J37 Full VTEC Valvetrain
A friend of mine wanted to see some pics, so I figured I would just post them for all to see.
What you see here are close up shots of the assembled valvetrain of a J37A2 head (2010 RL). This and the TL SH-AWD have full VTEC (intake AND exhaust). Enjoy!
It always amazes me whenever I see the inside of an engine. It boggles my mind to think that somebody somewhere had to detail and draw out each angle and contour of every mechanical surface and part. All while maintaining calculated specifications and tolerances to design a well oiled machine(no pun). Engineer porn is the best kind of art!
The exhaust port is actually smaller. Probably to make better torque at lower RPMs with higher RPM flow being accommodated by a different CAM profile.
Yes, these heads should be able to directly bolt onto a J32A3.
VTEC is controlled by a single solenoid exactly like the J32A3, J35A8, etc.
That's correct. All added exhaust VTEC changes were made inside the head itself. Primarily in the valvetrain and it's associated components. There are rumors, however, of weak valvetrain components in these heads. May be a good idea to have some sort of hardening or shot peening done to the rockers if anyone plans on a performance build with these heads. Especially motors that will be seeing regular high rpm revs.
Lets not focus on the negatives here buddy. Didn't mean to upset the charisma in your thread. Lol.
Here's some more badass pics to reintroduce the goodness this thread brought! Got both of the castings ready for use. The front one just needs to be reassembled but I'm waiting on the camshaft as the original showed some signs of wear. One of the heads are brand new out of the box and the other is from a used j37a2 I purchased solely for the heads themselves. The used casting (front) has been cleaned extensively, crack checked, resurfaced and had all valves/springs checked for proper specs.
Was cleaning up my j37a2/j37a4 head and prepping it for use then remembered Eric (OP) requesting some pics of the rockers. I managed a few with my iPhone and they came out pretty decent considering.
Here's the two of the four exhaust rockers. The other two exhaust rockers are identical to these.
The intake rocker and cam follower. There are only two pieces from the intake side. This is because the actual rocker has a split end design that can depress both intake valves at once when riding the primary or secondary lobe of the cam. Took a few more pics of these rockers due to the design complexity. This was the first ever variable valve lift design on both intake and exhaust from a SOHC head the world has seen. Honda engineers are truly the best in the world.
The next pic was simply to show how Honda uses pressurized oil to lock rockers. The cylindrical shaped steel lock is actuated into another rocker (usually the "VTEC" rocker) next to this primary rocker. You can see the small orifice in the bottom of the cavity where the lock sits where the oil is fed through. Although nearly all VTEC systems use this method, this one is both intricate and simple all at once.
Oil for the VTEC system (as well as the valvetrain) is fed up from the block into the end cap shown here by a small port on the right. Then it's directed out of the two dime size holes which obviously then feed the two hollow rocker shafts. The shafts are ingeniously dual purposed in holding the rockers themselves as feed oil for the VTEC system and valvetrain lubrication. The shafts have very tiny holes that perfectly lineup behind each VTEC rocker to feed them pressurized oil. As a matter of fact, both shafts are held in a specifically "clocked" position by machined indentions for the top mounting bolts of the rocker bridge. Again, a typical thing for Honda to do on their heads.
Also. I need the part numbers for heads. Also the head gaskets... which I'm guessing I'd have to use the 3.7. What about the timing belt. That's that big question. And then also get valve covers. Plus maybe nee coil packs if they're longer... Damn me. .. I'm teasing myself now. ..
The cam belt is the same. The head covers are different, the coils are different, the intake runners are different and the exhaust port / manifold mounting is different. But the J-pipe mounting is the same. There are many online Honda/Acura parts websites that list part numbers, so you can do your own research.
Only the j37a2 (09+ RL) and j37a4 (09+ TL AWD) engine codes carry the VTEC on the exhaust and intake. All other j37 variants from the MDX (j37a1) and ZDX (j37a5) are intake VTEC only. What's funny is how much smaller the cams are (intake lobes) in the a2/a4's yet they ONLY make 5 additional horsepower. Hmm, can you say DE-tuned!?
Originally Posted by yungone501
Hey Eric, what's the word on the install of this motor?
Justn, I know you said you are doing MDX heads in a different thread. Any reason you didn't go with the RL heads? I understand if it's something you got cheap or had lying around, but if buying new, why not go with the 2 or 4 heads? You'd really be like, "VTEC just kicked in, yo!" lol
plus, I wasnt even really thinking about upgrading until my friend so happened to over-rev the car. i was hastily making decisions and my first choice from Robert was 3.5 heads until I woke up sunday morning and was like....wait, i wont be happy with the 3.5 heads.
but this thread has got me thinking about the future and if i so happen to over-rev again, I know which route to take.
We have an accord on v6p with the j37a1 head already. I have a tls head with 09 camshaft in my j30a5.
You guys will probably have better luck with the j37 heads since you have the displacement and compression to fully utilize it.
From the look of your heads Honda increase the valve size in the new engine correct?
Nobody let this guy fool you, Eric is one of the quiet automotive/engine masterminds that just sit back and watch from his garage full of badass j-series parts and custom electronics.
I've got my EYE on you...
Robert(yungone501) sold me the used MDX heads(J37a1). I dont think he had any of the newer engines available or he would have mentioned it to me.
The 07-09 MDX heads were given the best of both worlds with their traditionally placed cam journals, tumble port design, stronger and lighter valves/springs, and enlarged cooling jackets. Basically the j35a8 heads with much better port design. The j35a8 heads are better for higher revving large displacement engines because the ports don't induce turbulence which agitates airflow at higher velocities.
All 3.7's have 36/30's.
