J-Series Engine Mounts Compared: Innovative & XLR8 Mounts
J-series Polyurethane Engine Mount Kits Compared: Innovative Mounts and XLR8 Mounts (Read on Heeltoeauto.com!)
The J-series engine mount game has been somewhat heavily contested over the years; Innovative versus XLR8. We get calls and emails all the time about these two quality brands from people confused about forum hearsay and old, outdated posts. This article is going to lay out some of the similarities and differences between these two great performance mount kits.
First, a bit of backstory. There seems to be this lingering rumor that the Innovative Mounts are inherently bad because of “donuting” or deformation of the ploy bushings. Factually, there was a thread posted on Acurcazine.com which discussed the issues with an old Innovative design. Speculation and/or general consensus was that the bushing design used by Innovative was not adequate for the load they were under. The design of the mount and/or bushing needed improvement. What is important to know is that many years ago the Innovative kit was completely redesigned in an aptly innovative way, and that while threads on the internet are relatively permanent, product design and reputation is not. The current design is not susceptible to bushing deformation at all.
Now that that is clear, we'll get the comparo going.
Factory mounts are very good at isolating noise and vibration from the engine. Despite what you might read online, they are actually fairly durable as well. They usually last in excess of 100,000 miles, except in some cases where heavy duty-cycle (aggressive driving with performance mods) can cause them to wear prematurely. It should be understood that changing to aftermarket mounts will noticeably increase both noise and vibration inside the cabin significantly. Whatever polyurethane mount set you choose, it won’t result in fluid filled, rubber-dampened comfort. Your Acura TL won’t feel quite so luxurious with poly mounts in, regardless of the durometer you choose. That said, original mounts can fail with increasing frequency with the intensity of power addition that enthusiasts do these days. If you just need new mounts after 120,000 miles, we might suggest new stock mounts. If you are looking for more performance, read on.
But there is clearly a need for performance polyurethane engine mounts for J-series engines, so here they are. Now, both kits, XLR8 on the left, Innovative on the right:
They look pretty different, don’t they?
The old Innovative kit used to look similar to the current XLR8 kit, but Innovative rethought the loading and potential for problems with front and rear mounts and addressed them by turning the bushings on end. With a lateral mount position, the surface area that carries the weight of the mount is pretty small. With the bushings mounted vertically, the load is carried over a larger area and the bushings have been proven to be much more durable over time, even the softest 60A durometer that presented an issue with the old design.
If the CNC stainless steel bracket on the Innovative mount above looks turned 90 degrees, that is because it is. We were playing with swapping bushings and accitdently left this one off in the pcis.
The rear mount is the same arrangement as the front. The front and rear position mount design are critical due to their need to the loading they take as the engine moves back and forth on and off the throttle. The XLR8 mounts using the lateral bushing layout have been reliable. Our preference is the Innovative method. We don’t try to steer customers one way or the other here, as it seems a matter of preference.
Both mounts use precition cut steel parts which are assembled and welded. One nice feature of the Innovative mount is the individual parts all lock together to locate themselves before welding. The XLR8 design is simpler, but by interlocking the parts before welding there is far less chance of assembling incorrectly before welding. Ultimately, both parts are made in good fixtures that produce repeatable good fitment and we have no complaints about installation on either.
While the front and rear subframe mounts take the burnt of the drivetrain load, the standard engine mount on the right side of the engine tends to fail pretty frequently. Thusly, XLR8 and Innovative Ploy Mount kits both include these passenger-side mounts.
Functionally these mounts do the same thing, but there is no denying the amount of craftsmanship that has gone into the Innovative Mounts rivals the XLR8 ones. If we look at how the load is carried on these mounts, both bushings are mounted laterally. As the engine moves in the mounts, the XLR8 bushings undergo a twisting force, while the Innovative ones undergo a rotational force along the axis of the bolt. As such, there would be more force needed to move the XLR8 mount, putting more stress on the steel brackets. We do have one recorded failure of the XLR8 design here, but it seems to have been an anomoly. We don't see problems with either design in general. Again, we don’t try to steer customers here, but the material and fabrication quality is noticeably more impressive in one of these mounts:
The above shot gives a good look at the shape and size of the Innovative bushings as compared to the XLR8 ones. The Innovative ones are smaller, and have a tapered face to them. Speculation has it that these two factors were contributing to the "donuting" that occurred when the bushings were allowing the mount pins to sag in the material, permanently deforming it. The XLR8 bushings are larger and have flat faces, but these two factors cannot contribute to a more stable bushing. The load is the same. Making the bushing more captive in one area to prevent it from squishing out would only serve to cause it to squish into a different area. The size of the bushing would not prevent the material from deforming either; The reason being, the deformation happens at the point of application of force. Two bushings of the same durometer with a 1/2" hole in the middle are going to deform the same at the hole, whether the OD is 3" or 10".
Thus, with the XLR8 design, we feel, without having measured them, that the stiffness of the softest XLR8 bushings (62A) must be significantly more than that of the softest Innovative bushings (60A); more than the durometers would imply. Otherwise, they would be deforming as well. One of these two is not providing an accurate bushing durometer, it would seem.
