd cat when you can just buy a test/race pipe from one of our vendors here like heeltoe or excelerate?
An actual straight pipe will yield more performance gain & sound louder while costing less than a high flow 3rd cat.
How much did you pay for that if you don't mind me asking?
Old Oct 10, 2013 | 07:10 PM
EvilVirus's Avatar
I think he is only going for sound, butt remember you get what you pay for so it could sound worse
Old Oct 10, 2013 | 08:59 PM
SirSwag24's Avatar
I live in Nj. Its illegal to not have the 3rd Cat and it won't pass inspection
150
Old Oct 10, 2013 | 10:28 PM
150
Oh that sucks about the 3rd cat part. I'm surprised they actually do a visual inspection of the under carriage of the car.
$150 isn't a bad price at all than since 3rd cat deletes is illegal.
Old Oct 10, 2013 | 10:32 PM
SirSwag24's Avatar
Yeah, so I put that in and straight pipe all the way back. I wonder if putting a dynomax resonator in would help beefen up the sound a bit
Old Oct 11, 2013 | 01:36 AM
Richie v6's Avatar
Former Sponsor
NJ and NY are two of our largest markets. I doubt they do a visual inspection.
Old Oct 11, 2013 | 08:15 AM
SirSwag24's Avatar
I'm going to look into that. I also believe (correct me if im wrong) that the O2 sensor is before? the third cat so the readings would be fine because the TL has 2 pre cats.
I would like to change the piping in the future though, i just figured getting rid of that noise was a priority.
Old Oct 11, 2013 | 11:04 AM
AccordFlex's Avatar
Im sure you could put in a test pipe in place and throw on a heat shield over it and they would never know.
Old Oct 11, 2013 | 12:21 PM
You're right. The 3rd cat does not have a o2 sensor connected to it so everything will be fine. The o2 sensor are connected to the PRE-CATS which is before the j-pipe.
This is what I would do if you are worried sirswag. I believe there's actually a test pipe that has mounting points so you can bolt in your factory heat shield to it and make it look factory.
"The pipe also includes tabs to reuse the OEM heat shield. Also includes hardware and gaskets."
http://www.heeltoeauto.com/xlr8-perf...roductid=65452
or
http://www.heeltoeauto.com/atlp-race...roductid=63699
Old Oct 11, 2013 | 12:28 PM
SirSwag24's Avatar
or
http://www.heeltoeauto.com/atlp-race...roductid=63699[/QUOTE]
now what is the benefit of having the test pipe instead of the magnaflow cat? pros and cons?
Old Oct 11, 2013 | 12:29 PM
SirSwag24's Avatar
or
Old Oct 11, 2013 | 05:47 PM
test pipe is less restrictive than a regular high flow cat due to 0 cells. Its just a hollow tube.
Old Oct 11, 2013 | 09:19 PM
pohljm's Avatar
technically its 1 cell
mitchigan
May 29, 2019 06:53 AM
rcs86
Aug 2, 2016 06:52 PM
ArcticDuk
Jun 29, 2016 06:57 AM
Rob144
Sep 21, 2015 08:18 AM
