J35A8 motor swap
nice, well just let me know when you want to mod again... we can do it all.
probably, they didn't look too professional.... but i dynoed at 3 other locations and i ran lean on every dyno.
13.2@ 107 on Street tires
Originally Posted by BLACKURA_NY
So the J35A8 is the TL-S block?
Hi guys, here are some bootom lines on a 3.5L buildup.
First the tought of "just dropping in" a J35A8 block is dead from the word go. The J35 uses a different tranny and bellhousing bolt patteren, so it would not bolt up to the existing tranny, this is why I use the J32A3 (04-06 TL) block, it is compatible with both my AV6 and your TL trannys and gives us the J35/J32 89mm bore. Esentially the "internals" difference between the J32 and J35 is the 86MM vs 93MM stroke. Here is a quick breakdown.
Model-Bore-Stroke
J30= 86MM X 86MM
J32= 89MM X 86MM
J33= 86MM X 93MM Custom Frankenstien
J35= 89MM X 93MM
J37= 90MM X 96MM
J42= 96MM X 96MM In design...
Engine block interchange.
J30A1,J32A1,J32A2 = same bell housing pattern.
J35A3,J35A4,J35A5 = same bellhousing pattern.
J30A4,J30A5,J32A3 = same bell housing pattern.
J37 = New pattern
J35A8 = unkown as of yet, but seariously doubt compatable with J32A3.
The engine in my AV6 automatic is built from a J32A3 core (block/heads/intake) with 04MDX/06Pilot crank and 04MDX/07Ridgeline Rods, both of these are forged, 03CL-S pistons (not sure if forged, have gotten conflicting info), with Total Seal rings. This netted a 10.5:1 compression and on my untunned (EManage not installed yet), running on Stock ECU only with Stock FP and only a AEMv1 CAI I laid down only 232 dynojet adjusted WHP and 321 dynojet adjust WTQ, I am sure this will even out and come up aonce I get the EMU in and tuned.
Model-Bore-Stroke
J30= 86MM X 86MM
J32= 89MM X 86MM
J35= 89MM X 93MM
J37= 90MM X 96MM
J37 = New pattern
Originally Posted by vtecAccordV6
Does the 2004 acura tl intake manifold fit on a 2004 honda accord v6 engine using all the accord parts onto the acura tl intake manifold? like the throttle body, and wiring etc.
Model-Bore-Stroke
J30= 86MM X 86MM
J32= 89MM X 86MM
J35= 89MM X 93MM
J37= 90MM X 96MM
J37 = New pattern
Model-Bore-Stroke
J30= 86MM X 86MM
J32= 89MM X 86MM
J35= 89MM X 93MM
J37= 90MM X 96MM
J37 = New pattern
Model-Bore-Stroke
J30= 86MM X 86MM
J32= 89MM X 86MM
J35= 89MM X 93MM
J37= 90MM X 96MM
J37 = New pattern
Model-Bore-Stroke
J30= 86MM X 86MM
J32= 89MM X 86MM
J35= 89MM X 93MM
J37= 90MM X 96MM
J37 = New pattern
Originally Posted by type-s09
how in the hell you have 321 torque?
Here are my dynos done on a dyno dynamics dyno which reads 15% below dynojet numbers.
And here is the link to the build
http://www./forums/showthread.php?t=86084
i support your build but you need to find a better dyno...that dyno is way off..i mean look at the slope of you hp graph...unless you spray and a are pushing about 20psi there is no way a NA motor is gonna gain power at that rate..i mean its almost straight up..
Actually they way I understand it , it is because I am running a automatic so they can't even start recording until about 4K RPM, I got the same looking result on my baseline but the numbers came out on par for a stock car. A also know that I can not hold off the line traction without TCS, if I turn TCS off I am spinning wheels off the line. And I have 3 long black stripes off my side road to prove it, LOL.
hell yeah..well i had a 2nd gen TL that had 240 whp and about 206 tq and if you stalled it from a dead stop and launched it would go straight to rev limiter blowing the tires off...with that kinda torque you would leave marks in 2nd gear...
94 DC4 RS LSV/Turbo
thought you guys would get a kick out of this
j32 motor swap... Rear wheel drive, putting out 500hp
MADE MY HRDA (<-crazy)
it is gutted, and is also using the stock tl ecu
but the funniest thing it is an element LMFAO
http://www.hondatuningmagazine.com/f...onda_element_d
Already answed on page 2...
BTW. WTF is a papio??
version of a full size (up to
200lbs) ulua. A juvinile, if
you will.
So wtf is an ulua?
They are apex reef predators competing
with shark, barricudas and man
I suppose, for the bounties of the coasts.
The ones around here are all in the
Trevally family, on the east coast I think
they're called Jack Crevalle.
So anyway I spent many years chasing
these beautiful, brutally strong fish
down many coasts using an ultralite
6 pound test setup and artificial baits.
Not lately, it's too painful to ride the bus
to go fishing. There still might be some
around at Sept.'s end. They tend to go to
deeper water at the end of summer.
This is not me. It's fine exaple of a white
ulua I found online. I have a good of me
somewhere...
This looks a lot like Kiribati (Christmas Island)
wow nice to see another offshore fisherman...i do some king mackeral, amberjack, and bottom fishing (snapper, grouper etc)..also do some onshore fresh and saltwater, trout, bass, flounder..etc
casting poppers from
the shoreline that is until
NVA releases the 7th gen
AV6 trolling kit...
casting poppers from the
shoreline going after jacks
and barricuda. that is until
AV6 trolling kit...
Originally Posted by papiowhisperer
Actually for me it's pretty much
AV6 trolling kit...
AV6 trolling kit...
Yeah, OK, right after I get the Knight Rider Turbo Boost done
As for the RL, except for the usual bolt on's, there isn't much to make any sort of a noticeable difference.
Jul 16, 2017 07:33 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
