My Supercharger Build thread. Experts needed.
iWhine S/C 6MT TL
As most of you guys know I bought a brand new kit from Pizzaman! Great guy btw. He's kit doesn't come with the comptech ACM but it does come with the AEM FIC with PNP harness. Most of you guys are like "Damn that's awesome". So this is my build thread. I have spoken to a lot of members here through PM or on the phone (Alex Imfamouslink). I have a ton of questions and most have been very helpful, and I will openly admit it.. I'm going to be a bit cheap now, after spending $$$$.
-I'm not looking to track this car, this is my daily driver
-The purpose like most who get this kit, pleasure knowing you have a supercahrger!
-I have a few supporting modification, exhaust work (J-pipe, comptech exhaust) I have the TB coolant bypass to help keep unwanted hot temps away from the intake manifold.
-I plan on doing a custom 3 inch CAI to help with cooling the charged air.
I have the AEM.. Here's the deal.. I understand about the surge problem, most have fixed it by doing upgraded exhaust work (Pre-cats, j-pipe, exhaust) I don't like the way the car sounds with Pre-cats. AEM requires a tune, Ive called placed in NJ and basically got nothing... Many don't want to deal with jap vehicles and the AEM unit. Required to upgrade at least injectors and fuel pump with tune = $$$.
My questions for those that have done this
-ACM hooked up, can I upgrade the fuel pump without crushing FPR? is that a better solution and one step to helping with surge?
-What's the bare min I need for the AEM to function other than a tune. Example (Injectors RSX-S)-(Fuel pump upgrade?)-(Exhaust work?)
-For those that still running the ACM unit, what steps have you taken to resolve some surge issues?
-Wiring up the AEM vs ACM. I know I have the PNP harness but most were telling me I might need another harness for Vtec to be lowered if not that then a relay with a half ass made harness.. Any input on this is appreciated.
-I had hi-speed help me with the CAI intake. For those that have done this, what intake setup did you use? I was told 98 Accord 4 cylinder works with a 90 degree elbow.
Addition things that will be done is clutch and flywheel. I was told the light flywheel will cause chatter and vibrations. I don't want this car to feel like a POS half ass civic. I was also told the stock clutch can handle the power out put perfect for a daily driver. Thank you guys I'm sorry if my questions sound stupid but trying to get an idea of what to do before I order things.
P1zzaman (09-22-2012)
Chapter Leader (NY/NJ)
iWhine S/C 6MT TL
Thanks Alex, There's just been a bunch of information Ive been getting from helpful members here. I was told I don't need to do anything except tune the AEM to the car (No upgrades to fuel, exhaust, ect) Nobody answered my question about, without the ACM unit how can I run this car to get the AEM tuned? At this point with very little options of who to tune my car and not fuck up on the wiring I might end up forking the money for a new ACM from comptech. I wish that they updated the software on the ACM to fix the surge problems. Like I said this is my daily, if eric is still running with the comptech setup as is for so many miles I don't see why my car will be worse off..
iWhine S/C 6MT TL
Yeah it's a lot of money. I'm sure ill find someone who wants it. thanks for your answer.
Just FYI, the F/IC takes the place of the ACM. You don't run it at the same time or anything.
Also, the F/IC is MUCH easier to tune than say the MS3 which means that it's considerably cheaper to tune. It's silly to consider getting rid of the better fuel management setup and go with the more primitive one. I don't understand the logic behind going that route.
The ACM is the primary issue behind the S/C surging. Whatever Comptech did in the tune, they F'd up big time. With the F/IC, my surging was almost completely eliminated.
There are a number of guys here with experience wiring up the F/IC. Just reach out to KN_TL, NVA-AV6, or myself. We can do the wiring. Hell, any of us can probably even set you up with a base map that will help you just get to the dyno in order to get a full tune on the car.
