My Weapon-R Dragon Intake Install
Old Apr 30, 2005 | 10:07 AM
2004TLinIL's Avatar
Good morning everybody!
I thought I would post the results of my Weapon-R Dragon Intake Install. First off, let me show you the completed install and then we can talk about specifics from there.
Here you are:
The install took under an hour. Honestly, if you have ever worked on a car before, it should take you about thirty minutes. I spent a great deal of time looking around at the engine and how things were nicely put together.
I had ordered this product from http://www.eautoworks.com/html/ORD-1-1-1-24644.cfm for about $131.00 drop shipped directly from Weapon-R. From the time of order to the time of delivery for standard UPS ground from California to Illinois was about seven days.
Upon examining the box that it came in, there was no not knowing what was in the box. The box was very nice and glossy and described every detail. Pretty nice. It wasn't until opening the packaing until I realized how well Weapon-R has there act together. Every little item was wrapped up to protect it - whether it was a screw, bracket, filter, or even piping. Not only did that do that, but there was a checklist inside the box making sure they gave you not only every part needed, but additional brackets, etc. I was very impressed. Also, there was a ton of yellow pieces of foam holding everything down so that there was not even a single rattle. Way to go Weapon-R!
The instructions they provided were good enough for the newbie or do-it-yourselfer. They could have put a little more methodology to it and included a few more pictures, but this would only guarantee my recommended half hour install. It was good enough - not excellent.
Basically, all you do is remove the top/bottom stock airbox with filter inside and hose to throttle body and all clamps and bolts (one clamp, two bolts, and one tiny bolt). You need to cut two tie wraps as the electrical harness is tie wrapped to the left side of the box - so if you try to take the box out, you can't. Also to the firewall side of the airbox, there is a screw holding down a wire clamp that is connected. Unscrew this, put the screw aside and then zip tie the little clamp to the wire harness to get it out of the way. Once this is completed, you can clamp a coupler to the throttle body. Next, you can cut about a 2.5" piece of PVC rubber, connect it up to the pipe and return for the air nipple and then slide the pipe into the throttle body coupler you just put on and clamp again to hold the main pipe in. Next, put a coupler on the air filter and clamp down. Then, slide the air filter onto the main pipe, make sure the air filter has the tiny little screw end-up to put a bracket on. Clamp down accordingly. Disregard the directions for bending a piece of metal they include. They provided extra brackets. Next, take the rubber with double sided screws and screw it in towards the right finderwall closest to the firewall where the stock airbox came out of. Next, lay the straight aluminum bracket on top, and screw down and point it towards the air filter. Next take the little l bracket and screw that onto the air filter. Connect both brackets up together with the screw I had you set aside. I had to supplie a nut to fasten these components together. Wala, you are done!
Starting the car, no apparent difference in characterisitcs. At idle with or without the hood open you can definitely hear the sucking sounds of a high pitch hiss. In park, slightly reving the gas you hear a nice roar. Not too loud, but really nice. Definitely you can tell something is not normal like stock vehicles.
The test drive. Well, all I can say, under normally driving conditions there definitely is a growl, it is not quiet like stock. Mash the gas pedal let's out a real nice roar and as your speed increases and your RPM's, it does get louder - but reallllly nice - growl, not overbearing and things appear to be smoother and more responsive.
Simply put, for $131.00 and an hour or less of your time, this is definitely a nice mod. Oh yeah, the butt dyno does say so too!
Brian
Old Apr 30, 2005 | 10:40 AM
BukvaMan's Avatar
did you remove all the other stuff besides the air-box - i installed kandn short ram last night i left the resonator and everything else that i couldnt get to without taking the wheel off
Old Apr 30, 2005 | 10:54 AM
2004TLinIL's Avatar
I did not remove resonator that is tucked in the wheel well either. Just the top air box removal only.
