J32A3 Integra Swap... need help with EM
I need to know which ECU I can use guys. I'm going to delete the CATS on the heads, so I think I need to run the CL-S ECU but I'm not sure.
Also, I want to use the harness that came on the engine. I need to know what additional wiring I need to buy to go from the bay, to the cabin/ECU. I know it will not be plug and play but I can't seem to find info about the TL harness. Everyone uses the CL-S harness and I want to use what I have (factory TL harness, manual engine, harness and trans)
94 DC4 RS LSV/Turbo
problems...
1. ecu, you need a manual ecu from 04-08
2. these ecu's have immobilizers, contact richie v6 regarding this
3. you need the wiring diagram to mat these 2 wiring harnesses
4. if you delete the cats you simply just run defoulers and you wont have check engine light
5. contact p2r on how they deleted drive by wire
ps. can you take pics of how you modified the motor mounts
dirtyspitshine
01-03-2023 08:23 PM