Regarding your fueling, do not, I repeat, DO NOT cheap out on your fueling. Just pick up a set of RDX injectors (~$250) and hold off on crushing the FPR. The problem with crushing the FPR is that you don't know exactly what your fueling parameters are. Is it 50 p.s.i., is it 65? Nobody really knows.
If it turns out that your pump can't keep up with the RDX injectors, THEN consider crushing the FPR. Really, it's one of the most ugly, half-assed, hack-ish things you can do when you have a fairly serious F/I setup, and is the most likely to cause you (and your engine) problems down the road.
04WDPSeDaN (09-23-2012)
Superstressed
@ 04WDPSeDaN, as I mentioned, I am running the FI/c and have 0 surging; with the ACM the surging was bad. My car is Automatic so I don't know if that would have any affect (good or bad) with surging. Also, as bmeyer said, get yourself a set of RDX 410cc injectors and pigtails. I bought them from this place http://www.corsportusa.com/store/cat...ducts_id=12162
@ bmeyer, is there some way to pm or reach you via text? I had a few questions about the SC and was told you're the man to ask, if you don't mind. Sorry 04WDPSeDaN, don't mean to jack your thread.
iWhine S/C 6MT TL
Thank you guys, bmeyer can you set me up with a base map for aem. Thank you.
The problem is that all of us tuned guys get people asking us ALL the time for maps for their cars; we never just hand them out. First, we paid decent money to get our cars tuned; we're not really wanting to just give that out for free. Second, everybody's car has a different setup. You cannot just drop one person't tune in another car and expect it to work. Third, we don't mind helping guys out, but we've all been around the scene long enough to know when people just intend to take the map and never get an actual tune for their cars. It just creates more problems for us because then it obligates us to help them out when s**t's broken. (AND IT WILL BE BROKEN BECAUSE THE TUNE WAS NOT MADE SPECIFICALLY FOR THEIR CAR) We don't want that. It's a prime example why I don't have PM's enabled.
Really though with the S/C, you can just zip-tie the bypass valve and get it to the tuner. Since it's a piggy-back ECU, you still get all of the factory fueling and timing, thus there's no need for a base map just to get it to the shop. Even with the RDX injectors, the F/IC is setup so that you can enter in the factory injector size and your new injector size so that you can drive the car without an actual fuel map loaded and it'll be fine.
With regard to gauges, even though you don't want any visible gauges, it is still a good idea to run a wideband controller. You can get them without gauges and it will provide feedback to the F/IC.
@bmeyer, do you want me to handle the map request?
@04: follow what the guys said and zip tie the bypass valve open. I too had to temporarily do the same.(try not to hit 4 k rpm in this stage) Send paul the fic harness so he may modify it and it be PNP. DO NOT go back to the acm, its not going to do you any justice. Do not use any ones base map either. wait it out until you can get the rdx injectors as well. I believe your in the tri state? winter is coming up soon, it may be more beneficial for you to wait it out through the winter, gather the right supporting parts. go about the install correct. get a tune and open the next season right. Different parts,cars require a different tune. I have a tuner for you in NJ if you would like. PM me for details.
iWhine S/C 6MT TL
Thank you guys, Handsom would you be able to pm me that information. this is adding up more than I'd like to spend at this point.
If you have the Comptech tool isn't crushing the FPR simple and predictable?
The only question I can offer advice on is the CAI. I used an AEM V2 I had laying around and just cut the end off to make it fit. Simply, clean, and you can still using the same mounting points.
Don't any any good info on the supercharger but I have cm stage 3 with aasco lwf and have zero chatter; now I had a little when it was breaking in but after 750 miles or so it stopped chattering. This is my DD and have had zero problems.
InFaMouSLink
10-30-2015 09:43 AM
Sarlacc
Console & Computer Gaming
09-30-2015 02:15 PM
Joe Avesyan
09-29-2015 03:57 PM
04wdpsedan, acm, acurazine, build, charger, comptech, hot, nsx, pizzaman, pos, super, supercharged, supercharger, thread, vibration
