J32a3 bottom end OEM build
Old Jun 3, 2025 | 01:01 AM
Speedfreak813's Avatar
So i have a j32a3 with a bad bottom end, I've done some research on what I can swap in just want to make sure I'm right and get advice before I make any decisions.
Ive read j35a3 crank rods and pictons drop right in. If i go this route do the bearings and rings have to be for j35a3 or can the brand new j32a3 ones i have work? Also what are the benefits to this build
J35a4 are plentiful in my local you pull it, but from what i under stand you have to use RL pistons with this crank and rod setup. What are the benefits to this build, i probably wont do this one because of the chances of finding a RL and the yard.
the my final option is another j32a3 bottom end, or complete engine from the yard (yes this is a junk yard build only thing new will be bearings and rings)
Which would be best hp and tq numbers, looking for more of a mid range power curve.
Thanks in advance for the advice and information
Glorygang600
Jul 18, 2021 07:12 AM
Funmonkey
Jul 10, 2017 07:20 PM
slprwgn04
15
May 4, 2014 12:13 AM
yungone501
May 23, 2012 10:11 AM
rtatsutani
Sep 7, 2005 02:56 AM
