K&N on 07 type s...
Old Jan 15, 2008 | 07:41 AM
vinnier6's Avatar
K&N on 07 type s...
anyone using one on their type s....i just ordered one, but was curious to what kind of results people are having....i am not expecting much, but maybe a 1 mpg and maybe a slightly louder intake....
Old Jan 16, 2008 | 09:18 AM
S PAW 1's Avatar
K&N does not make a CAI to fit the '07 TL-S. As you may have read in this section, the K&N comes as a convertible short/long ram. I also have a P2R thermoblock spacer and gaskets, which add 1 1/2"length. I do not know how the long ram CAI will fit. It may be just fine. I used the short ram version that I had originally on my '05 as a long ram, and ran into clearance problems with the battery (I decided against using the long ram on my '07). I purchased a Braille battery, which is much smaller and lighter. The best feature of the short ram is that it is longer than most short rams, and actually curves down into the space just above the factory cold air intake piping, once the filter box is removed. Due to this, it minimizes sucking hot engine air, which would negate any hp increase. I feel the hp increase is substantial with my setup. I ran the P2R with the stock intake, and then a drop-in K&N, and I could feel a slight torque increase with either filter. The drop in doesn't seem to make any difference over the stock filter to me.
My A/T actually chirps the tires on the 1-2 shift using the paddles and the VSA turned off now. The hp increase is real, and substantial IMO. It is no louder than stock until the vtec comes to come into play, which is just the way I wanted it
Old Jan 16, 2008 | 11:28 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Maybe the OP actually meant the drop-in K&N filter. That's how I first read it. If so, then you won't experience any gain in performance, IMO. Whatever you do gain will be negligible. Regarding sound, the same thing. The drop-in filter just won't make that much of a difference. If the OP actually DID mean the K&N CAI, then disregard.
Regarding having the P2R TB Spacer, along with a CAI, I've noticed the 3 major brands work: AEM, Fujita, Injen. I got mine to fit with no fitment issues. Now with the K&N CAI, I cannot comment, as I don't have experience with those.
Old Jan 16, 2008 | 11:47 AM
S PAW 1's Avatar
Princelybug
When the OP said "louder", I just thought "CAI"
This is twice this week you have picked up on things that I totally overlooked.
The first one was the reset code on the radio and Nav.
After seeing your Avatar, I'm beginning to think you're my "guardian angel"
To the OP, as stated, don't expect any measureable change with the K&N drop-in.
Sorry.
Old Jan 17, 2008 | 12:15 AM
Originally Posted by S PAW 1
Princelybug
Sorry.
S PAW 1, no problem! Who knows, It could've just as easily been me that was mistaken?
Old Jan 18, 2008 | 08:39 AM
vinnier6's Avatar
so far, acording to the mid, i am getting 2 more mpg average...i was averaging 22mpg, now 24...that is about what i was expecting...i cant tell if performance is better because the car already screams....like i said before, i knew right off the bat that i would see some kind of change just by looking at the two filters side by side...now i might just have to see about removing that resonator....
Old Jan 19, 2008 | 08:25 AM
S PAW 1's Avatar
He must be talking about the drop in.
Old Jan 19, 2008 | 04:13 PM
vinnier6's Avatar
its just a drop in...
Old Jan 21, 2008 | 05:18 PM
I hate cars's Avatar
Better mpg due to a filter or CAI is a myth. Will not happen unless you're running a carb (and that's iffy) or you're 50,000 miles past due for a change.
Old Jan 21, 2008 | 08:10 PM
vinnier6's Avatar
so i guess the computer is lying just to make me think i am getting better mpg with the new filter....pretty smart computer, i guess....
Old Jan 21, 2008 | 08:54 PM
Pure coincidence, change of driving style/habits, computer inaccuracies. It's impossible unelss you went from a very clogged stock air filter to a new CAI and in that case a clean stock filter would show the same increase. Explain to me how a higher flowing filter could increase mileage. The Honda PCM sucks in that it doesn't use a mass air meter but still, you have the 02 sensors to make the necessary corrections.
Old Jan 23, 2008 | 05:58 AM
S PAW 1's Avatar
None of us are experts as to the internal workings and computer gadgetry built into these engines, so I just utilize the mathematics. I am trying not to check gas mileage EVERY time I fill up, but I do most of the time. My '05 consistently showed an extra 2-3 mpg after installation of the CAI. Now my '07 has only had the install for 1 1/2 weeks, and I haven't had the opportunity to check over a good period of time. So far, I haven't seen an increase either from the MID or actual.
If it happens, I won't try and figure it out, but I will know it's real.
I do know that there IS a hp increase, which means added efficiency, which should equate to better mpg.
Charles Bennett
Jan 28, 2018 08:53 PM
Jul 16, 2017 07:33 AM
mvidal6
ILX
Nov 14, 2015 07:43 AM
justin.w13.walker
Sep 22, 2015 02:21 PM