Old Apr 30, 2005 | 01:34 PM
NFLblitze1's Avatar
Youse Gots Sacked
isn't weapon R known for lack of quality...as in it won't last as long as Injen or AEM....and youll have to end up replacing the filter more often than the AEM or INJEN
Old Apr 30, 2005 | 02:20 PM
2004TLinIL's Avatar
The only "quality" difference between all of the products is the type of air filter element they have. I have used just about everything out there with all different project cars and this is the first where I am using this type of Element on the Weapon-R. They had different elements in the past, and they were all pretty good - not as good as AEM or K&N though. So, with that being said, I might have to change the filter, but I doubt for at least 24000 miles.
Old Apr 30, 2005 | 03:26 PM
coop1018's Avatar
I am confused why a weapon R would benefit the TL. I was caught between the AEM cold air and the weapon R Short ram. After a lot of research, isnt it defeating the purpose of the stock intake of the tl.
Old Apr 30, 2005 | 04:58 PM
2004TLinIL's Avatar
The stock intake of the TL is no better than any others while standing still. The only improvement on any other car is the inlet for air is in the front dam of the car versus on the side where the wheel well is. With this being said, take out the equation of the air in the front as it still has to traverse through the resonator, etc. If you eliminated the resonator and put a straight pipe to the box, then it would be better, however, the air filter element in addition to the actual pipe of how the air traverses is what makes the difference. I would belive that if you decided not to go aftermarket and put a direct pipe from the front air damn to the stock box and replace the rubber hose from the stock box to the throttle body and replace the stock filter it probably would be a great setup. The cost to do all that would be about the same as I spent on the Weapon-R. To each their own, but don't tell me that the stock is that great. I no longer has that first gear lag in automatic mode.
Old May 1, 2005 | 03:29 AM
mio's Avatar
mio
Police
how many horsepower now? 275?280?
Engine sound is much better than stock? or just similar...?
Old May 1, 2005 | 09:38 AM
2004TLinIL's Avatar
Engine sound is not similiar to stock. It changed it for sure at all RPM's, most noticeable in 3rd gear after 4K - kind of like a 'waaaaaaaaaaaaaaaaaaaaaaaaaaa sound' (makes peoples heads turn).
Old May 1, 2005 | 12:17 PM
AsianTL's Avatar
Asian07RL
Nice set up.
Did you feel any different in performance or just the louder sound?
Old May 1, 2005 | 12:20 PM
Pro Stock John's Avatar
Car Addict
Brian, does it have any drone or resonance at like 50-70mph?
Did you put that WR sticker on there or did it come with it already on?
Old May 1, 2005 | 03:04 PM
2004TLinIL's Avatar
No drone at any speed unless you are on it in 3rd gear while going 50+ and pushing it (above 4K RPM).
I put the WR sticker on it. I normally don't, but this time I thought what the heck.
Brian
Old May 1, 2005 | 03:06 PM
2004TLinIL's Avatar
Drove a lot today and yes, definitely felt a performance difference in city and highway driving. I'm likin' it always now!
Old May 1, 2005 | 05:34 PM
Car Addict
Gonna be near the loop anytime soon? I'd love to check it out or hear it. You are 6mt or 5at?
Old May 1, 2005 | 07:38 PM
AsianTL's Avatar
Asian07RL
Do you take it off when you bring your car in for the any type of warranty service?
Old May 2, 2005 | 07:54 AM
2004TLinIL's Avatar
Work downtown, commute with the train.
Regarding taking it off for warranty work = yes, I would, hence why I did a SRI.
Old May 4, 2005 | 03:27 PM
ckya's Avatar
is it possible to change the filter to K&N or AEM ones?
Old May 5, 2005 | 08:42 AM
2004TLinIL's Avatar
Yeah, no problem at all doing that - any filter will work.
Old May 5, 2005 | 12:35 PM
05TL6MT's Avatar
I wonder if it's worth it to add the Weapon-R Ram air kit to this intake. It would be almost like an Ice Box, but you could put the air intake in the lower grill where the stock intake draws air from.
Was there any reason you didn't get the Secret Weapon intake?
Old May 5, 2005 | 03:10 PM
Car Addict
Adding 90 degree bends to an air intake hurts it's efficiency.
Old May 5, 2005 | 03:34 PM
2004TLinIL's Avatar
Cost and what Pro Stock John said.
