Modifying Stock Airbox
Old Aug 1, 2006 | 12:08 PM
cristphoto's Avatar
Has anyone modified their stock airbox to get better flow? I thought I read something on it here, but a search couldn't find anything. I don't like the idea of a K&N (or similar) filter protecting my engine and most of the CAI's use this style. I believe that a conservatively modified air box can give pretty much what you get from aftermarket CAI with none of the negatives (possibility of water damage, lowered torque, dealers hassles while in warranty). From my "old-school" hotrod days, I recall this was done cheaply and with good results vs. $$ paid. Thanks. Steve
Old Aug 1, 2006 | 12:11 PM
cristphoto's Avatar
I forgot to request in my first post, does anyone have the illustration of the airbox assembly that they can post? Thanks.
Old Aug 1, 2006 | 02:31 PM
RjS's Avatar
RjS
Found this in another post awhile ago. Hope it helps.
Old Aug 1, 2006 | 05:13 PM
cristphoto's Avatar
Thanks RJS.
Old Aug 1, 2006 | 07:38 PM
Schulminator's Avatar
it's 4:20
I removed the resonator boxes behind the bumper, and ran something similar to the pic prior. It seems to work pretty good. Don't want a CAI for soggy florida..
Old Aug 2, 2006 | 06:59 AM
cristphoto's Avatar
Did you replace the resonator with piping so the intake can still breathe through the front bumper slots? Does the resonator unbolt (for easy re-install if wanted) or do you cut it off? Thanks for your reply.
Old Aug 2, 2006 | 10:58 AM
sotgecho's Avatar
I removed my stock resonator yesterday with the help of this thread.
https://acurazine.com/forums/car-talk-5/driver-side-seat-replaced-rsx-loaner-85337/
Also I replaced the stock filter element witha K/N OEM replacement for better airflow.
http://www.knfilters.com/search/prod...x?Prod=33-2299
It took all in all about an hour to remove everything because there are some bolts that in odd places that require some awkward reaching.
Then I used the piece that is circled
to make my own CAI like the picture in the post above.
It was worth the time it took to remove and install the filter. $30 for the filter on ebay for a decent HP gain based on my butt dyno and a nice growl when you floor it.
Also if you take apart your stock airbox you will notice that there is a deflector in that channels the air in a specific way to your filter. I read on here somewhere that people removed it trying to utilize more of the filter. But there is not proof that it helps anything.
Old Aug 28, 2006 | 04:30 PM
cuuze6803's Avatar
cuuze6803
From: South Florida, Broward (wear old pople come to die)
First time i heard about ram air on ours. Will make tubbing from trottle body to box, make a way to open the box with a slidding door incase of floods. K&N of course (Proven gains, pays for it self, and better sound.) will make tubbing to lower grill for the intake if not to hard/seams unsafe, or can't find metteral needed installing my self. Deffently Will put Tuorado in intake. ASSURE a couple h.p. and gas millage increases from first hand experience in 3 family cars with Torando. Besides reasonable price/eassy to install. REMEMBER COLD AIR improves engine profamce all around. They make a rap around sleave for intake tube that shown great increase for cheap. Last for about 2-4 hours the longer recharged but can keep it on as long as you want. It's Chill Factor Perforamce Inc. (don't know web site, never seen it in stores). Different sizes to fit any application, Cheap, no tools, recharges in hours, and does,t sweet on elec.. Coolder more denisty of air in chamber. Swirling air and fuel mixture is more efecent. so these are for the low budget gains.
Old Aug 29, 2006 | 11:37 PM
ubnpast's Avatar
The stock intake also sucks in air from above the drivers side headlight as I tried to draw.
hashbrown
Feb 18, 2022 11:20 AM
vpasla1
Sep 17, 2016 07:24 PM
rcs86
Aug 2, 2016 06:52 PM
DerrickW
Nov 15, 2015 05:52 PM
rangomango
California
Sep 24, 2015 05:47 PM
