need exhaust hlep
Old Nov 12, 2006 | 04:33 AM
3rdGenA-spec's Avatar
need exhaust hlep
where can i find just the greedy evo muffler's at. or what greedy exhaust is a close fit to our car???
Old Nov 12, 2006 | 05:29 AM
aznbo187's Avatar
You may want to try purchasing a dual exhaust kit, for example they make them for the V6 accords. You would have to pretty much just chop off the mufflers only. Or you can see if you can find it used.
Old Nov 12, 2006 | 01:14 PM
how far off is a 2nd gen exhaust from a 3rd gen?
Old Nov 12, 2006 | 03:51 PM
aznbo187's Avatar
Won't fit. You will need to cut it and have it custom welded. And if you were to probably try to re-adjust it, the exhaust shop will probably charge the same as if you were to go with a custom new setup, I'm assuming...
Old Nov 12, 2006 | 05:33 PM
encrypted03's Avatar
aznbo187 is right. They will have to modify the catback piping in order to make it fit. They will have to cut the midpipe into 2 sections and change the angle, weld new hangers, lengthen and shorten a few sections of piping.
Old Nov 12, 2006 | 06:28 PM
aznbo187's Avatar
I'm not sure if you were the one with the evo, encrypted, but IF only it were able to mount up higher. ::sigh::
Old Nov 12, 2006 | 11:46 PM
yep, i'm one of the members w/ the evo's. i too wish they would be able to mount higher, but there is no room underneath there
Old Nov 13, 2006 | 12:05 AM
yea thats the exhaust i want to go with. i had it on my teg and loved it. what year and make did your evo come off of. did u do the hole system or the rear section only?
Old Nov 13, 2006 | 01:07 AM
aznbo187's Avatar
Any system that's duals for the accord will work. Greddy only has 3 different canister sizes. One which is the one on the accord's, the other one is sorta slanted such as the G35, or 350z, or lastly the shorter one for the celica's.
Old Nov 15, 2006 | 09:28 PM
I got the one for the CL, and had them re-work the entire catback to fit.
Old Nov 15, 2006 | 09:39 PM
thanks for the info. i will look in to that one. i was thinking about using the tsx.
joflewbyu2
Oct 8, 2015 11:16 AM
swany0095
2G TSX Performance Parts & Modifications
Oct 7, 2015 02:18 PM
jmaxima03
Sep 27, 2015 10:22 AM
prbori
Sep 27, 2015 01:37 AM
ivan06106
Sep 26, 2015 04:38 PM
