J-pipe/pre-cat gaskets
Old Apr 18, 2009 | 06:48 PM
mglax13's Avatar
New shoes on my
Hello all. I just bought a used RV-6 J-pipe, and it has no hardware or gaskets. I have the RV-6 test pipe, so I have a gasket and nuts and bolts to make the test pipe to j-pipe connection. As for the J-pipe to pre-cat connection, are those custom gaskets, or can I find those online? I'm not sure what to look for or where to buy them. Also, do I re-use the nuts and bolts that currently connect the j-pipe to the pre-cats, or should I aquire new bolts?
Thanks in advance for your help. I just wanted to have this all set before I get under there, start taking things apart and don't have everything I need!
Old Apr 18, 2009 | 10:33 PM
OneWickedTypeS's Avatar
MY KBP IS BTR THN URS...
I would maybe contact the company that made it for new gaskets, this is what I had to do cause after 8 stores and no gaskets...
Old Apr 18, 2009 | 11:56 PM
mglax13's Avatar
New shoes on my
I firgured that would be the route. Alright, thanks for your input.
Old Apr 19, 2009 | 12:20 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
just use some copper rvt
Old Apr 19, 2009 | 12:29 AM
TLAdvanced's Avatar
The Kinetics of Bleu
LMAO! Al, we have been through this before. It is RTV
jmkiang's Avatar
zaino'd
PM Richie V6
Old Apr 19, 2009 | 03:13 AM
greco9885's Avatar
matt, might be worth your while to call up the dealer since richie uses the honda gaskets. the one on your test pipe should be fine since you probably havent had it in that long
and you can reuse the bolts you have, you dont have crazy miles on the car, plus the bolts/nuts aren't torque to yield.
Old Apr 19, 2009 | 10:05 AM
InFaMouSLink's Avatar
Chapter Leader (NY/NJ)
i'll check my supply of extra bolts and gaskets since i bought the whole setup and i'll let you know what i have left over from the kit. its going to be on wednesday tho matt.
Old Apr 19, 2009 | 10:21 AM
jmkiang's Avatar
zaino'd
J pipe to precat gaskets are not OEM Honda gaskets... those are the precats to block gaskets.
Old Apr 20, 2009 | 12:35 AM
mglax13's Avatar
New shoes on my
I just ordered them from Richie. Cheap and easy enough, 2 gaskets and 6 nuts were $12.50 shipped.
Old Apr 20, 2009 | 02:09 AM
Xiomaro's Avatar
1st 3g Turbo TL-S
Richie FTW!
Old Apr 20, 2009 | 04:03 AM
ssmtl2nv's Avatar
2009 g37s 6mt
Originally Posted by Xiomaro
Richie FTW!
+1, his cust service and products are great.
cycdaniel
Dec 17, 2019 10:58 AM
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 27, 2015 06:52 PM
jpm3071
Sep 18, 2015 04:51 PM