But ultimately what difference does it make? We have tested both the 60A and 75A Innovative bushings in our TSX and noticed essentially no difference in vibration between the two. Poly is poly and is going to be uncomfortable.
So there we have it. A real, current-day look at the differences between the XLR8 and Innovative mounts for Honda and Acura J-Series engines. Which one is for you? Take your pick. We sell both at Heeltoeauto.com!
![](http://heeltoeauto.com/gallery/var/resizes/Product-Features/Jseriesmounts/IMG_8267.jpg?m=1401769895)
![](http://heeltoeauto.com/gallery/var/resizes/Product-Features/Jseriesmounts/IMG_8268.jpg?m=1401769890)
![](http://heeltoeauto.com/gallery/var/resizes/Product-Features/Jseriesmounts/IMG_8277.jpg?m=1401769890)
![](http://heeltoeauto.com/gallery/var/resizes/Product-Features/Jseriesmounts/IMG_8276.jpg?m=1401769894)
![](http://heeltoeauto.com/gallery/var/resizes/Product-Features/Jseriesmounts/IMG_8269.jpg?m=1401769895)
![](http://heeltoeauto.com/gallery/var/resizes/Product-Features/Jseriesmounts/IMG_8280.jpg?m=1401769896)
The following 6 users liked this post by MrHeeltoe:
DrOwNiNgPoOl84 (06-15-2014),
EL BAN (10-03-2014),
princelybug (06-15-2014),
st_dot (06-13-2014),
UTAH TSX (09-25-2014),
and 1 others liked this post.
![](https://acurazine.com/forums/images/maestro/buttons/collapse_tcat.gif)
Popular Reply
06-13-2014, 10:14 AM
Appreciate the post, however, to get a real and accurate portrayal I feel we need a 3rd party. If Josh reviews XLR8 bushings he will favor those since it benefits him. Correct me if I am wrong but isn't innovative your company? If so, of course you will lean towards your bushings/mounts.
At the end of the day this really holds little weight until a 3rd party, that has knowledge of both products conducts a test.
2) I do not own Innovative. I wish I did. They have an amazing manufacturing capability for being a small company. They water-jet, weld, fab, and make their own poly bushings ALL IN HOUSE. Only thing they don't do is powdercoat.
3) Heeltoe IS the 3rd party. We don't make either, we sell both. We have a vested interest in customer satisfaction and don't care which mounts people buy. We are just showing you the differences.
Moved to the LOU
The following 10 users liked this post by MrHeeltoe:
1black_seven (06-13-2014),
1uncleanTL-S (10-04-2014),
blownhatch (06-15-2014),
and 5 others liked this post.
twigglius (06-13-2014)
Thanks for the review
Moved to the LOU
I guess I look at things differently. I'm in the world of marketing and advertising so I think about vested interest. How do I know that Heel Toe does not make more of a profit by selling innovative mounts vs. XLR8?
Marcus, you are correct that you stated several times that you do not steer customers. But you also stated in the review that "our preference" when referring to design. Am informative article should have no we, our, terms, etc...
You indirectly and cunningly lean towards innovative mounts. This is totally fine and I'm sure they are both exceptional products. I am just pointing out what I see.
Former Sponsor
Marcus, as usual, you have written an excellent write up. Thank you. I just wanted to clarify some points below that I think are worth adding to this write-up.
Firstly, while I agree that the new Innovative mount kits are better designed than previously there still is the issue of their bushings and the tendency for them to "doughnut". The bushings are smaller, softer, and more prone to distortion. We've seen it dozens of times and in recent years. I can post image after image of it.
Secondly, this new design is still relatively new so it's still difficult to say how durable they really are. You wrote:
But even according to this FB post these are only 1.5 years old and since these had a bad reputation for so long I doubt everyone flocked to buy these too quickly. Thus it would be difficult to say that they've stood the test of time.
https://www.facebook.com/HeeltoeAuto...96682483780745
Well all bushings do deform over time. It may take years upon years and 100,000 miles but they will deform. So I don't think it's fair to conclude there will be no "bushing deformation at all".
Fourthly, Innovative, as a company, is one of the most disorganized companies we've ever dealt with and some of their products have not been designed properly. Our XLR8 mounts ship the same day, on time, and when said they will ship. Innovative ships mounts and orders 3-4 weeks after the order, in our experience. My point is a company's reputation in fulfilling orders as well as design is important as well.
Fifthly, yes you do sell both products but there is obviously some pricing and marketing advantages to selling Innovative mounts over XLR8 mounts. And you stated above that Heeltoe's preference is for the Innovative method and design. So this isn't an entirely neutral write-up.
Again, I'm not posting up to argue or mud sling but I thought this is a needed post amidst the thorough write-up you provided above.
First counter-point: We've sold many of these kits, and are using a set in our personal TSX (same mount design). We've not recorded one failure of complaint since then. You must know something we don't.
