Need to know if the AEM FIC is worth the money.
I have an 06 TL 5AT fully bolted and wondering if the AEM FIC is truly worth the money. I keep hearing conflicting opinions about it and it's my only option for tuning since Hondata won't work and the J&R ECU I believe is too expensive. So once and for all, is the AEM FIC worth getting so that I can make the most of my setup? As of next week all of this will be 100% installed on my car -
AEM Cold Air Intake
ATLP V2 J-Pipe
ATLP Hi-Flow Cat
XLR8 Base Duals Cat-Back
RV6 Hi-Flow PreCat x2
J37 Intake Manifold
J37 Intake Manifold Spacer
J37 Throttle Body
J37 Throttle Body Spacer
Thoughts?
AEM Cold Air Intake
ATLP V2 J-Pipe
ATLP Hi-Flow Cat
J37 Intake Manifold
J37 Throttle Body
Thoughts?
I have no direct experience with the FIC, but from everything I've read, it will not allow for optimal tuning. If I recall, there were 2 boxes that people use because one would only retard timing, the other would only advance timing. I don't know if the FIC can do both, or one, as once the Hondata came out, I abandoned any thoughts of anything else.
I would strongly suggest looking for a used JnR. There were a number of them in the BM over the past 2 years, for VERY cheap money compared to new. It's a standalone ecu on top of the factory ecu. I already had a Hondata when I saw the JnR, but I can say unequivocally that I would rather have had the JnR than the Hondata. I'm sure I'm in the minority but I believe there is something in the Honda ecu that we aren't seeing, or don't have access to with regards to tuning using Hondata. It's my personal feeling that something ecu based has contributed to at least 2 Hondata tuned turbo setups. If I remember right, one was a built motor. It's possible that the J35 is a giant turd compared to the J32A2 when using FI, it just doesn't seem probable.
Cliffs Notes: Skip the FIC, save for JnR, tune and be happy
FIC cannot increase timing. What you can do is skew the o2 so that it will keep the timing high. It is mostly used for boosted car because of it is ability to reduce timing. It is not bad if you just want to trim the Air fuel ratios. People were running this for build motors before flashpro became available.
I think this guy was running the fic before he swapped over to flashpro. He is the only one I seen that gain 20+whp using flashpro. Most gains are around 10whp.
http://www.v6performance.net/forums/...g-results.html
I have Hondata and love it, great product for my application. The best options for you is the J&R setup. Make sure you can find someone that knows how to tune it.
From what I read on AEM the FIC is for a FI application and not N/A.
You can add as much timing as you want with the FIC... but it's useless and stupid to add timing on 11.1 engine on 91-93 gas... but the FIC cannot monitor the knocks so pretty bad on knock happy engine... Hondata is a great tool and worth the investment if you can make it work on your car
Also, since you don't have any power mods and your car is an automatic... if your current AF is close to 12.8-13.0 you won't gain that much of anything with any tuning tools except for lower knock counts
The following 4 users liked this post by DomGSR-T:
I'm punch you OP. This was posted in one your other threads. read
https://acurazine.com/forums/perform...thread-870327/
The following 4 users liked this post by EvilVirus:
This is great advice from someone who knows tuning the 3rd gen TL. I think you should forgo the tuning unless you plan on a supercharger or turbo in the future.
TheTLProject (02-03-2016)
TLProject, consider looking into cams if you plan on staying NA. That and port and polish work. Just be aware that beyond the 3.7 Mani/TB swap, serious diminishing returns await (well more so than the already pathetic results on the 5AT)
EvilVirus (02-03-2016)
I've spent a good amount already. I'm done with engine mods.
AEM Cold Air Intake : $300.00
ATLP V2 J-Pipe : $379.00
ATLP Hi-Flow 3rd Cat : $295.00
RV6 Hi-Flow PreCats : $529.00
XLR8 Base Dual Cat-Back : $949.00
P2R J32 Throttle Body Spacer (no longer need) : $119.00
J37 Intake Manifold Conversion Kit : $810.00
EndlessRPM Blue Front Tow Hook : $22.00
Total : $3403.00
Total : $3403.00
Damn, you never told us about the tow hook. That's good for 35 whp.
But I would sell the AEM intake and the spacer and invest in a good four inch intake to capitalize on the bigger throttle body. And ditch the third high flow cat for a straight pipe.
Airaid U-Build-It Master Kit I Intake Systems 101-401 - Free Shipping on Orders Over $99 at Summit Racing
EvilVirus (02-04-2016)
