J32a1 j32a2 = j32a3
94 DC4 RS LSV/Turbo
Well if you follow the standard which is, first letter is series, followed by 2 numbers is the size and the last 2 characters are the head.. The blocks would be relatively the same
I got the Shifts
block the same. heads are different. j32a---whatevers have the same block.
heads changed in the j32a2 as well as the compression (pistons). j32a3 had similar changes.
but a j32a1+j32a2 =/= j32a3.
you will need the j32a3 heads etc. on the j32a1 to make the A1 into an A3.
the 3G TL block has headers cast into the block, I believethe others have real headers.
dirtyspitshine
01-03-2023 08:23 PM