Old May 5, 2005 | 06:26 PM
Car Addict
Did your idle go up at all, and does the air box make a huge hissing noise or just a little?
Old May 11, 2005 | 09:16 PM
ed99's Avatar
9.5+10.5 22m=Hella Flush
Here you are:
Brian
Looks nice and nice review but why did you get a short ram over the Cold Air Intake such as a AEM. OUr stock intake is a Cold Air intake. So maybe a short ram is not the way to go. I am just thinking out loud.
Old May 21, 2005 | 08:54 AM
TomSawyer's Avatar
Talking Looks good...
Seems to me the benifits of the CAI are negligable compared to this setup (for sound and improved throttle response) and certainly being able to quickly swap back to stock for any warranty work is a plus. I had an Audi-S4 B4 platform (2.7 L bi-turbo) with a chip and intake and with it being an Audi, there were PLENTY of service visits... so it was a royal PITA to have to remove those items (I had the full computer stock so I just swapped those out). Still, with as picky as some dealers are about aftermarket stuff, being able to swap back to stock easily is a real pro.
I am wondering about one thing... since the stock air box receives it's 'cold air' from the drivers side lower grill, does cold air still get piped in through that same system to hit this short RA setup? I have not inspected the TL's intake but since you guys have you'll know the answer to that one. If it works like I'm thinking, then as long as that piping for the stock CAI is left in place, it seems that cold air will be hitting this SRI filter nicely. Correct me if I'm wrong....
Old Jun 6, 2005 | 03:03 PM
stretchb69's Avatar
Come on, someone answer this question please. I'm in the market for buying a cai and wondering the same thing.
Old Dec 18, 2013 | 03:46 AM
L_Ninja_7's Avatar
Can someone please answer this??
Thanks!!
Old Dec 18, 2013 | 03:47 AM
L_Ninja_7's Avatar
I mean this one!
Old Dec 18, 2013 | 05:57 AM
paperboy42190's Avatar
nice thread revival
Old Dec 18, 2013 | 06:20 AM
Nick216's Avatar
The Boss
Originally Posted by L_Ninja_7
I mean this one!
Not sure what the question was, but if u remove the intake resonator and leave all the other pipes it takes air from the lower foglight area. Completely stock the intake draws air from near the battery.
Old Dec 18, 2013 | 10:23 AM
nttstt444's Avatar
Faaaakin cold air intake threads FTW!
Old Dec 18, 2013 | 11:18 AM
EvilVirus's Avatar
Old Dec 18, 2013 | 12:46 PM
Eaglesfan9106's Avatar
The air filter that comes with the aem v2 is a k&n says it on the filter I have one
Old Dec 18, 2013 | 03:51 PM
EvilVirus's Avatar
Hope you realize that the post you responded to is from 2005???
Just saying
Old Dec 18, 2013 | 04:11 PM
Nick216's Avatar
The Boss
Atleast he didnt make yet another cai thread. I prefer this lol
Old Dec 18, 2013 | 04:34 PM
Hahahah oopss o well didn't realize
Old Jul 24, 2020 | 08:01 AM
William Poth's Avatar
3rd Gear
Here you are:
I had ordered this product from eautoworks.com -&nbspThis website is for sale! -&nbspeautoworks Resources and Information. for about $131.00 drop shipped directly from Weapon-R. From the time of order to the time of delivery for standard UPS ground from California to Illinois was about seven days.
Brian
Any oics?
Old Jul 24, 2020 | 08:42 AM
Acura TL Builder's Avatar
Ya what is this, the mid 1800s?
Old Jul 24, 2020 | 09:12 AM
3rd Gear
Yea not sure what that means just trying to see how to use the mounting bracket
Old Jul 25, 2020 | 05:43 PM
1black_seven's Avatar
Slot Machine Lubricator
He means, why are there no pics, it's 2020 for gosh sake.
cycdaniel
Dec 17, 2019 10:58 AM
hues10
1G RDX (2007-2012)
Sep 7, 2016 03:47 PM
james357
Feb 13, 2016 02:37 PM
nanos
Nov 12, 2015 08:41 PM
Abe_Froman
Sep 16, 2015 01:27 PM
