mid muff delete
Old Jun 11, 2009 | 03:29 PM
warren4066's Avatar
mid muff delete
thinking about removing mid muffler and replacing with straight pipe. now what is the difference between stainless steel and aluminized steel...called most shops and they offer aluminized steel?
pros/cons will be great
did search and did not want to read that 2o something page on this thread
Old Jun 11, 2009 | 04:48 PM
ChocolatePuma's Avatar
Need to fix my Bike
Originally Posted by warren4066
thinking about removing mid muff and replacing with straight pipe.
There are several surgeons that can help you out
Old Jun 11, 2009 | 05:15 PM
warren4066's Avatar
hope so...i read only 5 pages and way too many pages...if the aluminized steel is okay then i don't mind using it for the straight pipe
Old Jun 11, 2009 | 08:02 PM
05BlkTL's Avatar
It's ok but it will eventually corrode. If you want a little extra protection after it's installed give it a spray with some high temp paint, VHT, Duplicolor are a few brands. Then let your car idle for 10 min, turn off for 20, then idle again for 20, turn off again for 30 to cure the paint.
Old Jun 12, 2009 | 11:32 AM
warren4066's Avatar
^eventually corrode? when? how many years/miles or condition of weather?
Old Jun 12, 2009 | 12:08 PM
ssmtl2nv's Avatar
2009 g37s 6mt
aluminized steel will rust immediately and corrode within 5-7 years eventually. It is okay to use it as it is similar to the oem catback piping. The pros are that the exhaut is gonna sound more throaty, similar to a g35 exaust note. There are no cons except the piping.
Old Jun 12, 2009 | 12:12 PM
Tripnbeats's Avatar
heat/weathering is ur worst nightmare (and you cant avoid either). Make sure u get a good stainless or aluminized. regular piping would rust at a normal rate like within a week, it wouldnt fall off but you dont wanna see it when the car is up....its like wtf is this rusting for?
Old Jun 12, 2009 | 01:59 PM
jguerra23's Avatar
Looking for new mods
Mid Miuffler removal alone is kind of pointless... the sound barely changes.
Old Jun 12, 2009 | 02:19 PM
Trew's Avatar
Delete the stock resonator while you're under there. Then you will hear a difference.
Old Jun 12, 2009 | 02:52 PM
snake134's Avatar
don't delete the resonater. just get a magnaflow or dynomax one.
Old Jun 12, 2009 | 04:27 PM
warren4066's Avatar
will do the mid muffler/aluminize steel straight pipe...and if i'm satisfy with that then i'm done, if not i will remove the resonator and replace it with a magnaflow...off track but hows motor city right now? born and raise in macomb cty.
Old Jun 12, 2009 | 04:34 PM
TL|GTX's Avatar
A Black TL
Economy is baddd.
Old Jun 12, 2009 | 08:47 PM
NedShneebly's Avatar
practicing nihilist
I got it. thought it would have gotten a couple laughs. tough crowd.
Old Jun 17, 2009 | 12:41 AM
cheath2's Avatar
3rd Gear
it really doesnt change the sound but if you really want it done i would use stainless steal
DerrickW
Nov 15, 2015 05:52 PM
merc009
Sep 29, 2015 03:06 PM
johnpancakes014
Sep 27, 2015 12:58 PM
ceb
ILX
Sep 27, 2015 10:56 AM