Second counter-point: We've been selling these for 2 years now. I think that's a pretty good amount of time to claim the product is problem free. The reputation is poor because there is a popular post chastising an old design, and nobody has really bothered to pay attention that the design was revised and is more reliable in the past. XLR8's been riding that wave for a while selling mounts based on theirs being trouble free as compared to Innovative, but that is not a realistic claim any more, and has not been for years.
Third counter-point: Ok, maybe saying "at all" is an overstatement. But practically, a user should expect to find that these mounts will stand the time.
Forth counter-point: Innovative as a company has it's niggling attributes, as does every vendor we deal with. EVERY vendor of ours is a pain from time to time. Yes, XLR8 mounts ship fast, but we also stock Innovative ones and they ship within a day or so most of the time as well. This is a bit of a feeble claim, that the company is unreliable. They are as good or as bad as the next place out there, depending on the perspective and the timing.
Fifth counter-point: If someone wants an Innovative kit because I like them, or if someone wants an XLR8 kit to be loyal to Excelerate or because they cost less, or someone wants stock mounts for the comfort (which we directly tell people not to buy either as much as we recommend one or the other) then that is their decision. Customer says "Which is better?" We say, they are both great, reliable, fit well, and are well made. "Which would you get?" We say, Innovative. We like the design better, and they look nicer. Different questions get different answers.
Former Sponsor
I've not been riding any wave, other than the one that is tried and true. Our XLR8 mounts have been out that a lot longer and have proven to be more durable.
From a 3rd party review to a mine is better in no time! ;(
Deeznutz8 (08-14-2020)
There is no "mine." I will still happily sell a person either kit, and advise them that both are good quality and function the same. I don't make either. There is no "mine." There has been a very significant difference between these two kits for years now, and I am not seeing that anyone has every really pointed that out.
We don't mind sponsoring and effort like this.
XLR8 can dispute the notion that Innovative mounts might be reliable, but they are the vendor that should come under scrutiny for bias more than Heeltoe. They are the producer of their own kit and have much more interest in retaining market-share over the competition. Heeltoe sells both and makes neither. Our interest is only in customer service and information.
If popular opinion proves that the XLR8 mounts are better, we are happy to offer them to our customers as long as XLR8 will supply them to us. Our sole interest is in educating our customers and providing the products that will make them happiest. If the extra money for an Innovative mount kit seems totally unreal and unjustified, by all means don't buy them.
If our comparison makes it seem like the Innovative ones are better, then we'd like to think you guys are making your own determination there and not just taking our word for it...which we are really not saying anyway.
TLX-S
Thanks for the write up comparing the two ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I currently have the redesigned Innovative with 60A bushings installed on my '04 TL for a year now. I only have the Front and Side installed, there was just too much vibration with the Rear installed, so I have OEM for the Rear.
I've put about 13k miles on the car and haven't had any issues with them. Just the Front and Side does a excellent job at keeping the engine from rocking back and forth.
Marcus, I completely agree with your unbiased review. I was refering to Josh's commentary
MrHeeltoe (06-20-2014)
KingKong_Dav
Why don't u get front innovative mounts n rear xlr8 mount n call it a day
But I like Marcus n his write ups. He's the man.
Josh is cool too he have the best prices in America for all I know.
I have the xlr8 75 durometer ones. I can't compare the two as I've never tried the innovative ones, but loving these mounts so far. Had a lot of vibration when A/C was on initially, but they broke in after a good ~3k miles, and ~80% of vibrations are gone, and yes they are still tight I checked the torque couple weeks ago. It's been 8k miles now and they rock, hardly any noticeable vibration now and they take all the beating I throw at them. Engine feels more connected to the car now and power delivery to the wheels is instant, whereas before on the stock mounts the engine would rock first then car would move. Now she moves as soon as I hit the gas.
Agreed. They don't "break in" in a few thousand miles. You just get used to them. I have the XLR8 60 on the front and side and still OEM on the rear. I've got about 3-4k on them and thought the vibrations were smoother than after the initial install, but then I drove a stock 3G. I was wrong, lol. My car still isn't Nissan VQ coarse.
might be putting my rear oem back in seems like more and more are doing this.
The following 2 users liked this post by MrHeeltoe:
1uncleanTL-S (06-25-2014),
pohljm (07-15-2014)
I have the innovative 60a all around in a 6mt I get really hard vibes it I let out clutch too much at release point and give little to none throttle but that only happens when I'm tired if I leave normal with right amount of throttle no shakes but when ac is on car does shake a bit also on cold starts hope that helps it doesn't bother me but my wife hates it when she drives
put the rear oem mount back on and it's a perfect balance between rigidity and vibrations...vibrations reduce big time with an oem rear mount. completely satisfied with my setup now
Ordered on sunday at my door on wendsday thank you HeelToe, will be installing tonight the front and right mounts and drive it for a few days before we install the rear mount so we can see what the difference is, very nice looking quality stuff the pictures don't show how nice they really are.
MrHeeltoe (10-06-2014)
sockr1
10-01-2015 01:31 AM
