New '07...little help?
I've just grabbed an 07 base CGP with 77k on it. It runs like new and I grabbed a 4 yr / 80 k warranty for damn near cost. With [Canadian] summer coming around july, I hope to have a ton of mods installed. So far the WORST thing about this car is these god awful rotors. I've warped one already, and after reviewing a few posts via the search button I've come to believe the slotted Stoptech from Excelerate are a solid OEM upgrade. Pads as well, but that is a different topic completely.
What I would like to do consists of small engine upgrades, as well as a few style. Engine wise I am looking at (like a similar topic below) CAI vs OEM K&N replacement, this Dynomax resonator delete, possible some mufflers though I don't want every cop in a 4 block radius knowing I'm driving over 3k rpm. Also I noticed these NGK Iridium plugs are fairly good to install over stock?
I believe this car hasn't had anything replaced/upgraded on the engine (except PS hose). With that being said, what are a few recommendations you guys may have that would benefit my needs?
What I need: nothing, the fact I'm getting into a car turning the key and driving away is enough.
What I want: A little more power than it has, nothing that will require super modding, or will cause harm to the engine (may void my warranty?) Also if there are any ways that I can reduce my mpg without driving like a grandma that don't require the hundreds of dollars this tuner piece costs, that would be great.
Take it easy
Take it easy
NGK iridiums are stock plugs and are good for 105k miles
I suggest you upgrade the jpipe to an aftermarket jpipe with better and more efficient bends.
there are two latest and greatest jpipes which can be found from http://store.excelerateperformance.com/ and http://rv6-p.com/
They both gain about the same horsepower; so I would not split hairs on which one gains more.
this is a nice gain of about 15 horses.
I would Do this mod before you chop up your factory exhaust. because chopping up the factory exhaust might lead to sound problems when adding a jpipe. and you're mostly after performance gains and not SOUND.
I've come to believe the slotted Stoptech from Excelerate are a solid OEM upgrade <---------Go with those.
Excelerate offers a acurazine brake package that comes with pads and rotors.
Do the intake resonated removal. There is a DIY guide on here.
MM delete will give it a bit of a growl and for mufflers it depends if you want to go quad, Socal Automotive sells them (though they are on back order or sold out atm)? Also, there is a memeber selling some on the black market (sticky rice or something is his user name).
Here is link that will help you out:
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Appreciate the quick response. I guess I'll stick with the stock plugs. Good call on the jpipe spaceman, but I think I will take care of all surrounding items before that unless I get this raise.
